Question about GE GSS25JFPCC / GSS25JFPWW Side by Side Refrigerator
GSS25QSWC SS GE refrigerator will not dispense ice or water, makes ice fine
  • 4,070 Answers
Since both are not working I am assuming it is related. So the water inlet valve on the back where the water supply connects may be bad. Disconnect the water lines coming out of the valve and try the water dispenser to see if water comes out at the valve. You should also hear the solenoid on the valve click. You can swap the wires on the dual valves and try again on the ice maker side. If not water comes out and you hear the valve work the screen may be blocked up before the water valve. Take the incoming water line off to see if you have water there.
Posted on Nov 09, 2010
Have a SS #GSS22WGPEWWW Ice not coming out
Try taking ice pan with auger out hold door open and press light switch for the door in while someone presses dispense ice. I want to see if the motor is turning behind the auger ice tray. The door switch has an interlock and when door is closed the dispenser controls should be functional. When open this disables water and ice dispenser. waiting on your response, Sea Breeze
Jan 26, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
GE PSS26GRE SS not dispensing ice
The first step you need to do is to turn the water off to the refrigerator so it quits making until you get it fixed.
If your fridge has the control boards in each side of the freezer cabinet that controls the icemaker, then you have a failed board. If you have a standard icemaker with the metal shutoff arm then you have a failed motor module in the icemaker. You can remove the icemaker and unplug the wiring connector from it so you can leave the water on to the dispenser.
Thank you for contacting Fixya.com
Aug 11, 2009 | GE Profile PSW26P Stainless Steel Side by...
GE Profile Fridge Model No. PSC25MSWA SS not making ice
Check to see if there is any obstruction (object of any kind) in the ice cube mold area. If nothing found, you will have to replace the icemaker, as individual repair parts are not available.
Aug 04, 2009 | GE Profile Arctica 25.4 Cubic Feet...
Makes ice fine but doesnt dispense
Sounds like the dispenser auger is frozen up or stuck. The lights dimming happens because the voltage drop from the stuck auger's motor when you try to use it. Remove the ice machine and clean it. Do not try to take it apart!
Sometimes, the ice machine will fill too much with water and get stuck. Often, it's because the cabinet isn't level.
Jul 09, 2009 | GE Profile PSW26P Stainless Steel Side by...
PSS26PSTA SS - Only dispenses crushed ice.
Remove the ice dispenser bucket. You will see a square hole at the back wall with a horizontal rod in it. You should be able to move it up and down with you fingers. If not, it may just be frozen. Warm it with a hair blower and try again. If still no luck, the WR62X58 dispenser solenoid may be burnt out / melted and need to be replaced. It is attached to the metal just above and behind that square hole. The removable tray at the bottom of the dispenser recess is a part number WR17X12133 for a PSS26PSTA SS. Contact any GE servicing dealer or general appliance servicer near you to get one. You can get parts direct from GE also, but the won't be any cheaper, and you may pay more shipping and handling.
Nov 20, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Monogram ZISS480DMCS Ice Maker Problem
i would first check water supply to ref. measure the resistance of coil either open or resistance. if all this is ok then exit side of line needs to be checked for water.
Sep 22, 2008 | GE Monogram ZISS480DRSS Stainless Steel
GE GSS25JFPCC / GSS25JFPWW Side by Side Refrigerator Logo
126 people viewed this question
Top Refrigerators Experts
Sal De
Brad Goodale
Sometime Mechanic
