Question about Onkyo DX-C340 CD Player
I need a optical lens for a panasonic boombox cd player, model # RD610, and part replacement # S0DD110Z.
    President:
  • 1,932 Answers
You can the replacement part # S0DD110Z from below website
http://www.pasc.panasonic.com/
Click on order parts and accessories,Then it open another page.Enter the part number it will ask to add to cart then you can order it.
Thank You
Posted on Nov 10, 2010
Cd player won'start
try cleaning the optics with a soft cloth or Q-tip and isopropyl alcohol(just a drop!!!!) start it again....otherwise replace pickup..... regards, meder's tv service
Aug 15, 2012 | Panasonic RX-D11 Cassette/CD Boombox
My Sony CFD-S33 CD player has started only playing 10 min of each CD
Clean the optical pickup lens, by inserting a lens cleaning disc into the player. If it do not help you, repalce the optical pickup unit. Sony sets will have special type optical picku units. You might have to contact the authorised service center for Sony at your town, to get an original one.
May 22, 2012 | Sony Cfd-s33 Cd Cassette Recorder Am Fm...
CD Player does not turn
how long have you been using this player and when did this begin?
Remove the disc and try another. If the player refuses to eject the disc, remove it from the wall and fix it back and fix it back again. Then turn the player on.
If the player still gets stuck on "loading" mode for other disc, then it means the laser is weak.
The lens is weak such that it cannot load data on discs. Its spinning, trying to load, but can't because of the weak laser.
Get a lens cleaner, use it to clean the lens. If that doesn't solve the problem, get a screw driver, open the player's cover so that you can gain access to the lens, use a cotton board to clean the surface of the lens. This should clean dust or dirt that might be on the lens.
If non of the above solves the problem, then know that you need to replace the laser to a brand new one.
To replace the lens, remove the bad laser, use it as a sample to get exactly the same type and do the replacement. Note that replacing a laser (lens) needs a professional touch, so if you cannot replace the laser, get it to a repairman to fix it for you.
Once this us done, your player will play all discs again.
Regards.
Jan 10, 2012 | Panasonic RX-D15 Cassette/CD Boombox
CD player freezes on certain tracks. My only way to stop it is to push the advance arrow to go to the next track It seems to happen on every CD I play.
try to clean your optical lens, by a cotton badge and put some oil on moving parts. if ended you need to replace optical assembly. or try to re align potentiometer that control the focus of the lens.
Apr 10, 2010 | Philips Magnavox MCS225 17...
Wont read any cds
Try cleaning the optics lens using a cotton swab and alcohol. If that does not resolve the problem, the optics have failed and will need to be replaced. If I remember these units correctly, they use Sony optics assemblies that are readily available for around $20-$35.
Dan
Oct 27, 2009 | Bosch PB10-CD Radio/CD Boombox
My cfd-510 radio wont play cd's how can i fix it? everytime I try to play a cd it atempts to but can't
Open up the top and try cleaning the lens using a cotton swab and alcohol. If that fails to resolve the problem, then the optics need to be replaced. These units use KSS-150 optics, I think. These are still available (or a substitute) for around $20 for the part.
Dan
Sep 18, 2009 | Sony Boom Box With CD Player & Cassette...
My RCA RCD160 Radio/CD playder will not play CDs.
Try cleaning the lens in the CD player with a cotton swab and alcohol. If that does not resolve the problem, it is likely that the optics are defective and need to be replaced.
Dan
Mar 25, 2009 | RCA RCD160 Radio/CD Boombox
Aiwa CSD TD310- manufactured 2001 - looks like this(above)1)Problem getting cd to work; 2)need help with "sleep" button:how to set
Well, for the CSD-ED27 the sleep works like this:
1. press STOP/MEMORY and then also
2. press PREPEAT/FM MODE/OSC
3. your display will show 10
4. use the tuner - & + to good from OFF-90 mins
As to you CD player not playing:
it is sounds like the spinner might be not spin completely flat to the optical reader. This happen with my portable CD player, however at this time I do not have a fix for you. Good luck though.
Mar 20, 2008 | Aiwa CSD-ED27 Boombox
Error Code F26
Here is the link to the user manual if you need it; http://service.us.panasonic.com/OPERMANPDF/RXED707.PDF although of course it doesn't list that error code and panasonic no longer support the model on their site except for the user manual. If you don't mind paying $19.50, then these guys have the service manual available which almost certainly will list the error codes and their solutions; https://www.manualsparadise.com/ShowProductsForModel.do?model=M91217722 Sorry I had no luck finding that one for free. My guess is that the lens needs cleaning, and that the error code simply means "bad disc" or something similar. Best way to clean the lens is with a cotton bud/ Q-Tip moistened (not wet) with gin - nothing else works as well or as safely. This should be easy to do as you have direct access to the lens, just be gentle. If you get no luck from that then the best i can suggest is to contact panasonic direct; http://www.panasonic.com/support/ and see if they can tell you what the code means, if they do, and you need help solving the problem, please ask again. Good luck, I hope this helps
Jun 23, 2007 | Panasonic RX-ED707 Boombox
Optical unit for RXD25
i got a website you can go to to find that info "www.partsstore.com"
Apr 16, 2007 | Panasonic RXD25 Cassette/CD Boombox
Onkyo DX-C340 CD Player Logo
85 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
