Question about A & A Manufacturing Toledo Scale Circuit Board Controller A14849200a
How to calibrate toledo model # 2181 scale - A & A Manufacturing Toledo Scale Circuit Board Controller A14849200a
What does the triple e error code on a Mettler Toledo scale
ive seen this before on my scale (don't know your model number??), seems the cable to the bottom platform was damaged , the guy said it was reading disconnected . ?? he replaced the entire lower part and it worked well again , found out later my temp hit it with a pallet lift , so that's how it got damaged .
Feb 02, 2017 | Mettler Health & Beauty
How do you calibrate, it's a body fat scale, can't find model #?
It's important to find the model number to be able to find the correct manual. Below is a link to FAQ's about Taylor body fat scales.
If you do a google search for "taylor body fat scale" you will see a list of a few models. Examine each to see if one of them is the same as yours.
Taylor USA FAQs Scales
Searches related to Taylor body fat scale model number location
taylor body fat scale model 5741 manual
taylor body fat scale model 5761bf
taylor body fat scale model 5731f reviews
taylor body fat scale accuracy
taylor body fat scale 5731 review
taylor body fat scale athlete mode
taylor body fat scale readings
taylor body fat scale5758f manual
Aug 01, 2014 | Taylor Health & Beauty
Battery code for Salter kitchen scale Model 6055
i needs manuals of calibration of the scale salter model 6055
Aug 23, 2011 | Salter 2001 electronic kitchen scale
When I check my scale with 100lb weight it reads 100 kg or 220 lbs??
you need to turn the calibration setting to 100 lbs, then it will be calibrated
Mar 17, 2011 | Detecto Model 6855 Bariatric Scale
Where can I find a user's manual for a Toledo Scale meat slicer, model#5401?
looking as well for sharpening stone for model 5400-0-001
Oct 22, 2010 | Microwave Ovens
I have an old toledo electronic scale that I need to reset? This is an old electronic scale and it is flashing 0000. The name on the machine is Toledo Sentinel III model 8420
To Whom It May Concern:
I have access to the same model you mention in your post. It was handed to me for repair and I did my best to track down a schematic for Toledo Scale model 8420. Coincidentally I happen to work in the same neighborhood that Mettler-Toledo is located and getting to their CSR was easy. Bad news is this same CSR who is what we in the industry call a "Lifer" didn't have any of the service documentation for this 25+ year-old scale.
Good news is I made a request to the original owner not to throw out the scale once I returned it. If you are interested in buying the scale "as-is" and salvaging the parts needed to solve your reset and 0000 problem, this may be your best opportunity. I don't know as of this writing what the original owner, a restaurateur, will ask for the scale but estimate it won't be much. These scales are industrial strength and this particular one is in great cosmetic condition.
Because I am new to Fixya and don't have the patience to set up an account presently, you will have to post your reply as you did for your initial question. I will check the site in a couple of days to see what has transpired and go from there.
Best regards,
Chris
Oct 19, 2009 | Kitchen Appliances - Others
Scale displays OUT2
you need just to recalibrate it:
The procedure is standard for semi-all models of pocket scales, but the way how to get to calibration mode differs from model to model (or vendor to vendor).
In brief:
1.While turn-on get to the calibration mode (by pressing and holding the ON button, or holding TARE while turinig on) You should hold this "magic" combination until the LCD will show a number (large number - it was more than 2000 in my case). This number is a raw data from the sensor.
2.Now release the "magic" button.
3.Press it one more time, the display will show 2Ero and then 100.0
4.Now put calibrated weight of 100 grams on the scale and wait 3 seconds.
5.Press "magic" button again.The display will show CAL and then PASS.
6.Now remove the weight and turn off the scale.
7.Thats all - now you can use your scale as usually.
Jul 26, 2009 | DigiWeigh 100 X 0.01 Gram Digital Jewelry...
How to calibrate a Pelouze model 4010 scale with a
when i turn on my 4010.the screen display shows 4010 but thats all it does.any solution.
Jul 08, 2009 | RTO Pelouze Scale With Remote Display -...
A & A Manufacturing Toledo Scale Circuit Board Controller A14849200a Logo
243 people viewed this question
Top A & A Manufacturing Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you an A & A Manufacturing Measuring Tool and Sensor Expert? Answer questions, earn points and help others
