4.6 L V Northstar engine problem. (Idle is rough (but not extreme). Changed spark plugs and it got a little better. Idles at 675 R.P.M. No problem with acceleration. Upon slowing down I feel the engine rough idle the most. My local Mechanic sad I need to change the coil packs. Hard to believe that though. Also changed coil boots (spark plug wires). Added an injector cleaner but no change. Diagnostic tool (OBDII) revealed cylinders #1 and #2 are running too lean? Of course the engine service light is on. Any suggestions?
  • Gene May 12, 2017
    Hi Robert H Danelson, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? You may have partially blocked injectors on 1 and 2 cylinders.
Big Poppa Ma
  • 302 Answers
SOURCE: Check engine light on
There are three kinds of gasoline engine misfire scenarios, first there is the "under load" misfire and there is the "at engine idle" misfire, and finally there is misfire continuously. All engine misfires exist because one of three things has occurred. First, a cylinder has lost compression, a cylinder needs a certain amount of compression to operate correctly. Second, the ignition system has failed or is failing intermittently, spark is needed at the time of compression to ignite the fuel air mixture. Third, the fuel air mixture is incorrect, proper mixture is needed for the ignition system to ignite fuel properly. If any of these conditions occur in the engine, the engine will misfire.
1. Low or no compression can be caused by
a. burned or leaking intake or exhaust valves
b. worn or broken piston or piston rings
c. worn out camshaft
d. wrong weight motor oil was installed holding the cam followers from adjusting
e. broken valve spring
f. failed head gasket.
2. Ignition system has failed or is failing
a. spark plug has fouled or is worn out
b. ignition coil
has failed
c. spark plug wires have shorted
e. engine control module coil driver has failed
3. Fuel/Air Mixture is incorrect
a. vacuum leak at the intake manifold
b. fuel injector has failed
c. EGR valve is stuck open
d. mass air flow sensor has failed
e. oxygen sensor has failed
f. air intake boot is cracked
common problems:
1. fuel injector has failed or is failing
2. spark plug wire has shorted
3. spark plug is worn out or is cracked
4. ignition coil has failed is failing
Testing a coil on the car is pretty easy. No special tools are required. Just remember to be careful, the amount of electricity generated by your ignition system can be dangerous. If your coil is already off the car, or if you would like a more specific data-driven test, you can bench test your coil. To set up the test, remove one spark plug wire from its plug, then remove the spark plug using a spark plug socket. Next put the spark plug back into the spark plug wire. Be careful not to let anything drop into the empty spark plug hole -- very bad.
Posted on Dec 07, 2008
  • 99 Answers
SOURCE: Check engine light comes on. p0171 and p0351 codes found
From Lusty Kid:
I know the economy is bad, but change all of the plugs. Check your PCV Valve hose, 150 rottens them out allowing air to be sucked in, thus all kinds of codes.
Depending on mileage. Dismount the EGR valve and clean passages. If you are really good dismount the throtle position sensor body and clean out passages with Choke Cleaner., dismount where the EGR valves connects to the engine, clean out passages. Also check the hose thats behind this mounting to ensure is not clogged. If clogged clean it out. If not replace it. Is about 1.5 ft. long, connects to the PCV Valve Hose.
When is the last time you change your harness. Can't remember??? Replace it. Good Luck
Posted on Dec 26, 2008
  • 14036 Answers
SOURCE: loss of power on acceleration. engine bucking.
check transmission fluid.change fuel filter and air filter.try changing up on where you buy gas .because bad gas causes problems.
Posted on Jun 26, 2009
  • 25 Answers
SOURCE: I own a 2002 Chevy Trailblazer with 4200 vortec
Do you know if the plugs were changed, a bad or broken plug will also cause rough idle and slow acceleration?
Posted on Oct 21, 2009
webmaster21
  • 803 Answers
SOURCE: rover mower has a spark but won,t even kick over
As for all of us as Experts at Fixya. We would greatly appreciate if you would place your question in the right category so that an Expert with knowledge of this field can provide you with help. Sorry that I could not be of more assistants. I will inform other experts in this field of your issues so that they can redirect to help you. Thank you for using Fixya.~WEBMASTER21
Posted on Dec 08, 2009
Why does my 98 Hyundai Excel have problem engine problems
have the fault codes read and save money on unnecessary replacement of parts . The codes will reveal what the problem is.
Jul 25, 2014 | Hyundai Excel Cars & Trucks
Rough idle on pontiac grand am
pull the air intake hose off the throttle plate, you will find a lot of black carbor around the throttle plate causing idle concerns. clean this with a intake system cleaner. this will smooth out the 2.4 liter quite a bit
Aug 06, 2012 | Pontiac Grand Am Cars & Trucks
U i have a 97 ford escort that idles rough so i replaced the wires and plugs it still idles rough but runs a little better the coil shows spark on all cylinders any ideas
Often, on the Escorts of this vintage, rough idle can be due to a leak in the vacuum system. With the engine running, listen closely for any tell-tale hissing sounds coming from any of the vacuum hoses. Check that they are all securely in place and the end-clamps are all tight. Also check that the PCV valve and the hose connecting it to the manifold are securely in place. Another possibility is the Idle Air Control (IAC) valve. If it is clogged or sticking, it can cause rough idle. Refer to a service manual to diagnose the IAC valve. Other things to check: make sure that the air intake is unobstructed and clean. You might consider cleaning the manifold and throttle body. Check the air filter and replace if necessary. Let me know if you have any other questions.
Apr 02, 2010 | 1997 Ford Escort
Spark problem
maybe when you are pulling the wire just a little you are making a better connection, make sure your wires are all in good shape, it may be just loose
Nov 20, 2008 | 1989 Honda CBX 750 F
Spark problem
Nov 20, 2008 | 2008 Husqvarna TE 510
Spark problem
Nov 20, 2008 | 1989 kawasaki KR-1
Spark problem
Nov 20, 2008 | 2006 Suzuki SV 400
Spark problem
Nov 20, 2008 | 1989 Suzuki Rg 400
Spark problem
Nov 20, 2008 | 1975 kawasaki Z1B
Computers & Internet Logo
294 people viewed this question
David Payne
David Payne
