Question about One For All URC4110 Remote Control
Need code for VM 4000+ cable box
I am needing the code for the VM 4000+ cable box for use with the universal remote. Thanks!
Try a Learning Universal Remote like Sony RM-VL600! Should work...Lorenzo
Posted on Sep 29, 2008
How do I get it to control Magnavox cable box?
Codes are in the remote. If your GE remote is universal, you can use it to search for something that will work with your Magnavox cable box. If you search through all codes stored in the remote without success, you may have to try a different universal remote. All universal remote do not contain all possible codes.
Nov 20, 2015 | GE Televison & Video
How to control my cable box with the tv control
hello!
refer to your TVs owners manual. You will find codes for common set top boxes there. all the new TV remotes are universal. If you see "cable" or "cbl" button on remote, you will be able to do so. Worst case scenario: you need to buy universal remote or use your cable box's remote to control basic functions on TV. Codes for TVs are included with cable box's remote control. Or, you can call your provider and ask for "Sony Bravia"codes. If you have a satellite box, codes are supplied right inside "setup" menu of the box.
Good luck,
Alex.
Jan 30, 2012 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
I have a Trutech PLV1615T TV and a RCA RCR311 Universal Remote that I lost the info for. How can I get them to talk to each other....Thanks, Tom
RCA Universal Remote Control Programming Codes Programming Your Universal Remote.The remote may already be set up to operate your brand of TV, VCR, or Cable Box. It is pre-programmed with following codes: y TV-000 y VCR-000 y Cable Box-000 y AUX is programmed with VCR code 037For brands that require programming, there are two ways to program: Using Code Lists or CodeSearch. Use Code Search if the code lists are not available or if the codes from the lists do notoperate a device.Programming a Device using Code Search:1. Manually turn ON your device (TV, VCR, Cable Box)2. Press and "HOLD" CODE SEARCH3. Press and release the device button you want to set up (TV, VCR, Cable Box) However,if you are using AUX for a device, press and release AUX first and then the devicebutton for the type of device to be programmed (TV, VCR, or Cable). The selecteddevice button will flash once.4. Release CODE SEARCH.5. Press OFF/ON repeatedly until the device turns off (you may have to press up to 100times at a rate of once per second).6. Once the device turns off, press and release ENTER.7. With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6...Hope this helps! Parsos215
Sep 20, 2011 | RCA Universal Remote Control
Trying to incorporate my Hannspree remote with my cable remote as to use just the cable remote......? Thanks, ph
Hi, unfortunately the only way to use your particular brands remote with your cable companies remote is if the cable remote has what's called a "LEARN " key. This is used for cloning another remotes codes to the cable's remote. Unfortunately most tv suppliers don't provide their codes for universal remote use. The first thing i would do is contact your cable providers customer assistance to see if they have setup codes for your brand. then if that doesn't work then you can always buy a universal remote with a " LEARN " function, enabling use with hanspree tv as well as current cable box. I hope this was helpful and thanks, let us know how we did, Good luck ,Prodzilla
Apr 13, 2011 | Hannspree ST42DMSB 42 in. LCD TV
Need to program a universal remote to work on Magnavox TB100MW9
Most of these are new and codes do not exist for them. You'll need a universal remote that has a learning feature so it will learn the code. Walmart has them for $16-$19.
Nov 11, 2008 | Philips Magnavox 27MS343S 27" TV
Remote Control Code for Motorola Cable Box
I have a Motorola cable box and used code # 051. Works great. Can't find a code for DIGISTAR tv though. If anyone has one, shoot it to me at deannescollard@hotmail.com.
Feb 22, 2008 | Motorola Mobility DRC800 Universal Remote...
One For All URC4110 Remote Control Logo
457 people viewed this question
Top One For All Televison & Video Experts
Computer Repairing
Computer Repairing
Are you an One For All Televison and Video Expert? Answer questions, earn points and help others
