Question about Cooper Wiring Devices Aspire Smart Dimmer Switch, Sand
I'm using a Cooper Master Dimmer with a Cooper toggle type 3 way switch circuit controlling one incandescent light fixture. My home is 30 years old and I've found many deviations from acceptable wiring practices. I hooked the two switches up last night and as long as I have the toggle type 3 way in one position it will allow the master to control the fixture brightness. When I turn the master off it comes back on about 1 minute later. I suspect the travellers are not landed correctly. I'm about to start ringing out the wiring if I could be certain that the master switch is not malfunctioning.
    Novelist:
  • 107 Answers
The problem is most likely not the dimmer or the wiring, but rather the existing 3-way switch.
First of all, the Aspire smart dimmer does not work in conjunction with traditional, 3-way, on/off toggle switches. When the 3-way switch is in one-position, it lets the dimmer work, but in the other position, it cuts power to the entire lighting circuit - and the smart dimmer is NOT going to be able to override that. You instead need to get the corresponding remote dimmer (sometimes called a slave, or a companion dimmer), and use that to replace the standard 3-way switch.
That may also solve your "mystery turn-on" issue. Even though those dimmers can use the existing 3-way switch wiring, you have to REALLY pay attention to the instruction sheets to see how the master and the slave wire up to each individual electrical box. I vaguely remember that even if you were to use the product in a single-pole application, those two wires that, I assume, you attached to the traveller wires in the house needed to be shorted together in order to work - and since you have them running into a 3-way switch, the errors that you're seeing are bound to happen.
Long story short, get the slave dimmer, install it according to the instructions, and all these problems should go away.
Posted on Nov 09, 2010
Cooper wiring devices 390-6107xx-eg1d wiring diagram
This is the Cooper product #6107; Standard Series Occupancy Sensor, 3-Way, 500W/400W, Incandescent, Halogen, Fluorescent Rapid Start Ballast.
Do NOT use to control light fixtures with CFL or LED lamps!
Connect this switch by using the diagram for the #6107 Single-Pole or 3-Way (match your existing switch) linked below.
https://objects.eanixter.com/PD365967.PDF
Dec 01, 2013 | Cooper Wiring Devices Electrical Supplies
Lights flicker in circuit with dimmer switch
Dimmer gone bad.
Buy new dimmer.
Check total wattage of bulbs, and compare with watt rating of dimmer.
Check if dimmer feels warm
reduce watts in ceiling linghts
http://waterheatertimer.org/How-to-wire-3-way-dimmer.html
Gene
h
Jun 26, 2013 | Electrical Supplies
Is the cooper 6482v compatable with a hunter fan?
Hi, I'm an electrician and can answer your question.
This switch may be expected to operate your paddle fan / light correctly, when properly installed.
"Properly installed" means that the loads will not exceed the limits of the switch. For your Cooper 6482V-K this is: 300 watts of light (bulbs should be standard incandescent types - or other type such as compact fluorescent, but only if they are clearly labeled as "dimmable") and not more than 1.5 amps for the fan motor. This 1.5 amp rating of the switch is usually more than enough to handle most residential paddle fan / light fixtures. The lights must be connected to the continuously variable dimmer and the fan to the 4 speed switch - do not swap.
I hope this helps & good luck!
Jan 20, 2013 | Cooper Wiring Devices 6482V-K 4SPEED...
Lightolier 3 way remote wiring
If you have determined the wiring to be correct, then yes, the remote is probably defective..
According to Lightolier literature, your Lightolier OS600 is called a "strap dimmer". Having 540W on a 600w rated switch is pretty close to the limit (90%) of the switch, and will cause the switch to fail sooner than say a 300w load. The 600w rating of the switch applies only if all the heating sink fins are in place. Often times, when installing in a box with another switch or dimmer, fins must be removed to allow the switch to physically fit. If any fins are removed, the rating of the switch is reduced. Page 30 of the manual shows that a 600w strap dimmer that has a single fine removed is reduced to a 500w capacity dimmer, and if both fins are removed, it is reduced to a 400w dimmer. You may find that you will need a 1000w dimmer to reliably gain control of your 540w load, as it will control 600w even with both fins removed. This derating is required due to the heat created by the dimmer. Heat is a killer for electronics, and solid state dimmers are no exception.
Check out page 32 of that manual. On it, are wiring diagrams for dimmers and switches. I believe your is figure "G" that shows the 120v "hot" (black) connected to the black wire of ALL switches, the yellow wires of ALL the switches are connected together, but are not connected to anything else, the 120v neutral (white) connects to the MASTER white wire AND light fixture white wire and finally, the MASTER red wire connects to the light fixture black wire.
It is also important to note that these switches are for standard tungsten incandescent and quartz halogen lamps ONLY. They are NOT suitable for CFL, Fluorescent or other types frequently found in commercial / industrial buildings such as neon or other gas lamps such as Metal Halide, Mercury Vapor, High Pressure Sodium, etc.
Jun 01, 2012 | Philips Lightolier Onset 600W Incandescent...
Can i use a Leviton slide dimmer no. 6631 with a holegen fixture
Incandescent and halogen appear the same to these switches. Basically, if the fixtures has a ballast or the lamp uses gas for illumination (as opposed to filament) it will require a special dimmer made expressly for that use or no dimmer is permitted. Such lamps would be fluorescent, compact fluorescent (aka CFL), high pressure sodium, mercury vapor, etc.
