Question about GE (PSS26MSRSS) Side by Side Refrigerator
Hello, I have a GE Prolife side by side refrigerator PSF26PGSA BB and I notice that the refrigerator side has ice build up on the back wall of it in the inside. Can you please help, could it be the temperature sensors or could it be the Defrost Heater & Bracket Assembly? Because I do not see any defrost heater sensor where the coils are inside of the refrigerator when the cover is removed.
  • 316 Answers
Where exactly on the back wall of the fresh food compartment(refrigerator) is this ice build up? If its building up in the air vents, that usually indicates a warm air leak, and this additional warm air is creating condensation, read ice, where it meets the colder air. There is no defrost heater or sensor in the refrigerator, all the cooling components that need to be inside the cabinet are located in the freezer. To check for warm air leaks, check to see that your light switch turns the light(s) off, check that the door actuates the switch when its closed, you will have to close door and squeeze part of the gasket to see if the light stays on. Furthermore, check the door gasket itself, make sure there are no gaps, rips or other malformations. Check that the bottom part of the gasket is not sagging, or the hinge side corners are not bunched up, or stretched out from the corners. Also, let the door close by itself like normal, and check the lower portion of the non hinge side of the gasket, if there is a gap here, further check for scratches on the bottom inside liner, not the door, inside the bottom of the fresh food compartment. If there are scratches here, this indicates the door is rubbing on the bottom because its too low, indicating a problem in the lower door hinge area. You dont mention any refrigerator freezer temperature problems, so it does not sound like a defrost problem or an issue with an evaporator fan motor failure.
Posted on Nov 09, 2010
I have a GE Artica PSF26PGSA BB side by side refrigerator. Water collects in the bottom and runs out on to the floor. Any suggested solutions?
Clean it. You probably have a large dust collection in, under and on your units underbelly.
You should have a collection pan, underneith, that collects the runoff water and the heat from the componits will evaporate it before it fills too much.
You could also have a leak in the plumbing system that supplys your ice maker. When your valve opens, you should be ready with a flash light inorder to watch for any drips underneith the unit.
Could be a simple fix of just tightening up a bolt, or could be a repairman issue.
Good luck.
Mar 11, 2014 | GE (PSS26MSRSS) Side by Side Refrigerator
GE GSS25WTGA BB
This could be a dozen different things causing this. Do you see ice build up on the back wall? Your freezer coil could be icing over and blocking fan air flow. This can be due to a bad fan, low freon.....
Oct 12, 2013 | GE Refrigerators
Freezer is not working. Ice maker is working. Started noticing the past 2 weeks that ice cream is melting. Refrigerator is working but not keeping things really cold. The unit is only 3 years old.
ice mker will soon quit as when ice cream is soft the tempt is rising . look for frost build up in back wall of freezer . if so the heaters have failed ( very common ) . they will have to be replaced . there is a new style that replaces mose G E heaters . and they are much better .. mm
Jul 29, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
We have replaced our G.E. side by side refrigerator mother board ,it did fix the problem with the ice maker and water not working ,a week later ,the ice started to build up agian and fridge is not getting...
The bdefrost heater behind the wall inside the freezer is bad if the ice you have is on the back wall of the freezer. Remove the back wall and deice the coils and replace heater. wr51x10101
May 25, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
We cannot find the drain in our GE side by side fridge freezer. Their is ice accummulating on the floor of the freezer side and although we think this may be due to a blocked drain - we cannot find it !!...
Pull unit away from wall, take panel off the back so that you can see the compressor. You will find a pan close to the compressor. The drain drains into this pan. You can take a turkey baster, fill it with water. Blow the water into the drain. This will unclog the drain.
Note.
If ice is building up on the inside lower back wall of the freezer, you have a defrost problem. If so it most likely will be the heaters behind the inside lower back panel. They are easy to replace. You can find them at www.partselect.com . You will need to enter your model number (without the spaces and also without the BB at the end) this will bring up a break down of your unit. You will not only be able to order the part, you will also be able to see where they are located inside the unit.
Oct 13, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE 24 Profile refrigerator: The freezer part
my refrigerator goes into auto defrost every 60hrs for 45 minutes or till the bi metal(defrost thermostat) says it had enough....recently i had ice built up on the coil because my defrost thermostat was stuck open...
ice builds up because the moisture that comes from opening the door or food condenses on the cold coil...tempurature of the coil is below 32 degrees which will ice up the condensed moisture...
defrost is timed to remove this build up
Oct 01, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Warm frig and cold freezer
usualy a defrost problem check for ice on back wall in freezer thats most common problem check for ice on wall in freezer ice build up is due to defrost system failure
Aug 17, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE side by side not working
Defrost cycle not functioning. Could be defrost timer, timer motor, or defrost heater. I detailed this for someone else. see other solutions.
Nov 05, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice build-up in back of freezer
you probly got a water inlet spout froze over.. take out ice maker and look where water inters icemaker and see i that is froze
Aug 23, 2007 | GE GSH25JSTSS Stainless Steel Side by Side...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
159 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
