Question about LG Refrigerators
Just changed my filter ant the water coming out is kinda black. it was fine before??
  • 316 Answers
This is completely normal. It is very common for new filters to due this. What you are seeing is the charcoal dust being rinsed through the filter, charcoal is what the filter uses to clean the water. You will see in the packaging is a recommendation to rinse about two gallons of water through a new filter to "wash" it.
Posted on Nov 09, 2010
  • 4,793 Answers
Because the new filter has allowed more water to flow it has shifted the black moss from the lines.just let it run for awhile,it wont do you any harm.....
Black water pours out of the heater system into intex spa
Backwash filter system, change filter media if over two years old, flush out heater. Check water clarity going into the filter system, if dirty..., you may have a broken underground line. Check water clarity coming out of filter system, if dirty.., backwash again and check filter media. Also, Heater boiler headers may be rotting.
Apr 10, 2016 | Intex Pool & Spa
Projection TV. DVD works. Cable often seems, "untuned". Static & un-fine-tuned sound of channel with black screen. Then, later, it will come on just fine. Sometimes, will go back to untuned status.
I would suspect your cable box first. I would unplug the power cable from your cable box and wait 60 seconds. Plug it back in and try to watch cable tv. I would also make sure the coaxial cable going from the wall to your cable box is connected properly. I would also make sure the cable going from the cable box to the tv is connected properly. Test your tv and see if it works correctly when you watch cable. If this fixes the issue you are good to go.
  • If this makes no difference use a set of new cables if you have them.
  • If this does not work then call your cable company. They may have to replace your cable box.
May 25, 2015 | Televison & Video
I replaced my GE profile MWF water filter (identical GE part) and now I dont have water dispensing and don't have a working ice maker
Quite frequently carbon fines can be flushed from filter and plug the filter. If you have the bypass plug to replace the filter. Put that in and flush system completely. Take the filter and flush it at the kitchen sink. It is best to fill these with water before installing and flush the carbon fines before installing in fridge.
RJ
Mar 09, 2011 | GE Mwf Ge Refrigerator Smart Water Filter...
1987 jeep wrangler has a nutter bypass and runs rich
did you check the air filter? if the air filter is dirty, the mixture is automatic richer than normal. the ratio between air/fuel is changed.
try this ant let us know.
Apr 12, 2010 | 1987 Jeep Wrangler
My front load washer is not spinning out the water.
Check for lint and coin build up in filter, which is located in the front. Remove bottom panel to check. If water is pumping out and machine is not spinning but still tumbling at low speed, you will probally need a speed control.
Feb 25, 2010 | Frigidaire Affinity ATF7000E Front Load...
I changed the filter for the water dispenser and after purging the water for awhile, the dispenser stopped working. What needs to be done to get the water dispenser to work again
Put the old filter back on , if water was fine . You never change filter just because a light comes on telling you to . The change filter light comes on after time or usage of dispensor .( Good way for manufacturers to make extra money ) . Change the filter only when water flow slows from dispensor .
Aug 13, 2009 | Sub-Zero 690 Side by Side Refrigerator
99 Grand Prix GTP,Changed fuel filter, will idle now, still won't
exactly right, theres trash in the tank. keep changing or cleaning the filter and get the gas out of it. replace with good gas and pick up something at the auto to dry up the water in tank. auto guy should be able to help pick something. hope it helps
Mar 20, 2009 | 1999 Pontiac Grand Am GT
Dirty water line from filter
Attach flexable rubber line from water bottle, like is used for race bicycle riders,or tape up a hose to a water bottle. Turn off valve at water pipe leadign to line to filter. Remove filter. place a pan to catch water under the machine. Attach A small diameter hose to water line where water exits to glass.With machine turned on and your rubber hose attached turn bottle upside down and squeeze while pressign glass lever. Flush through approximate one quare or until water stream is clear. Their is no pumb ofor flow the line preaure is al that moves the water so backflushing is easy.
Dec 14, 2008 | Frigidaire FRS26R4A Side by Side...
"ant A" and "ant B" inputs go black when the tv is first turned on.
Try opening that "Ant A, B" device and apply some fresh solder to all the components inside. Also you can try to by-pass that device using the connector below. One end connects the cable in and the other end connects to the circuitry inside the TV.
Jan 24, 2008 | Mitsubishi VS-60609 60" Rear Projection...
No Picture, sound is all static
Make sure the ant. input switch didnt change and check the ant. connections If that dosent work sounds like a defective tuner.
Mar 30, 2006 | Philips Magnavox 27MS343S 27" TV
Refrigerators Logo
269 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Mike
Mike
deecee73
Level 1 Expert
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
