FixYa.com
Tags:
Lexmark X5470 All-In-One InkJet Printer
Faxing problems (by 2 users)
posted by sazzi555 on Jun 16, 2008
i can send a fax but not recieve,i can hear the fax ringing and got it on auto answer as no other phone is attached, but nothing what am i doing wrong?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by tompace, posted on Jul 11, 2008
I can only receive faxes when the PC connected to it is turned on.
I've reset to defaults, checked everything. We did have a power outage about a month ago, and the clock on the Lexmark X5470 had to be reset. But it's weird when the computer is off the fax won't pick up. There is an answering machine inline, the rings have been set, which is why it Does pick up when the computer is turned on. It did receive faxes when the PC was turned off, up until about 3 weeks ago. Could I have set something wrong when re-setting the clock from the power outage ?
Thanks!
Best Solution
posted on Jun 18, 2008
Thanks for Trying (70)
Din-D-tech
Rank:Wiz Wiz
Rating: 85%, 21 votes
Are u using a dedicated line for the fax or is it shared.....
If u are using an answering mech...then u need to set the rings...on the fax greater than the answering mech...
Or else Clear the NVRAM....(Note u will loose all the contacts saved in the fax mech)
a. Make sure the printer is in “Copy Mode”.
b. Press the “Menu” button once.
c. The screen will display “COPY MENU: Copies”.
d. Press the left arrow button once. The screen will display “COPY MENU: Tools”.
e. Press the button once. The screen with read “Tools: Maintenance”.
f. Press the button once. The screen with read “Maintenance: Ink Levels”.
g. Press the right arrow button until the screen reads “Maintenance: Print Test Page”.
h. Press the button once.
i. This will start the Self-Test. Once the page has printed, the printer will stop. The test is not continuous.
The printer will prompt u to set it up
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Printers problems?
help
printer makes noises when off... Answer This...
Cartridges 32 & 33 say they...
Apparently not. They are... Answer This...
problem with my printer
i have a laxmark X5470 series... Answer This...
remove ink
how to remove the ink for the... Answer This...
phone line error
i unplugged the machine to move... Answer This...
Repair Service
Find Printer Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
