Question about Watches
How is a stauer notched leather watch band removed and replaced
No, he asked about a notched band, like on the Graves. Here the watch attaches not across the full 2cm or so but at two 6-7mm lengths around either side of a center protrusion, through which the pin slides.
Each pin consists of a longer part and a shorter end cap with a smaller pin maybe 2mm long that fits into the end of the longer hollow pin. These take a fairly serious pull to take apart, but must be pulled with care, for two reasons: one, so the pieces don't fly off and get lost when the pin comes apart, and two, so you don't accidentally torque the head sideways off the small pin, which is easy to do when you're pulling hard and not being careful. Vise-grips, with maybe thin wood like popsicle stick pieces to cushion the end caps might do, so you don't damage the end pieces as you squeeze, but again be careful. (If you do twist the endcap off its tiny pin, you might be able to glue it back with superglue (cyanoacrylate), but that's a patient precision operation by itself.)
Once the pieces are detached, the long pin will slide through the simple hole in the top and bottom protrusions from the watch case. You can customize your replacement band, set the pins, and gently compress them, again with widemouth pliers and a cushioning, they will go together more easily than they came apart.
Other Stauers use regular pins you can just pop off with the end of a pen knife, but this one is trickier.
Good luck :-)
Posted on Aug 19, 2014
  • 183 Answers
SOURCE: need to find half replacement band for eclissi watch 23120
This as with most fashion brand watches has to be ordered through the manufacturer. Contact the manufacturer direct or see a retailer for instructions.
Posted on Sep 18, 2009
escapement
  • 2334 Answers
SOURCE: Removing Links from the Stauer Atomic Watch band
Click on my profile (escapement), then click on Tips and Tricks. There you will find tip how to add or remove links. Rate me, please .
Posted on Apr 08, 2010
  • 2501 Answers
SOURCE: HOW IS A STAUER NOTCHED LEATHER WATCHBAND REMOVED
These sound like standard spring loaded pins.
To remove them I use a small screw driver and press it gently against one end of the pin, while pushing it lengthwise.
This compresses the spring and allows the pin to pop out.
(take care where you do this as it may fire out and get lost).
It may take several attempts to get pins out, as you have to experiment with the forces applied to get the right balance.
Putting the pins back in is also a skill. putting the pin into the strap, put one end into it receiving hole and press the other end as far as you can. Move the end in line with the other receiving hole and remove screw driver. It sounds easy but takes a little practice!
Posted on Jan 05, 2010
  • 299 Answers
SOURCE: HOW DO I CHANGE THE LEATHER BAND ON THIS WATCH?
The springbars can be retracted using a small tweezers but a springbar tool will make it a much easier job. You can get one from Amazon or ebay for under $5 - search "springbar tool" to find them.
Posted on Apr 24, 2010
  • 103 Answers
SOURCE: My 433lsl black band broke. I can not find a replacement broke
order a replacement band directly from skagen its only $25
http://www.skagen.com/service/home.fx
Posted on Aug 04, 2010
Need to replace my leather watch band on my goofy watch with an authentic disney band. it is leather with no characters on the band & underside is stamped with disney made in china. Need size &...
If you need an authentic Disney watch band, try asking at a Disney store. However, non-Disney watch bands will fit this watch and may be both better quality and less expensive. Almost any jewelry store, department/discount store jewelry counter, or shopping mall watch kiosk will be able to measure your watch and determine the right size band. Many women's watches in this general style use a 14mm or 16mm band, but you should measure your watch to make certain.
May 05, 2011 | Disney Goofy Brown Leather Strap #D075S007...
Hi , I need a leather band for my nautica a 23095
You can take any leather band but the wide must be 22mm. I´ve a diving band from casio watches since 4 Jears. It´s still ok.
Dec 31, 2010 | Nautica A23095 Watch for Men
Aug 03, 2010 | Skagen 433LSL Wrist Watch
Puma PU100041004 Watch Black Leather bracelet replacement/repair
mcdevito75 here, BEST BET, look for a small watch repair shop in your area for a replacement band.
Jul 10, 2010 | Puma PL1050
Skagen watch band pins I've remove/changed spring pins other watches several times before but for this watch nothing happening How is it done?
they are very tough they have more pressure on them than most spring pins also on your watch they are tucked into the leather very well. the best way is with a spring tool apply quite a bit of pressure. a normal watch band will not fit this watch. it will only take skagen replacement bands.
Jun 24, 2010 | Skagen Titanium Rectangle Watch Dial...
Apr 08, 2010 | Swiss Stauer Deep Dive Watch
Jan 05, 2010 | Watches
Watches Logo
2,546 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
