Question about Refrigerators
I have a kenmore elite bottom freezer refrigerator (trio). When the freezer door is closed a rapid clicking/grinding noise has started. When I open the door, it stops. When I close the light switch at the top of the freezer, the noise starts again
  • 316 Answers
I've heard similar refrigerator noises like yours before. Sounds like the evaporator fan motor, located in the freezer and runs only when the door is closed, is being obstructed, possibly by ice, possibly by some wiring or even a food item. You could have a defrost problem, but you dont mention any refrigerator or freezer temperature problem, so that is likely not it. It is also possible the evaporator fan motor itself is out of balance. If you remove the back wall of the freezer, you will be able to see if there is something obstructing the fan blade, if the motor or shaft is out of balance, when you close the door light switch, check the balance of the shaft, it should not have any wobble at all, in fact, if the fan blade is not attached, you should not be able to tell by looking at the motor shaft if the motor is running or not. Also, just happened to think, if one of the fan blades is even partially broken off, that will cause the motor to be out of balance. But if one of these blades is broken, it was broken by something else, either ice or something, and you may have to find the cause of that, otherwise it may happen again.
Posted on Nov 09, 2010
How do I take KENMORE ELITE TRIO 596.75533400 out of demo mode?
Try pressing ultra ice and home while the refrigerator door is opened,or ultra ice and the refrigerator pad with the freezer opened. Hold for five seconds. Hope that works.
Jun 12, 2014 | Kenmore 22 cu. ft. TRIO French Door Bottom...
Both freezer and fridge just stopped cooling. The lights come on when the doors are open and it sounds as if it's trying to run, but no cooling.
The problem can be temperature not set properly or any of fridge or freezer door not closed properly and cool air is getting leaked out. This are basic possibilities which first needs to be checked. But if this possibilities are checked ok and still the problem is same, then its weak compressor issue. Click the link below for more details:--- http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
This will help. Thanks.Helpmech.
Aug 07, 2011 | Kenmore Elite TRIO® 7854 (25 cu ft) Bottom...
Kenmore/Elite Model 795.7756,7757 Trio: Bottom Freezer Door won't close. The latch or hook at the bottom corner of each side will not hook in.
We have a kenmore elite refrigerator modle number- 795 7756,7757 and it has been making a humming noise very constant now after two weeks, what could it be?
Sep 18, 2010 | Kenmore 77554 / 77543 Bottom Freezer...
Fridge is hot, freezer is working properly
The temp control damper solenoid is frozen closed - or the solenoid itself is failed.
CLICK HERE
for the part
#13 in THIS DIAGRAM
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 17, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Freezer quit working on '04 Kenmore Trio Elite 25' bottom
Can either be starting components for compressor, or Motherboard.
May 04, 2009 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
Kenmore elite trio 596.76539500 control panel says OFF.
On a Kenmore Trio 78729 made by LG, open left door and push the Ultra Ice and Refrigerator button simultaneously for 5 seconds. The display will change from 0 OFF to temperature settings.
Dec 10, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Elite trio
Hello bigmikeegator
Welcome!
You said, you have the Kenmore Elite Trio Bottom Freezer. You moved your refrigerator to a new home and removed the bottom freezer door, but can not seem to figure out exactly how to put it back on correctly.
It's too much for me to tell you myself.
This is easier!
Page 9 shows you how to remove and reinstall doors.
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0523115.pdf
Thank you,
Huuum,
Please remember to leave a rating!
Oct 06, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Trio 596.76502500 Mystery Noise
Does the noise only occur when the compressor is running ? My unit has this problem, similar symptoms to your unit, they stop when the freezer door is opened, etc., Several service calls have not completely eliminated it - yet ! The problem seems to be that the compressor coils are too close to each other and rattle. Adjusting them helps for a awhile.
Jul 31, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Open Questions:
Refrigerators Logo
126 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
