Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
I have an old Whirlpool washer that lately has been leaving a brownish and greasy ring around the top of the tub after washing clothes. What could possibly be causing this problem? The bearings? If so, should I replace the transmission in it or get a new washer?
Replace Seal and bearing, thats all.
Posted on Nov 10, 2010
Clothes get tangle around agitator
unplug the power. open the top of the washer to expose the tub. Hold on to the top layer of clothing and rotate the tub by hand in the direction that untangles the clothes.
Nov 02, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
What is the agitator
The agitator is the large part inside a top load washer tub that moves the clothes around while they wash and rinse.
Sep 26, 2011 | Whirlpool Washing Machines
Our washer is leaving a greasy residue around and on the top of the drum.
If the age of your machine is over 10-12 years old, you could have a model that uses a transmission and the trans is leaking. If it is the transmission, it could be about a $150+ part.
Older washer designs used a motor to drive a transmission to agitate and spin the wash tub. As these get older, some develop small holes in the drive shaft (up under the agitator) which lets the trans grease get into the wash water. Our old washer lasted 23 years before the tub started to rust, so we decided it was time to get a new one, rather than put money into such an old machine.
IF your washer is older than 15 years, it might be starting to develop some other issues, such as rusting tub, etc., that could be costly to replace those parts, like the transmission, so you need to determine if
you want to repair or replace the machine.
If you can provide a model number, with all the alphas and digits, including the pre-printed ones on the label or tag, it could be confirmed that your washer uses a transmission and that is the likely source of the grease you're seeing.
Hope you find this Very Helpful and best regards!
Aug 23, 2009 | Whirlpool Washing Machines
Machine leaves greasy looking streaks on clothes
tub bearing water seal gone ,needs new bearings and seals.
Jun 11, 2009 | Frigidaire GLTF2940ES Front Load Washer
It takes my washer 3 times to ring out my clothes
Hello
Welcome to Fixya
My name is Huum,
You said, lately when i wash, my washer washes perfectly but it fails to ring out my clothes
You have either a bad or loose drive belt.
Or a bad motor unable to spin up to speed!
Sounds like you need a hands on diagnoses !
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
Feb 01, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
WHIRLPOOL ULTIMATE CARE II MAKES YELLOW BROWN STAINS ON LIGHT COLOR CLOTHES
Grease will not come from the interior of the washer, as the machine ages build up deposits under the basket and it is oily, greasy and full of mildew. If can get a spanner wrench from a appliance parts house and remove the basket you will see on machines older than three years a build up starting. I pulled 15 lbs from a 25 year old machine and I had to go get sick outside, it was bad.
Sep 25, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing machine
What actually will happen over time is the stainless steel retianing hub and nut diseningrate and the tub becomes loose. Then the spin cycle will destroy the top balancing ring. When this happens - the washer is junk - not worth repairing.
Before that thou - other mechanical problems can happen, like u-joint breakage. These washers are absolute junk.
Nov 27, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso Top Loader
The wash plate (or nunater) can be removed by following these instructions. It may seem like a lot, but the wash plate will not come out of the tub unless you follow the necessary steps: 1. UNPLUG THE WASHER. 2. Open the washer top. Look along the front seam of the washer where the top meets the front. There are a couple of retaining clips (about 2" in from each side) that you will need to push in on with a putty knife while gently lifting up on the top to get the top to release. Carefully open the top and lay it back against the wall in a resting position. Make sure you support the lid so it doesn't fall open when you tilt the top back. 3. Remove the tub ring. This is the plastic donut shaped ring that sits on top of the wash tub. There will be a tab on either side of the outer tub near the back that you can use a screwdriver to release the tub ring. The ring is filled with fluid and is used to balance the tub. So, if you hear liquid sloshing around, this is normal. 4. Remove the center cone from the wash plate. Use a flat blade screwdriver and insert it into any of the slots available along the sides. Gently pry until it pops off. I say "gently", but you may have to use a little muscle to get it to come off. Sometimes they stick. Once the center cone is removed there will be a series of nuts under it. 5. Remove the nuts and the wash plate should lift out. Be careful not to damage the gasket under it. Your clothing is probably tangled in the leveler under the wash plate. This leveler should have a key on it. The wash plate will only go back in with this key mating to a slot on it. So, remember how you took it off. In addition, when putting the wash plate back on, make sure you tighten the nuts in a cross pattern and evenly tighten them as you go. This will ensure the gasket seats properly. Good luck to you and I hope this helps you. PS Don't forget to put the tub ring back in.
Sep 18, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
Sal De
Gerry Harvey
Gerry Harvey