There are also some DIMABLE CFLs on the market. These can be used with ordinary dimmers and require no special wiring. Simply remove the old incandescent and replace with a dimaable CFL. Be sure to read the package for any limitations. Keep in mind, the CFL package must state it is dimable, as not all are. Dimable CFLs cost more than the non-dimable types.
Even though it was not asked, never use a dimmer to control the speed of a fan. That applies whether it is a paddle fan or a table fan plugged into an outlet that is controlled by a dimmer switch. There are variable speed motor controls made for this purpose.
Dec 25, 2011 | Leviton Electrical Supplies
I changed the light bulbs in the fixture it controls, now it does not work. What is wrong?
This switch is designed to dim incandescent lamps. It has nothing in its description about being used with CFL (compact fluorescent lamps) types. If you are attempting to dim standard CFL types, it will not work.
CFL's are available in both dim-able and standard types. As you may have guessed, only those marked as "dim-able" will work with a dimmer switch. Dim-able CFLs cost slightly more than standard CFLs but may be controlled by any switch. Dimmer switches may only control incandescent and other type lamps that specifically state they are compatible with dimmer switches.
If you are attempting to dim incandescent lamps, make sure that you are not trying to dim lamps with a total wattage greater than the dimmer can handle. Most dimmer switches are rated for 600 watts, if you have two dimmer switches under one wall plate, the wattage rating drops to about 500 watts. This de-rating is because of the heat the switches create. There are dimmer switches that can dim more than 600 watts, but the price skyrockets for a 1000 watt dimmer, and keeps climbing.
If your wattage is within the limits of the dimmer, check the bulbs. If they are ok, the dimmer may have failed and require replacement.
If you found my reply helpful, please rate it "4 thumbs up". Good luck & thanks!
Aug 16, 2011 | GE 18027 Dimmer Toggle OnOff with Slide...
I just installed a Leviton IP106 Illumatech dimmer switch. It was replacing my existing rotary dimmer switch. The switch is a 3-way wiring job, with another 3-way toggle switch (no dimmer) on the other...
The Leviton IP106 Illumatech dimmer switch must be installed at the switch location where the hot feed exists. From your description your hot feed is at the regular 3-way switch location. Swap locations.
Dec 22, 2010 | Leviton Decora Light Dimmer Switch
How to install a dimmer switch
This is a 3-way switch, made to control a light fixture that is also controlled by another switch in a different location. A typical example is a ceiling light fixture installed in an upstairs hallway, which could be controlled by switches at both top and bottom of the staircase.
The green wire in your switch is the ground connection, and joins to the green insulated or bare copper ground wire in the switch box. The red wire is the common connection. It connects either to the incoming AC hot wire from the electric panel, or to the hot terminal of the light fixture, depending on the switch location. The two black wires are traveller connections. They connect to the traveller terminals of the other 3-way switch.
If you purchased this switch as a replacement for a regular single-pole toggle switch or dimmer switch - one that controls a light from a single location only - then this isn't what you need and you can't use it. You'll know if you have a single-pole switch because it will have only three wires or screw connections. Return it and get a single-pole.
To install this as a replacement for a 3-way toggle switch or dimmer, connect the red wire to the wire going to the common terminal of the original switch. This will be a black- or brass-colored screw on a toggle switch, or the different-colored (not green, that's ground) wire on a dimmer. The black wires connect to the wires that go to the traveller screws (copper-colored) on a toggle switch, or the same-colored wires on a dimmer. It doesn't matter which traveller wire connects to which.
Note that if you're using a 3-way dimmer, only one of the switches can be a dimmer. The other switch has to be a plain old 3-way toggle.
Apr 08, 2010 | Pass & Seymour / Legrand D703P Harmony...
Wiring dimmer to knob and tube
You should attach the green grounding wire to the metal box using a green grounding screw. You don't want to leave the wire loose, as any contact with the switch screws could cause a short.
Also, you should wrap the switch with at least 2-3 complete wraps of electrical tape to prevent the screws from contacting the sides of the wall box.
As a side note, you should likely have a complete check done on your house if you still have knob and tube wiring installed, as the dangers associated with this very old wiring are many. Typically, older K&T wiring was used in homes well over 60 years ago and houses then only had minimal electric current drawing devices, such as lights and a couple of other small appliance devices (toasters, coffee pot, TV and radio, etc.)
The problem with older homes with K&T wiring still in use, is that the circuits can be easily overloaded with modern electric convinences and lead to a possible fire situation, especially since there is no dedicated ground to help mitigate short circuits, etc. Also, the rubber based insulation used on this type of wiring deteriorates after 40 years (+/-) and rodents tend to chew on exposed wires in attics and crawl spaces.
I don't wish to alarm anyone, but as a Licensed Master Electrician, I've seen and done my share of repair work involving Knob & Tube wiring and even had a couple of homes that had a mix of it and other, newer wiring, that I've completely rewired. Many states require K&N wiring be replaced before a home can be sold, so getting a jump on it will make your home safer and better suited to operate all the devices that people tend to have, in today's society.
Hope you find this Very Helpful and best regards!
Aug 27, 2009 | Cooper Wiring Devices 6009W-K ROTARY...
Cooper Wiring Devices Aspire Smart Dimmer Switch, Sand Logo
460 people viewed this question
Top Cooper Wiring Devices Electrical Supplies Experts
ken skalski
Jim Y
Jim Y
Are you a Cooper Wiring Devices Electrical Supply Expert? Answer questions, earn points and help others
