Question about Kodak Easyshare C182 12MP Digital Camera
Our camera makes audible internal noises when in use. Should the unit make any noise when in use?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 93 Answers
The unit produces sounds when like zooming or focusing or taking pictures. other sounds are malfunctioning in the unit, get it repaired.
Posted on Nov 09, 2010
Technical Pro LZ6200 noise from fans?
Not that this is a computer problem, but you know us computer geeks............
Noise in what way?
Audible noise from the fans, or noise in the 'line'?
As in needs a capacitor in line for static suppression?
Plus I gotta' ask...............salesman states there is noise from the fans?
If this is a known issue that the salesman is aware of, is there also a 'cure' that the salesman knows of?
I mean if I'm purchasing something online,......yes.........it's GREAT that the salesman is so forth coming. Good method to have repeat customers IMHO.
But I would think a known problem, should have a known solution, also. Just my 2cents.
{Yeah, I would recommend this, but we don't know if an old lady from Pasadena drove it with a lead foot, or the tires we're already bald.
If you want it though, I'll sell it to ya}
Awaiting reply. State in a Comment.
Noisy fans as in audible noise, or line noise?
Also, I believe you should re-post this problem in > Electronics > Audio Components > Amplifiers & Preamps.
There you will find true experts in this field, and not some 'guessing geek'.
Regards,
joecoolvette
Mar 01, 2013 | Computers & Internet
Why the amplifier is getting the sound of the engine att he spekers? while having the car with the engine running, you can clearly hear the engine noise on the speakers
There could be a number of issues
1. Grounding
2. Kinda speaker cables your using
Check your wireing and make sure this is not grounded to where it can be interfered by the engine.
Aug 17, 2010 | Majestic MA4200R Car Audio Amplifier
Camera says
Hi there just like to informed you that 2 reason can make a noise.
1. low or old battery's using.
Solution: replace it if too old or charged it fully.
2. Lens error. Internal lens guide pin if damaged then the camera goes off with bad noise.
Solution: repair or replaced the lens guide pin.
Thanks & waiting for your feedback.
Apr 01, 2010 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Canon Internal Flash will not Pops up and will not flash. Is there something I can check for or replace? I have a cannon rebel xti, the external flash works great, the button to make the flash pop up will...
Is it trying to pop the flash and making noise, or is there no noise at all?
If it's audibly trying and it won't pop up, it's stuck and something is blocking it. May need to send it in.
If there is no sound, then something is making it think that there's an external flash attached. Check out this photo here:
http://www.flickr.com/photos/dougpardee/133066175/
Doug Pardee on flickr may be able to help as well.
Hope this helps you! If so, leave me a rating!
Feb 26, 2010 | Canon EOS 400D / Rebel XTi Digital Camera...
Carrier Compressor Issues?
When you shut it off and back on it slugged the compressor if you turn it off and back on before the pressures equalize between the high and low sides it will slug the compressor and it will not run should let sit for five minutes or so before restarting. The humming is either the compressor making noise usually common for the compressor to make some noise or the fan motor bearings are getting bad on the outside unit. If the unit works normal probably not much you can do till it breaks if it is the compressor it is more economical to replace the whole unit if it is just the fan motor it is worth changing. You could take an amp draw on the fan motor and the compressor to see if the are within the limits on the name plate of the outside unit.
Jan 25, 2010 | Heating & Cooling
1997 s10 2 wheel drive truck. 4.3L v6 makes a loud noise as the car accelerates fast or under load. When running 55 I can release the gas pedal and the noise is not audible. I can put the truck in neutral...
Your noise sounds like it is power train related,If you have eliminated the engine,Since it doesn't make the noise while moving and in neutral.
It sounds like a universal joint in the drive shaft.Do you notice a vibration
along with the noise?
Nov 17, 2009 | 1997 Chevrolet S-10 Pickup
Buzing noise from power unit
What kind of system is it?
What "power thing" inside what?
It's a good chance its a ground loop issue.  Make sure the power cords aren't wrapped around each other or touching the speakers or running parallel with the speaker wires for more than a couple inches (interference transmitted into the speaker lines audible through speakers).
Aug 04, 2009 | Sony DAV-SA30 System
52 in. rca high def. rear proj. making high pitch noise
the set probably has lots of bad solder connection on the flyback and in the horizontal deflection circuit.
Feb 24, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Squeeking noise from unit when u switch set on but no picture?
Sounds like the HV generator will need to be replaced. Can you tell if the sqeaking is coming from this component without touching it?33c0a28.jpg
Feb 01, 2009 | Televison & Video
Loud groaning noise when copier is turned on.
sounds to me like the laser unit is going bad. common problem on this model.
razors
Nov 28, 2007 | Copystar CS-1510 Copier
Kodak Easyshare C182 12MP Digital Camera Logo
94 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
