Question about Swisher Zt2560 Zero Turn Radius 60" Riding Mower
Left side goes faster than right side - Swisher Zt2560 Zero Turn Radius 60" Riding Mower
  • jsampey Nov 13, 2010
    The mower is brand new just purchased from Lowe's. Lowe's doesn't have any expertise at
    my home store, Thibodaux, La. Also the left side makes a growling noise. Any more ideas?
  • 643 Answers
Is it a z mower?
Posted on Nov 09, 2010
  • Tre Elkins Nov 09, 2010
    it is the right side hydraulic steering pump, you need to replace it.
  • Tre Elkins Nov 13, 2010
    Just because its brand new doesn't
    mean that its not bad ,could've been from sitting in the store.happens everyday. I would take it back if its brand new.
My Dodge Grand Caravan is making a humming noise as you accelerate, while turning left it stops but gets worse while turning right. I replaced the left front wheel hub and no improvement, I need help
if hub bearing replacement did not fix the noise
when noises are on left and right turns
that has CV joints /drive shafts
would say they are the issue
replace both sides
and replace the left hand hub bearing at the same time
Oct 20, 2016 | Dodge Caravan Cars & Trucks
Left front brake is faster to apply and release than the right causing the van to pull left on a 93 chevrolet G20 van
replace the brake hose that goes to the caliper on that side. Some older hose collapse on the inside and make em slower to release
May 25, 2012 | 1993 Chevrolet G20
Left side flasher blinks faster
B-cox of the bulb connecter..it maybe loose..hope u got ur answer
Dec 03, 2011 | 1990 Nissan 300ZX
The indicator is faster than before
Normally if the indicator is going faster than it has before it is telling you that you have a bulb out on that particular side. if it blinks normal on the right but not the left, then the bulb is out on the left side and visa-versa. This happens because the resistance that the power goes through is no longer through twp bulbs, but only one. So it's cut in half and will make the flasher work twice as fast. Hope this helps.
Dec 29, 2010 | 2003 Toyota Corolla
My right turn indicator is acting up. It is clicking and blinking faster than normal, and faster than the left one. Both the front and rear lights seem to be working, but the front one seems dim. ...
It means you have a bad bulb on the side that flashes faster so turn the key on turn the blinker on and check if there is a light out on that side if there is replace it. If both lights front and back work pull bulbs and make sure the bulb ends are round like this U the bottom of the you goes into the socket first. also sand the socket lightly to see if you have a bad Ground.
Sep 14, 2010 | 1998 Honda Civic
I am pretty sure there is a relay bad on my focus for my signals. the left turn signal flashes faster than the right. Which one do i change?
Howdy,
First look for a burned out bulb on the side that flashes faster. Look carefully. Go to the right side that flashes normal and see how many bulbs flash front side and rear. then turn to left side and look, you may find one bulb burned out.
Good Luck !!!!!!!!!!
May 10, 2010 | 2000 Ford Focus
At low speeds the steering wheel goes left and right by itself. At highway speeds it viabrates
If it's shaking left and right and shakes faster the faster you go i wood say it's slipped belts in the front tires.Hope this helps.
Feb 25, 2010 | 2001 Chrysler Town & Country
My left blinker blinks faster than my right side
One of your blinker lights is burned out. Replace it.
Oct 28, 2009 | 2002 Ford Taurus
Fiering order on coil pack p38 40.l
As you look at the engine - Spark plugs first......on the left side of engine.......front to back.......2, 4, 6, 8 (even right),....2 goes to the left coil...top left.....4 goes to the right coil....top left......6 goes to the right coil...bottom left....8 goes to the left coil....bottom left....NOW....right side......front to back......1, 3, 5, 7 (odd left).....one goes to right coil....bottom right.....three goes to left coil....top right......five goes to left coil....bottom right....and seven goes to right coil....top right....hope it helps
Jan 28, 2009 | 1999 Land Rover Range Rover
Swisher Zt2560 Zero Turn Radius 60" Riding Mower Logo
218 people viewed this question
Top Swisher Garden Experts
Tim Whalen
ray gallant
john milligan
Are you a Swisher Garden Expert? Answer questions, earn points and help others
