Question about Char-Broil CharBroil 4637318 Grill
Char-Broil 4637218 Hi--have model 4637218. Cannot figure out how to put the little tank holder brace/bar back in place to hold the tank in place so it doesn't fall off the base of the grill. I need to know where to hook it up. My model looks just like the 4637318. thanks!
5 Suggested Answers
  • 1314 Answers
SOURCE: how to use a smoker
http://www.charbroil.com/charbroilwarranty/ConsumerWebsite/ConsumerHome.aspx look under how can we help you about midway down the page
Posted on Dec 31, 2007
SOURCE: Need instructions for assembly of char-broil gas grill
Need Instructins for Char-Broil Model 4955526
Posted on Jun 08, 2008
SOURCE: Char Broil commercial grill won't heat pass 300 degrees
The new regulators gas grill made to prevent flair ups when lit. Start with just one knob to lite it wait 3 min put on 2nd burner on low. feel the regulator if it is very cold start again after it warms up. if it is just a little cold warm it up by holding it and turn on the last burner
Posted on Jul 08, 2008
SOURCE: instructions on use o;f char broil electric h2o smoker vintage 2000
please send me instructions
Posted on Sep 21, 2008
SOURCE: Char-Broil TEC Infrared Grill the
what do we do about the sputtering tec gas line and no heat on tec burner
Posted on Feb 23, 2009
Char-Broil 463722313 chain
think its a match holder, if the spark doesnt work, you can place a match on it, light it and lower it down to ignite the gas...
hope this helps
Jan 04, 2014 | Char-Broil CharBroil 4637318 Grill
How do I put one together with no instrustions
Harvey, unless you do it every day for a living, it would be pretty challenging. So I g=have provided a link to the Owner's Manual for your Model Char-Broil Grill, that you can download and print for future reference. Keep it in a safe, accessible place. You may need it later to order parts or accessories.
http://www.charbroil.com/bps/char-broil/char-broil/knowledge/80005696.pdf
Hope this helps you. Please let me know and Happy Grilling!!
Jun 18, 2011 | Char-Broil Designer 463261106 Grill
How to install the propane tank
Your correct, the tank should either srand upright in a tank holder or hang from a device buit onto the grill. If you need to improvise, using some paving stones or whatever just make sure you don't pull the gas line.
Apr 26, 2010 | Char-Broil Quickset Traditional 463761006...
How do I set the tank holder bracket for a
there is a slider on the brackett which moves up and down to go over the rim on the top of the bottle
Feb 28, 2010 | Char-Broil CharBroil 4637318 Grill
Want to replace flame guard shield and can holder for drippings
Ok, I am reasonably sure your grill's model number is 463741209. That is Char-Broil Tradition Series 2-burner grill. I am giving you a link to the Char-Broil website that will take you directly to this model number. There are two tabs, one says "Replacement Parts" and the other says "Universal Parts". Under the "Replacement Parts" tab, you can order the "Vaporiser Bar", part no. 80007927 and "Clip F/ Grease Cup", part no. 80000271. From what you've told me, these are the parts you are looking for. You can most likely get them at Lowe's or you can order them online. Here is the link for you: http://www.charbroil.com/Consumer/product_detail_m.aspx?ProductSeriesID=7&Name=Char-Broil+QuickSet
I hope this helps you out!
Oct 21, 2009 | Grilling
I need a manual for Char-broil gas bar-b-que Model # 463420507
Try this web site:
http://www.charbroil.com/bps/char-broil/char-broil/knowledge/463232103.pdf
Dec 31, 2008 | Char-Broil 463232103 Grill
Char-Broil CharBroil 4637318 Grill Logo
115 people viewed this question
Top Char-Broil Grilling Experts
paulcarew
Dean Gruber
Dan Webster
Dan Webster
Are you a Char-Broil Grilling Expert? Answer questions, earn points and help others
