Question about EliteGroup 845GV-M3 Motherboard
845 intel motherboard not working . ram, smps, battrey is ok but computer is not on
    New Friend:
Cpu was working by it was not working
Posted on Sep 04, 2013
  • 135 Answers
SOURCE: No Dispay, No Beep
Try leaving it off but with power to it (should see a small green LED on Mobo) for about 30 minutes or more.
After this time try starting it with RAM installed of course!
If this doesn't work your Motherboard is dead.
Posted on Feb 17, 2009
cyrylthewolf
  • 143 Answers
SOURCE: ram support for intel 845 motherboard
Ok. So you've defined the Intel 845 chipset on your motherboard.
But is it the 845 or 845G chipset?
Click HERE for the specifications of the Intel 845 chipset.
Click HERE for the specifications of the Intel 845G chipset.
Peepnklown is only HALF right.
The Intel 845 chipset does NOT support PC133 memory.
The Intel 845G chipset DOES support both DDR and PC133 memory.
The difference?
The 845 has a single memory controller for DDR memory.
The 845G has two memory controllers. One for DDR and one for PC133.
Although you're going to need DDR memory as it is FASTER and less expensive than the older PC133 memory. (Believe it or not.)
I do NOT recommend using Corsair's ValuSelect memory on this chipset. I have two boards with the 845G chipset and that type of memory does not allow the board to boot.
These boards typically come with DDR266 (PC2100) modules installed.
I would go ahead and buy DDR333 (PC2700) memory for it. The board you have may not utilize the full speed of that memory, but will use tighter memory timings if the RAM is clocked down by the board. This will result in better efficiency of memory use by the processor.
Think of it as giving the motherboard "breathing room".
I could recommend PNY memory for the most basic compatability. (Not that they manufacture their own RAM modules...) Or perhaps Nanya, Infineon or Microtek.
Look for memory compatability lists for your particular motherboard module online. You could also use PNY's memory configurator on their website.
Click HERE for PNY's memory configurator.
Good luck.
Cyryl
Posted on Nov 18, 2007
  • 39 Answers
SOURCE: intel 845 mother support
research the ram to see if it will work on that motherboard. some ram requirements are present when you get memory for a pc. not all ram are compatible with certain motherboards.
Posted on Oct 06, 2008
jell587
  • 447 Answers
SOURCE: My Intel D102GGC and Mercury 915GLV motherboard not wake up
Is this new ram or have you used it in this machine previously?
A couple of things can cause what you describe, one of them being the wrong voltage of ram. This page contains the list of memory that your system can use, check the part number on your current ram in google to find out what voltage it runs at (the recommended voltage for your board is 1.8v).
Other than that you may want to do a CMOS reset by changing the jumper block (should be described in your mobo manual), powering the machine on briefly, power it down (unplug) and return the jumper to it's original location. Now try to post the machine.
Posted on Mar 06, 2009
varun_engr
  • 516 Answers
SOURCE: mother board fault
NO problem about..... the mb..
its ok.. The problem may be with SMPS or motherboard...
Contact the from where you buyed your PC..
Posted on May 30, 2010
MY COMPUTER IS NO DISPLAY, POWER OF SMPS & CPU FAN IS RUNNING , RAM IS OK, MY BOARD IS INTEL 845 GVSR
sounds like you may have an issue with your display driver or grahics card. try opening the computer and re-seating all of the hardware.
unfortunately this used to happen to me and its basically a trial and error fix.
Does the bios make a beeping noise when started?
Jun 11, 2011 | Computers & Internet
My machine is not starting..CPU fan stops just after starting for 3-4 sec..I am sure that the CPU,RAM and SMPS are OK.Most probably the problem is in the MB.Kindly help me to solve the problem.I am using...
if your power supply is good and has DC output.....i have encountered a leaky capacitor at motherboard near the power supply connector socket...need to replace it esp. if it manifest bulgy appearance..it is a electrolytic type, replace w/ same value, it does affect the power to supply the MB due to fluctuation......try to test run after replacing it..have a nice day...
Feb 12, 2011 | Mercury P4VM800M7 Motherboard
Mother board fault
May 30, 2010 | Mercury P4VM800M7 Motherboard
No Dispay, No Beep
Feb 12, 2009 | Intel D845EPI (INTELKD845EPILPAK10)...
Intel 845 mother support
Oct 02, 2008 | Intel Motherboard
845gvsr motherboard problem
I think it is ram's malfunction. Plug out the ram chips. clean it's terminals with soft clean cloth.
Mar 26, 2008 | Intel Motherboard
No display
hi
if you known about your all SMBS, RAM ,, PROCESSER, & HD Are all ok
  1. chack your ram then clean your ram slot
  2. smps ok
  3. about me your screen is black
  4. chang your bios battery 1st
  5. you use any video card...
Mar 03, 2008 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Display problem in pentium mother board!
MODEL NO.--INTEL 845 GVRS. problem is --- power led is on but no display and no beep sound. SMBS, RAM ,, PROCESSER, & HD Are all ok. Pls. tell me how can i slove my problem?
Nov 13, 2007 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Ram support for intel 845 motherboard
The difference?
Good luck.
Cyryl
Nov 10, 2007 | Intel Motherboard
EliteGroup 845GV-M3 Motherboard Logo
256 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
