NEW FISHER PACKEL WASHER MODEL WL 37T26D JUST INSTALLED STARTED FILLING WITH WATER THEN STOPPED SLIGHT NOISES BUT NOT SPINNING OR FILLING WITH WATER DONT KNOW WHAT THE PROBLEM IS ????? PLEASE HELP
the dr
  • 447 Answers
SOURCE: Whirlpool Ultimate Care II LSQ8220HQ0
You have to start eliminating them one by one a common reason is the spin tub mounting block if the motor comes on and clutch is driving basket drive and brake assembly than this is the problem.
Posted on Oct 04, 2007
ngfam1
  • 639 Answers
SOURCE: Maytag Performa Washer
Whirlpool is good but Speed Queen is the best with the best warranty in the industry!
Tested to wash 8 loads a week for 25 years!
3 years parts and labor compared to all others with only 1 year! And 10 years for the transmission not 1 year like all the rest!
only 34 gallons of water used in the top loader and 13.9 gallons in the front loader.
I'm 53 and I'm not buying another washer again!
YES I SELL THEM AND EVERYONE WORKING IN MY STORE HAS ONE! There are plenty of more features!
Speed queen is used in laundry mats all over the world!
So now that I reallllly saved you, GIVE ME THE BEST RATING SCORE HERE AT FIXYA!!
If its 10 years old or more don't put money into it!
The new ones are much more energy efficient!
Try these guys,they are good!
A&E Factory Service is nation wide!
1800-905-9505
They are open 7 days 24 hours to make appointments
Neil
Posted on Aug 24, 2008
AlmostBob
  • 550 Answers
SOURCE: Water is not filling up.
turn off water
disconnect fill hose from tap
examine screen inside hose end for 'muck' blockage
clean screen
reconnect hose
test washer
if no fill
replace water solenoid valve
note: cold water valve fails first, it gets most use,
if only using cold water, you can simply swap the hot and cold hoses at the tap, and swap the hot and cold electrical connectors on the solenoid valves, the hot solenoid is no the cold one and the washer can be used, cold only, for about as long as it has operated thus far..
Posted on Oct 14, 2008
jumptrout51
  • 3361 Answers
SOURCE: GE top load Washer won't stop filling or spinning
Remove the plastic hose from the water level switch and blow through it until it flows freely.
If it does not clear this way. Remove the front panel.putty knife needed.
Remove the water level tube from the tub and clean out the gunk.
Reconnect it to the water level switch.
Set the machine to spin and run it.
Reset water level control and try your machine.
Posted on Feb 21, 2009
SOURCE: leaks when filling
It could be a swollen impeller inside the pump causing it to wear a hole in the plastic housing and making the humming noise .It,s fairley easy to replace as it clips on to the end of the motor.Hope this helps.
Posted on Nov 28, 2009
Hi I have a geberit cistern 222.013.00.1 with hissing noises and tank keeps topping up occasionally
wait for the new washer/ valve to settle in
or turn down the inlet water tap a bit
what does this really mean
tank topping up with water and re filling occasionally
in the wrong way or too tight or the wrong part ?
Nov 09, 2016 | Home
I have a Sears Kenmore washer (Model # 11092281100). I replaced the motor coupler, and I checked the alignment of everything before reconnecting the motor clamps/clips. It seemed like the motor shaft was...
It could be the grease. It could run without noise if it was not installed all the way. Here is a link for properly installing Motor coupler video Now if everything looks right it is probally just the grease.
Nov 09, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
It is very cold in my garage where my Fisher and Paykel washing machine is. First it would not fill it just ran and ran without filling, then it started filling fine, but then after a while started...
water freezes. sounds like first your fill pipes were froze then the pump froze. if you can find a place inside the house for washer or you may have to build a room around washer and dryer and heat it
Dec 13, 2009 | Fisher and Paykel GWL11 Top Load Washer
Fisher Paykel Intuitive Eco Washer is squealing
You need to pull out the washer, TURN OFF THE WATER, then take the water hoses off the back of the washer. Check the screens inside the water inlets for debris. If that doesn't fix the problem you may need to ask fisher paykel if it's safe to put a chemical like limeaway in those holes to remove hard water deposits that have built up inside the valves.
Sep 20, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
My washer won't stop filling up with water!
This is a faulty water valve assembly. replace asap if possible. the embedded water pressure sensor is damaged.
May 29, 2009 | Fisher and Paykel WA37T26G Top Load Washer
Feb 04, 2009 | GE WBSE2090A Top Load Washer
turn off water
clean screen
reconnect hose
test washer
if no fill
Oct 14, 2008 | Fisher Paykel EcoSmart GWL15
Fisher and Paykel Washer Leaking
For those with water on floor after wash, check my post on "eco smart won't drain, smells hot". It could be something clogging drainage area at very bottom of the tub. I couldn't see the sock that was stuck in my FP's drain when I looked from the top between the white outer tub and the wash tub--everything looked fine. Then I removed the black motor/white plastic housing piece--Tip back washer and you should see this black electric motor/white housing on bottom. see my post for how to remove and check for plugged drain. it's really pretty easy.
don't know about outer tub holes, but glad i don't have that problem.
i hate my fisher paykel washer/dryer. i can't wait to sell this house--i will leave them here and get a new front load Duette for my next house!
May 31, 2008 | Fisher Paykel EcoSmart GWL15
Problem with Fisher & Paykel MW511 toploader washing machine
Having the same problem. Any ideas at all? It's really frustrating.
noavatar_s.gif nwesthamz
Rank: Apprentice
Rating: 75%, 1 votes
mw511 fills with water but cylinder isnt spinnig and when it stops filling nothing happens. However sometimes it will go complete cycle ans a noise can be heard on spin cycle even though it is not spinning. As thoiugh the motor is not engaging with the cylinder
Was this helpful? Yes No
Jan 12, 2008 | Fisher and Paykel GWL11 Top Load Washer
Washing Machines Logo
26 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
