Question about Whirlpool Freezers
S20drss10 has started to make clicking noise on and off all day and night. was told by comet to defrost it even though its frost free, called whirpool who said not to defrost it. just want the noise to stop
  • 77 Answers
It sounds to me like it is the rear brd failing..this brd runs basically yhe whole show and the sound you are hearing is probably 1 of the relays starting to stick on the brd. They are very easy to replace although dependant on which one you required the prices range from £80 to £200. The other problem it could be is the icemaker if you have one. There is a solonoid in the rear behing the bucket that changes the ice from crushed to blocks this can sometimes overheat and activate on it's own causing this noise. easily repalced and only costs a few pounds. Let me know and i'll give you some better instructions on what to do.
Posted on Nov 14, 2010
My upright freezer freezes everything fine my only pro.blem is that it builds up ice/frost on the ceiling of the freezer first and then works its way down i have taken everything out,started fresh and...
Since you didn't give a model number, I don't know if it is frost free or not. If it is, then you have a problem with you defrost system: defrost heater, thermostat or defrost timer.
It also sounds like your door seal is not making solid contact and most air is leaking into the freezer.
If your unit is a frost free, then water should drain down and out.
Jun 24, 2011 | Freezers
My Frigidaire freezer (not frost free)won't stay cold
look at level side to side , and front to back. if not level door can leak . you will see water where it is leaking. check defroster is if staying on .
Feb 18, 2018 | Frigidaire Freezers
"High wind" sound following defrost.
Freon running through the feon lines can make some odd noises, usually a gurgling or higher pitched noise. If your freezer works fine with no more strange noises, then don't worry about it. If you have temperature problems or continue to have abnormal noises, then see if your freezer has the 5 year sealed system warrantee that most freezers have. If it does, and it is under 5 years, then call Frigidaire to come out to check it out for free. If it is out of warrantee you will need to live with it or replace the freezer, since a freon sealed system repair is very high. Good Luck, Appliance Specialists
Feb 04, 2010 | Frigidaire 14.1 cu. ft. Upright Freezer...
1999 Frigidaire Refrigerator
Check rear wall of freezer by feel for frost. Heavy, even frost indicates likely problem in the defrost system. Unplug unit. Defrost heater (in freezer behind rear wall panel), defrost thermostat (same area-must be checked at freezer temperature) or Defrost timer-located lower back outside of unit. Near compressor. Do continuity test on heater and defrost thermostat and if they show continuity (good), replace defrost timer. If not, replace the one that tests bad.
Defrost coils fully. Reassemble.
Please let me know if I have helped with comments and rating.
Refrigerator will work about 7-10 days after being defrosted until thick frost builds up again cutting off air flow to both compartments
Sep 07, 2009 | Frigidaire Freezer 20.3 Cu. Ft. Frost Free...
I want to know if the freezer Frigidaire has a defrosting clock
I wait a few hours and I turned it on, I wait again all night and it is getting it´s temperature. Thanks.
Sep 06, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Ice built up in the frost free freezer section
It sounds like the freezer fan(evaporator) is wearing out. This problem is very hard to diagnose because the fan spins but no fast enough to circulated the chilled air thru the freezer and refrigerator. The parts and labor are around $300.00
Aug 01, 2009 | Freezers
BEKO Frost free freezer not as cold as it should be!
Sorry I don't have a solution for you, however would like to know if you found out what was wrong. I have an identical problem with my Beko fridge/freezer. It's only 14 months old and the freezer just wont freeze. I've turn it off for 24 hour and let it defrost completely (even had the panel off to make sure there was no ice left). I've turned it back on again and it still wont freeze. Everything seems ok, ie fan blowing, motor running etc. I really am beginning to regret buying Beko. thanks
Apr 12, 2009 | Freezers
Maytag model MQU1556AEW, frost-free freezer forms ice in bottom.
I'm not sure if this will help but the freezer that is located on the bottom of my refrigerator started forming ice on the back part where the cold air was supposed to be coming out. I kept hearing a hissing sound like water dripping on a hot surface. I called the repair man in and he had to replace the defrost timer. Once he did that it worked like a charm.
I am not an expert by any means although removing ice from a frost-free freezer is a pain and this took care of the problem for me. Good luck!
Apr 07, 2009 | Maytag Freezers
Kenmore upright older freezer coils frost up
the tech was telling you to put it in defrost and if ater the time you didn't hear the click the defrost timer is defective but like you are describing the defrost thermostat (bimetal) could be bad. here's a simple test (if your handy with a screwdriver) just dissasemble the panel and you will see the coil and defrost heater. if your handy with a voltmeter (please disconnect power first!) locate the two wires to the defrost element put the meter in "audible" mode and check for continuity on the defrost heater if you hear a beep it's good if it dosen't beep it's bad just replace heater w/ bimetal and your ready 2 go! email me @ hvac.tech7872pr@gmail if you have any questions
Jun 09, 2008 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Freezer
if the unit is a auto defrost sound like a defrosting problem, if not a self defrost and the coils are not covered in thick frost then a sealed system issue would be the problem to check
Apr 19, 2008 | Freezers
Freezers Logo
77 people viewed this question
Top Whirlpool Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
AJMAL KHAN
Are you a Whirlpool Freezer Expert? Answer questions, earn points and help others
