Question about Singer Quantum 9910 Computerized Sewing Machine
The light on the computer screen does not light up. the light where the needle is lights up but not the computer screen where the stitch display is.
There is a tiny 'brightness control' under the top cover next to the bobbin winder. Turn it up!
Posted on Dec 13, 2010
Why is the needle unthreading cub 4frister rossman machine
Pull at least 5 inches of thread tail through before taking the first stitch. It also helps to have the needle at its highest point when beginning the first stitch. Hold both thread tails lightly in the left hand while taking the first couple of stitches.
Oct 28, 2017 | Sewing Machines
Blind stitch won't lock
This is hard to find in the internet so I hope this will solve your problem...
Frequently Asked Questions
Q) Help!
I am breaking a lot of needles and the tension is getting too tight on its own while stitching and causing the thread to break. I am learning the machine for two weeks. Is it so sensitive too wools, cottons, and fleece that this would make such a major difference in the stitching - breaking needles, breaking thread?
(A) It may not be tension that is causing the problem with your portable blindstitch. If you have broken needles it has probably left some needle burrs in the thread and needle path that need polishing off with fine emory cloth (crocus) before sewing again.
Start with a new LWx6T needle without thread or fabric. Watch the needle as you turn the hand wheel. If there is needle deflection, reduce the penetration dial until there is no needle movement. If there is needle deflection caused by burrs, they must be polished off. Check the looper tip and two arms for any needle burrs and polish off. If there is needle deflection caused by the needle track lifting the needle, lower the track very slightly with the screws on the side of the black metal bracket above the needle.
Finally, Back off on the tension dial and retighten while you are sewing with a light strong thread and light to medium weight fabric, until you get the correct tension without loops. If tension is too tight it will push the thread up so it is not all the way down between the tension discs where it belongs.
(Q) I can't understand how to finish off at the end. It
always unravels. I have read the manual and it seems simple but I
apparently just "don't get it." Any help would be appreciated.
(A) At the end of the blindhem seam, position the needle all the way to the left, then use the knee lift to remove the fabric and jerk on the fabric at the same time. That will tie off the tread and break the thread at the
needle without bending the needle. You can weave the thread tail back into the stitches or cut it off. Before the above procedure, you could also turn the handwheel counterclockwise for a few stitches, then come back to the end of the seam and repeat the first procedure above.
Nov 15, 2007 | Tacsew T500
Activa 220. freezes up
Sounds like a computer board is failing.
Sep 03, 2017 | Sewing Machines
I have a CS 6000i which I have really appreciated. But now it is skipping stitches - mostly skipping. I have been sewing the same project and it had been sewing fine. What will fix it?
try increasing/decreasing the needle thread tension for the added material thickness
use scrap material until you get it right
Feb 14, 2017 | Sewing Machines
I just broke a needle. I replaced it. Now the machine is not stitching properly. I turned it off and turned it on. All the stitching lights blink. How do I fix it?
You need to change the correct size needles. There are two types of needles. One with cylindrical head and other with cylindrical head with flat surface on one side.
The other problem may be the position of the direction of the thread passing through the needle.
The third problem may be move your needle position one millimeter up or down and tighten it and check.
Please follow through these 3 steps one by one. You can fix the problem
Jan 03, 2015 | Singer 8763 Curvy
The lower stitching on my machine is not consistant, why?
Wrong size needle or wrong type of thread for the weight or type of fabric. For instance, you should use smaller needle size for light weight fabrics.
Jan 15, 2013 | Sewing Machines
I have a Husqvarna 936 huskylock which is about two years old. I have not used it much yet and yesterday I set it up to do a cover stitch for the first time. Since then I have spent hours threading...
For the cover stitch, only use a size 90 needle. Depending on the type of knit, use a ball point or stretch needle. The 936 uses standard sewing machine needles, so you can switch needles with the type of fabric, just like with a sewing machine.
Jun 29, 2011 | Husqvarna Huskylock Computerized 936
Display will not go on
Please refer to the manual or software manual for troubleshooting.
Apr 06, 2010 | PfaFF Creative 7570
Husqvarna designer 1 won't turn on..stitching had messed up and cleared out bundled thread and now screen won't light up.
If there is no noise, like the machine is calibrating or setting up, then more than likely the fuse on the transformer has blown. If the needle motor and feed motor make their usual noise and the lights come on but the screen won't come on, chances are a connection inside the machine is your problem. If the cable from the display screen becomes unplugged, the machine will "start up" but nothing will be displayed on the panel. If when you turn on the machine, you touch the screen and hear the "click" sound the screen makes then its a problem with the display screen only. (there are 2 screens, the one you touch your finger with is the touch screen and the one behind it displaying the picture is the display screen.)
Oct 19, 2009 | Husqvarna Designer I
Singer Quantum 9910 Computerized Sewing Machine Logo
90 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
