Question about Refrigerators
Not cooling, works intermittently. - Refrigerators
  • 316 Answers
If you would like free help, the more information you can provide us with, the better and more accurate a solution we can provide you with. How is it not cooling? anywhere, either side, everywhere, one area? works intermittently how? cooling intermittently, running intermittently? Does it make any unusual noises? dose it make any noise?
Posted on Nov 09, 2010
My Camry speedometer is intermittent
speed sensor could be going bad
May 29, 2012 | 1997 Toyota Camry
How do you replace the relay on the cooling fan---fan is not working and fuse is good
it may not be the relay but the cooling fan itself failing intermittently, I had the same
problem with an 04 PT cruzer and the fan was intermittently failing (if the fan has an open frame on the motor water gets into the motor). I replaced the relay with no success
(located in the engine compartment as yours will most likely be). Once I replaced the
fan itself, the problem went away and the A/C functioned much better. Hope this helps.
Jun 25, 2011 | 2006 Acura RSX
Freezer is working, refrigerator is not chilled, fan runs intermittently. Frost is starting to form on the back wall of the freezer. I vacuumed the coils.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
May 18, 2011 | Refrigerators
Left turn signal works only intermittently
turn flashers on...do the lights both flash? when you select left position does the turn indicator show that it is on...just not flashing? then clean up sockets and inspect/replace bulbs...sometimes i just find loose and dirty connections. But a marginal bulb will cause this problem also..works good for awhile when car is cool, but after it get hot then it gets intermittent.
May 02, 2010 | 2001 Jeep Grand Cherokee
Why does the Air Conditioning work sometimes and sometimes not?
I would replace the AC low pressure cycling switch, this is the most common cause of your problem.
Jun 23, 2008 | 1995 Chrysler Cirrus
Fan on laptop intermittent Avent 7110
That can be normal. Normally cpu fans start up only when cpu reach a determined temperature. After it cools down it stops until temperature reaches starting point again.
Generally, when the fan is not working properly, the computer turns itself off after a while because of overheating.
If you have this problem, laptop turning itself off because of overheating (check it is not hibernating etc.), then you usually solve it by replacing the laptop cooling fan.
Generally, 'fan on laptop intermittent' is not a symptom of malfunction.
Apr 25, 2008 | Computers & Internet
Refrigerators Logo
104 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
