Question about InFocus X3 DLP Projector
I connected the proyector to the pc but i do not get the image, i press computer and i got nothing. What do i do?
How to get HDMI Connection from Inspiron 546 to LCD HDTV working?
Press the Windows key and the letter "p" at the same time, and select duplicate
Feb 20, 2015 | Dell Inspiron 546 MT PC Desktop
Can't connect my computer to beam the projector
follow the steps and your owner manual read from computer or proyector download from www.fitness.manualsonline.com or www.retrevo.com
However you must use THE key FN for setup the proyector in your computer.
God bless you
Oct 28, 2013 | Sanyo Office Equipment & Supplies
I have a samsung syncmaster 940mw and i am trying to connect my laptop to it but the menu for the pc input is greyed out, can you help
Make sure that under display properties in your computer, that the laptop is outputting an image. The PC option will not show up unless there is a signal to the monitor from the laptop.
Mar 09, 2011 | Samsung SyncMaster 940MW 19" LCD Monitor
I have a IBM thinkpad i was trying to put The resolution screen big to watch in The proyector now it went black And nothing come to The projector i want to come to The regular standar
try starting in safemode. while the computer is starting press the F8 key to enter advanced startup screen. must be pressed before windows startup screen is displayed
Nov 06, 2010 | IBM ThinkPad R40 Notebook
Note Book no able to pass Image throgh pojector to screen
Hi brkhera. Did you try using FN + F5(twice)? (or maybe F6) after you connected the proyector? you will see either the same thing on both displays or nothing on the laptop and just the external monitor (depending on how many times you do it).In case you have a presentation using Powerpoint, first you need to make sure you have the video drivers installed (on laptops you'll have 2 - one for the laptop and the other one for the external display under Device Manager - if you have not reinstalled the OS this is not an issue) then if you do, you have to go to start - control panel - display - configuration tab and you will see the 2 monitors, one is the laptop and number 2 would be the proyector. Then you have to click on "extend windows desktop to this monitor" and that's it. Then on Power point you have to configure your presentation to display on the 2nd monitor and that's it. I hope this helps. Please don't forget to rate and write positive feedback for our fast-free support today. Thank you :D
Apr 30, 2010 | Acer Aspire One PC Notebook
Screen is black and power button gone amber colour.if you press buttons on monitor it says,in power safe mode press any key or move mouse. when you do this nothing happens
Restart the computer and turn off power save mode. If this is vista the power save mode has a lot of problems and can cause things like this to happen.
Sep 07, 2009 | Dell E173FP 17" LCD Flat Panel Monitor
¡S.O.S.! necesito manual de servicio Proyector Mitsubishi XL30U
you can try mitsubishi themselves, but from experience, they don't give out anything.
May 19, 2009 | Office Equipment & Supplies
Can't download images from Canon SD1100 to computer
Hi and welcome to FixYa.
Sounds like your reading right from the manual. <grin>
Try this.
Connect the camera to the computer via the usb cable. Set the mode switch to playback and press the power button, then:
on your pc go to Start>All Programs (or Programs)>Canon Utilities and find Canon Window. Double click on it and it should fire the program. Let me know if you have any problems. If not, feel free to rate my solution.
Rob
Mar 04, 2009 | Canon PowerShot SD1100 IS Digital Camera
I can not instal a proxima proyector
Does this give you an error message?
Usually when installing projectors, it's basically "plug and display", just check your Display settings and see if you can choose to either use the projector as the main monitor or extend the monitor image to the projector.
Aug 23, 2008 | Computers & Internet
Upload fotos
Here's how...
  • Starting PC mode
If you connect the USB cable to a USB port on your PC and then turn on the power, the camera will automatically switch to "computer connection mode".
In this mode, you can download stored images to your PC through the USB cable.
The LCD monitor on the camera is always turned off in PC mode.
  • Connecting the camera to a PC
1. In any mode, except Voice Recording mode, press the Menu button.
2. Press the LEFT/ RIGHT button and select the 'SETUP' menu tab.
3. Select the 'USB' menu by pressing the UP/DOWN button and press the RIGHT button.
4. Use the UP and DOWN buttons to select 'Computer', and then press the OK button.
5. Press the menu button twice and the menu will disappear.
6. Connect the PC to the camera with the USB cable.
  • Downloading stored images
You can download the still images stored on the camera to your PC's hard disk and print them or use a photo editing software to edit them.
1. Connect the camera to your PC with the USB cable.
2. On your computer's desktop display, select 'My Computer' and double click 'Removable Disk' - 'DCIM' - '100SSCAM'.
3. Select an image and press the right mouse button.
4. A pop-up menu will open.
Click the 'Cut' or 'Copy' menu.
- 'Cut' : cuts (i.e. moves) a selected file.
- 'Copy' : copies files.
5. Click a folder where you want to store the file on your PC.
Don't forget to rate this solution once you've tried it !
Good Luck.
May 20, 2008 | Samsung NV3 Digital Camera
InFocus X3 DLP Projector Logo
23 people viewed this question
Top InFocus Office Equipment & Supplies Experts
Electro Med Services...
color wheel light...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
