Question about Samsung HT-Z310T Theater System
My samsung ht-bd1150 keeps shutting off and display fan chk, but the fan works properly, what can I do to solve this issue?
  • 56 Answers
SOURCE: powering off for protection samsung HT-WX70
the fan is broken on your unit, this is a feature to keep the unit from over heating
check if there is anything blocking the fan from moving/rotating
try to contact your manufacturer
Posted on Jul 02, 2009
chipsandnuts
  • 70 Answers
SOURCE: Samsung HT-TWZ312 surround sound probs
With the home theater system off, press the 0-1-3-5 buttons in that order on the home theater's remote control.
Power on the home theater system.
With the wireless module on, press the [ID SET] button on the back of the wireless module for five seconds.
If your home theater continues to display rear check after you have tried the steps above, call Samsung Customer Care at 1-800-SAMSUNG (1-800-726-7864). Have your model number and serial number on hand to set up service.
Hope this helps!
Posted on Jul 08, 2009
chipsandnuts
  • 70 Answers
SOURCE: fan chk problem too
it means the home theater is over heating and the unit will shut down to prevent any damage. This can happen if the unit is stacked along with other electronic devices or the unit is in an enclosed area that prevents the unit from cooling properly. To decrease the chance of overheating, relocate your home theater to a more open area.
If the home theater display reads PROTECTION every time you turn it on, no matter where or how the unit is placed, it needs service. To set up service call Samsung Customer Care at 1-800-SAMSUNG (1-800-726-7864). Have your model number and serial number on hand to set up service.
cgweatherall
SOURCE: Samsung HT-X40 also shuts off after displaying Protection
You probably have the same problem that myself and several others have had, and let me guess, its outside of the warranty? How good are you with a soldering iron? If you are not afraid to do some soldering you can fix it, check out these instructions that i found:
http://lemurt.wordpress.com/2008/08/18/defenition-of-waranty-void/
you will need 474k or .47uf 100v capacitors and a soldering iron, but you can fix it, worked for me.
Posted on Sep 04, 2009
dunnbiker
  • 8546 Answers
SOURCE: samsung home theater HT Z410 fan chk will not stay on anymore
Can you see or hear if the fan is running? Is there sufficient clearance (4 inches) between it and the nearest surface for airflow? Is it clogged up with dust bunnies? You may be able to fix it yourself.
Unplug the unit. Look inside the vent at the rear. Reach in with a non-conductive probe to see if the fan turns freely. If not, it's bound up and needs replacement or unclogging.
If it turns freely with power off but doesn't rotate with power on, it's dead.
If it turns sufficiently fast with power on and you still have Fan Check, it's a sensor.
Resolve this issue and it will probably stop trying to protect itself by shutting off.
Posted on Feb 09, 2010
Testimonial: "Thanks for the help!"
Samsung ht bd1150 unaverisle codes
0382,0386.0388. Check these codes. If you wish to get more details, check the sites linked here. Setup code list, and setup procedure to many popular brand remote controls are given. http://electrohelponline.blogspot.com/ http://remotesearch.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy.
Oct 21, 2013 | Samsung Televison & Video
Home cinema shuts down after about two mins it says fan chk can u help
It means the fan(s) aren't doing their job. Clean out the dust bunnies and see if that helps.
Aug 23, 2011 | Samsung HT-X20 Home Cinema 600W Theater...
HT-Z410 ~ 2 years old "chk fan" message 2 min after startup; then shuts down. Home repair? How to find new fan?
Maybe you shoulkdjust look at it to see if it's clogged up with dust. The manual says to leave 4" of clearance around the fan opening.
The manual...
http://downloadcenter.samsung.com/content/UM/200802/20080220095448484_HT-Z410-XAA.pdf
Live chat with samsung might get you a part number:
http://www.samsung.com/us/support/owners/product/HT-Z410#
email support:
Call : 1-800-726-7864
Feb 05, 2011 | Samsung Audio Players & Recorders
My Samsung HT-WZ410 home theatre keeps saying fan chk, then shouts down, this has never happened before
I've advice you to check your exhaust fan if working properly.
The processor shuts down the unit because it sense that you have a problem on the fan.
This is happen to avoid further damaged to your output I.C. which is quite expensive.
If the fan is not working then try to clean it, sometimes it is full of dust that caused to stop from functioning. If you confirmed that the fan is already defective then replaced it with a new one.
After replacing and the symptom is still there then I've advice you to look for a qualified technician because there might be sometime wrong on the board (faulty parts).
Pls rate my help.
Thanks for using fixya...
Jan 15, 2011 | Samsung HT-Z310T Theater System
Getting a "fan chk" message on my Samsung HT-TZ512
Did u ever find a solution? The room I use the home theater in gets quite hot. I use an air conditioner but I think prolonged use in the heat has ruined the fan(s). The speakers will power up, and sound can be heard but after a minute or two the CHK FAN will come across the display, and ultimately, shut the system off. Is this what happens to you? T?hanks for any and all responses!,
Ed
Oct 04, 2009 | Samsung HT-TZ512T Theater System with...
Fan chk problem too
Jul 04, 2009 | Samsung HT-Z310T Theater System
Powering off for protection samsung HT-WX70
Jun 30, 2009 | Samsung Audio Players & Recorders
My dvd home theatre system ht tx75 keeps shutting down
protection error message means that your unit's fan is not working
it is a feature to keep your unit from overheating
check if there is anything blocking the fan of your unit from rotating
if problem still persist replace the fan
May 28, 2009 | Samsung HT-TX72 Theater System
I have a samsung ht-tx75 and it keeps shutting down every 10 minutes saying protection.the fan is working
Protection is very likely caused by an over heat condition, even with the fan working if the receiver is in a very enclosed place that warms up and is not ventilated it will cause the problem. The solution is to provide more ventilation so that the receiver can cool itself properly.
Feb 26, 2009 | Samsung HT-TX72 Theater System
Samsung HT-Z310T Theater System Logo
131 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
