Question about GE Dishwashers
Water is leaking around the pump area - GE Dishwashers
  • 4,339 Answers
Usually this is a pump seal. Replace it and before start up, put 4 cups of water in the unit or burn the new seal...
Posted on Nov 09, 2010
Coolant leaks around water pump area ,does,nt over heat.
Your water pump has a weep hole that indicated it is starting to go bad. Look at the lower part of the water pump while engine is running just below and behind where is says (THREADED SHAFT) when engine is fully warmed up if water pump is going out there should be antifreeze in this area leaking down onto the crankshaft pulley. In RED is where to look for antifreeze.
Sep 30, 2013 | 1998 Dodge Durango
Mysterious coolant leak
Check out this few help links,in related to this types of problem.Click the link below :----Transmission fluid gets into radiator?
http://schematicsdiagram.blogspot.com/2011/12/transmission-fluid-gets-into-radiator.html
The plastic housing which goes to the upper radiator hose is cracked and leaking?
http://schematicsdiagram.blogspot.com/2011/12/plastic-housing-which-goes-to-upper.html
Radiator leaking? http://repairhelpcenter.blogspot.com/2011/12/radiator-leaking.html
--------Car water leak around the Starter area and Bell Housing? http://schematicsdiagram.blogspot.com/2011/12/car-water-leak-around-starter-area-and.html
--------Leaking head gaskets? http://schematicsdiagram.blogspot.com/2011/12/leaking-head-gaskets.html
---------This will help.Thanks.
Jan 16, 2012 | 2001 Dodge Neon
How can i tell if my waterpump is bad? shut the car off and came out later to anti freeze in the driveway
If it's leaking that bad, open the hood take off radiator cap and fill with water (without making a mess and spilling a bunch. Then simply watch for where the leak is at, if it's leaking from a hose, the radiator, or from around the area where the belt is located on the passenger side of the engine compartment. If it's leaking from the passenger side around the belt area your water pump is the most common cause. They are made so when the bearing wears out around the shaft the pulley bolts, it has what are called weep holes and the water just runs out to tell you to replace the water pump.
Jun 18, 2011 | 2004 Ford Taurus
I fill it up and it takes two or three days to leak out.I have tried stop leak and dye,check all the hose connect with water in a spray bottle. Is there a other test i can do.
If this is a water leak check water pump diaphram (the hole in the bottom of pump) if you see water around this area replace water pump.Also check water pump gaskets for leak.Or have it pressure tested.
Apr 22, 2011 | Chevrolet Blazer Cars & Trucks
97 chevy 1500 coolant leak
It is the water pump most likely,they have ,what they call a weep hole in the bottom under the pulley,so they will leak out to let you know to change them right away.If it is on the top coming from the intake area,it would be the intake,they are also bad to leak,but look at the pump,under the pulley.
Mar 13, 2010 | 1997 Chevrolet K1500
Slow leak
The water pump should have a vent or "weep" hole. If the coolant is leaking from the hole, the water pump is defective. Hope this helped and best wishes.
Aug 11, 2009 | Dodge Spirit Cars & Trucks
Antifreeze leak in a 1999 plymouth voyager. Lookslike its coming from around oil pan. Water pump replaced last year.Also no heat
check all hoses .from thermostat to radiator to water pump. check heater hoses.if all is good .make sure your water pump not leaking around the gasket area.if all is good.core plugs could be leaking.
Apr 12, 2009 | 1999 Plymouth Voyager
Dishwashers Logo
50 people viewed this question
Top GE Dishwashers Experts
Mike
Garth Jackson
jdthefixer
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
