Question about Whirlpool ER8AHKXR
Where is Blower Fan Located - Whirlpool ER8AHKXR
  • 316 Answers
There are normally two fans on a refrigerator. One inside the freezer, and one on the outside near the compressor.
Posted on Nov 09, 2010
    President:
  • 1,218 Answers
Good day,
It is located behind the rear panel in the freezer compartment. If It has an ice maker, you would have to remove the 3 screws or 1 screw and 2 clips as well as the wire power plug and remove it first.
Remove the screws holding the rear panel, and it will expose the fan motor. Fairly easy change out.
Pretty much nuts and bolts operation.
Make sure you replace the blade as well, if it doesn't come with the motor kit.
Blower fan n orkn in my 95 jetta and cant fid a fuse ohe panel that says blower fan
Heater is controlled by a fan switch located in your dash panel, a resistor and a blower motor. If the fan is not working the first place to check is the resistor which is located behind the dash panel in the plenum. The way to check this is remove the plug and insert a jumoer wire, if the fan runs the resistor is bad.
Nov 09, 2013 | 1995 Volkswagen Jetta
Where is the Heater Blower Motor Resistor, located on Chevy S10, 2002?
The resistor is located right behind the blower fan motor and to the drivers side just a bit. I found it easier to get to the resistor by pulling the blower fan housing
Mar 05, 2011 | Chevrolet S 10 Cars & Trucks
Where is the heater fan located in a 2000 chevy impala?
Here's a great video too that will show you where it's located and how to replace it.">
Feb 14, 2011 | 2000 Chevrolet Impala
2007 Pontiac Vibe - Fan only works on high. I removed the cabin filter and checked the fan blower. It seemed not to be bound up.
The blower resistor has failed.It is located right next to the fan blower motor. It is located passenger side under dash.Check the pigtails to make sure no wires appear damaged.
Sep 17, 2010 | 2005 Pontiac Vibe
2004 sierra, fan blower stopped, not the fuses. where is the fan blower switch and how do I replace
get a voltmeter; check for 12vdc at the blower motor with the blower turned on; if there is voltage, the blower motor is bad; should be located behind a panel underneath the dash on the passenger side; if the fan works on 1 or 2 speeds, it is probably the blower resistor located in the same area as the blower; u can check utube for details
Jun 27, 2010 | 2004 GMC Sierra 1500 Crew Cab
Heater blower went out. Where is the blowere/fan
your blower motor would be located on the front passenger side underneath the dash
Jan 15, 2010 | 1988 Cadillac Sedan DeVille
1998 Ford Expedition Fan Blower Resistor Location
It should be located on the blower motor housing under the right side of the dash, it will have wiring connector and 2 screws holding it in.
Jan 09, 2010 | 1998 Ford Expedition
Where is the air coditioner fan andthe
One in the same, are usually up under dash on passenger side, or behind glove box.
Aug 14, 2009 | Dodge Caravan Cars & Trucks
I have a 1999 Saab 9-5. The fan blower doesn't
The fan is located under the windsheild wipers. The windsheild wipers will have to be removed. Then remove the plastic shroud and wiper motor and assembly. The fan is located in the middle under the windsheild. If your feeling the AC you can check the stepping units located on the AC unit behind the front console under the dash.....KEH
Aug 04, 2009 | 1999 Saab 9-5
1992 Cadillac Coupe Deville blower fan runs all the time
The BLOWER MODULE is located on the A/C EVAPORATOR housing located UNDER THE HOOD passenger side firewall. Has 2 electrical connectors. Mounted with 4 screw bolts.Hope this helps
May 20, 2009 | 1988 Cadillac Sedan DeVille
Whirlpool ER8AHKXR Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Sal De
Steve Allison
Steve Allison
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
