Question about Craftsman Air Tools & Compressors
Need a new pressure switch for Craftsman model 919152920 compressor, but that part is no longer available. The switch doesn't function to even turn on the compressor.
    President:
  • Craftsman Master
  • 1,400 Answers
You can purchase a generic/ universal pressure switch from www.grainger.com or ebay. Just look for the correct fittings and pressure cutout. Cost about $20. Before you order a new switch you should test that motor and pump are ok. Jump the wires on the pressure switch temporarily so line-in is connected to motor line. When you connect cord to wall plug the compessor should start and begin to fill. If function ok then order switch. If the motor does not start, may not be switch. Good luck
Posted on Nov 09, 2010
Testimonial: "Thank you. I'm sure that will work as the pump and motor are fine."
  • KERRY MCMAHON Jun 16, 2011
    How do you addapt a different switch when it is bolted down with 4 bolts and a sized diafram below it. When you disassemble the switch it comes appart in pieces and is difficult to reassemble.
I have a Craftsman compressor Model # 919-15292 2. The compressor stopped building pressure because air was continually being released through the unloader valve. I have replaced the unloader valve,...
you must have wired the new pressure switch incorrectly .when the pressure switch opens it will release the head pressure so your compressor must be running with the pressure switch contacts open should be 4 connections 2 marked motor which is from your compressor and 2 marked line which is your power coming in
Jun 15, 2011 | Craftsman 33 gal Air Compressor 6 hp...
CRAFTSMAN Air compressor Model: 919167450. IT'S GOT A LEAK" SO FAR SEEMS LIKE AIR ESCAPING AT CONNECTION OF COMPRESSOR TO TANK. THE COMPRESSOR THEREFORE DOESN'T SHUT OFF COZ PRESSURE LIMIT(PSI) IS...
Manual:
http://www.managemylife.com/mmh/owner_manuals/8336/CRAFTSMAN-Air-compressor-L0809089
Schematics:
http://www.searspartsdirect.com/partsdirect/partsdirect/showSubComp.pd?imageUrl=http%3a%2f%2fc.searspartsdirect.com%2flis_png%2fPLDM%2fP0040151-00001.png
Parts ordering:
http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Air-compressor-Parts/Model-919167450/0247/0703000/P0040151/00001?blt=06&prst=&shdMod=
Jan 08, 2011 | Craftsman Air Tools & Compressors
I have a craftsman professional twin cylinder 240 volt air compressor model #919.184191. It has a tube running from the tank to the switch and it is blowing air out where the tube connects to the switch....
Leaking in-tank check valve will cause air to continually leak out of unloader valve at pressure switch. Remove brass/steel fitting at tank and check seat for debris or replace as needed. You can use generic valve just watch fitting sizes. Available at www.grainger.com. Good luck
Sep 29, 2010 | Craftsman Air Tools & Compressors
I have a Craftsman air compressor twin cylinder, 2 hp, 20 gal. 220v. Model #106.154781. No operators manual. Problem is that when filling the tank the automatic shut-off no longer works and it must be...
Go to: www.searsparts.com
The pressure control switch which the compressor usually pumps into and is mounted on the tank, contains a backflow check valve, the pressure regulator switch, and a compressor pressure release valve. It's probably available only as a complete unit. The pressure switch itself is usually a microswitch that can be obtained locally at a hardware or appliance parts house. Make sure that the pressure switch adjustment hasn't been set higher than the compressor can reach. If you remove the cover, you can watch for mechanical movement at the switch when it is supposed to shut off. Don't poke at anything in there with metal tools--220 volts will give you a lethal shock!
Oct 30, 2009 | Air Tools & Compressors
I broke the red on off switch, on my preasure switch
IF YOUR TALKING ABOUT THE ON/OFF SWITCH ON YOUR PRESSURE SWITCH JUST REPLACE THE PRESSURE SWITCH WITH A NEW ONE FROM ANYWHERE - ONE THAT HAS THE SWITCH ON THE SIDE. TAKE YOUR OLD PRESSURE SWITCH WITH YOU TO MATCH IT. IF IT HAS SOME FANCY SWITCH MADE INTO THE COVER YOU CAN ADD THE PRESSURE SWITCH WITH THE SWITCH ON THE SIDE OR JUST BYPASS IT ALL TOGETHER. IT DOESNT EVEN HAVE TO BE THERE, THE COMPRESSOR WILL SHUT OFF AT CUTOFF PSI ANYWAY AND YOU COULD UNPLUG IT TO KEEP IT FROM RUNNING WHEN YOUR NOT USING IT. THE PRESSURE SWITCH W/ ON/OFF ON THE SIDE IS VERY AVAILABLE. HOPE THIS HELPS, JODY
Apr 08, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Craftsman compressor won't cycle off
Hi, First, I think the cutoff pressure is 135psi and there is an overpressure valve so let it run a little longer. I don't know exactly which model you have ( some of these were oil less) but if it is running longer than you remember, be sure to check the oil if necessary, make sure you are not using a long extension as this will cause the motor to slow down and definitely check to make sure the water is drained and the drain petcock is closed all the way. Also check it without an air hose attached. Good Luck!
Feb 14, 2009 | Craftsman Air Tools & Compressors
Craftsman 25 gallon compressor wont cut off
The pressure switch has snap action contacts that are opened by a diaphragm pushing against a spring mechanism. Unplug the compressor and remove the cover to the switch and look for the contacts. Make sure that they are not welded together from use. Move the on/off lever to see if they open and close. You may have welded contacts or broken mechanism within switch. A factory replacement is expensive, however if you are a tinker-er you can use a lower price generic pressure switch available on ebay. Switches are sold by pressure range, you need a 120#. Fittings may need tweaking. Enjoy
Dec 11, 2008 | Craftsman Air Tools & Compressors
Craftsman 6hp / 60gal air compressor
Does this trip on pressure or is it a breaker tripping? If you took off the intake then there is no pressure build up, thus it wouldn't trip the pressure switch. But would at the same time add a load to the motor. First check and make sure motor is wired properly, then check that pressure switch is wired properly and is adjusted to the right pressure. I don't believe that the intake tube would be clogged, it's a straight hole into the tank. But could be a possibility.
Oct 23, 2008 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Air Tools & Compressors Logo
713 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Craig Butler
Craig Butler
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
