Question about Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive
NOTHING happens when i plug into USB
So after a power outage when I plug in the harddrive into the USB nothing happens. the light on the unit is green. i can turn it on and off. i cannot see it under device manager. i hear no usb connect sound nor do i get any message.
also tried different wall outlet to no avail.
  • 3 more comments
  • chuck241 Jun 21, 2008
    Same problem. Vista recognizes with it is pluged/unpluged by the beep that accompanies USB devices being plugged in. However, there is no drive associated with it.
  • sjpisani Jun 22, 2008
    I have the same issue. The first time this happened I changed USB Wires and it seemed to work. Now it is just not working at all with either wire. So aggravating...
  • JonBT Jul 03, 2008
    I have the same problem with my drive, the only difference is that it is quite a bit older.
  • Anonymous Mar 28, 2009
    I have the same problem except i only happend after i tried to format it back to FAT32 so it would work wiht my ps3 and clicked delete partition
  • Ayman Hazime May 15, 2009
    Any usb thing I plug nothing happens I plugged magic jack it didn't work when I plugged it to another pc it worked when I plugged my phone it didn't work while it worked on my other pc note: I have Windows XP I don't want to format my computer I have important files
Staunchporra
  • 12 Answers
SOURCE: Simpletech 160 Portable doesn't show up
go into the control panel and click add/remove hardware... and manually add the device and then use the auto update to download the drivers
Posted on Jan 24, 2008
SOURCE: hi i have a WD
Hi I have the Essential Edition WD My Book 1TB/To, it was working well and then for no reason my computer does not recognise that it is connecte, now I can't access this drive was the g/ drive. Any clue as to what I should do?
Thanks
Posted on Dec 15, 2008
SOURCE: My WD5000H1-U00 will not start up when I plug power source in??!
Sounds like an internal switch or relay has failed. Not worth it to attempt repair. Were it me, I would open the case and recover the actual hard drive inside, it's probably still fine. For $25 you can buy a new external case to mount the drive in. This way you can save the data.
Posted on Feb 09, 2009
SOURCE: wd mybook lights flash and cannot acess drive
Just an FYI for anyone else with a similar problem. I had my buddy look at it and it was discovered that the problem was with the power cord.
If your hard drive is still under warranty, call WD and ask that they send you a new power cord. It worked for me instantly.
Worth trying anyway,
Posted on Apr 07, 2009
  • 7 Answers
SOURCE: I have WD External Hardrive (500H1CS-00)which was
ok...go to control panel then go to add new hardware then go though the steps...should help
Posted on Jun 25, 2009
ADP 8450 Since a power outage I am now unable to switch my dishwasher on. The light flashes and it makes some sound but then nothing happens.
If this happened after a power outage just turn off the breaker to the washer for 2 hours, this will reset the unit to factory settings.
Jan 17, 2011 | Whirlpool Dishwashers
My acer netbook 532h will not power on. just before problem the power on button stayed on and nothing happened; battery was pulled to turn unit off. unit has a blue light under the light bulb icon turn...
Two things to try first before we go further with the diagnosis:
1. Try to power up the netbook with the external hard drive disconnected & see if it will work.
2. Try powering up the netbook from the AC adapter only with the battery removed.
Nov 28, 2010 | Acer Computers & Internet
I have a Seagate Expansion Harddrive 500gb. When the power is on the green light stays on. However for some reason, now when i plug it it in the green light turns on and then turns right off. I can hear...
The external storage device has several major components:
* USB cable
* external power-supply
* disk-drive inside the enclosure
* USB-to-disk-drive adapter inside the enclosure.
Try a different USB cable.
Try a different USB port on your computer.
Try a USB port on a different computer.
Take a multi-meter, and measure the output voltage/amperage of the power-supply,
and compare with the specifications on the label of the power-supply.
Open the enclosure, and remove the disk-drive, and attach it as a "slave" drive in a desktop computer, to see if bypassing the USB-to-disk-drive adapter bypasses the problem.
Look at the label on the disk-drive, for manufacturer, product-number, serial-number, and manufacture date. Access the manufacturer's web-site, and use "check warranty status" to see if the warranty still is valid. If so, the drive can be replaced, at minimal cost to you.
Buy a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Search online for a professional "data recovery service". For a significant fee, they can repair your disk-drive, just long-enough to copy your files to a new disk-drive.
Nov 06, 2010 | Seagate (ST310005EXA101RK) 1 TB USB 20...
After a power outage computer will not turn on
first of all what kind of computer is i mean brand? secondly sounds like the power supply went bad..
Jun 12, 2010 | Computers & Internet
I turn my Acer on and nothing happens. The light
Try this it worked for me
Updating the BIOS will require a USB flash drive to store the BIOS information on during the update. To perform the update to the BIOS:
  1. Go here and download the latest BIOS for the netbook.
  2. Extract the files from the downloaded zipped BIOS file.
  3. In the Dos_Flash folder, rename the BIOS file from 3310.fd to ZG5IA32.FD, in all capital letters.
  4. Copy ZG5IA32.FD and Flashit.exe to the USB flash drive
  5. Ensure that the AC adapter is plugged in.
  6. Insert the USB flash drive into a USB port.
  7. Press and Hold down the Fn and the Esc keys together and press the power button.
  8. When the unit's power light comes on wait a few seconds and release the Fn and Esc keys.
  9. After the keys have been released the power light will start to blink.
  10. During the BIOS update process the display will be blank.
  11. Let the unit run and after approximately 1 to 7 minutes, the unit should reboot and the BIOS will be updated.
If the unit fails to reboot, or the BIOS was not updated sucessfully, try the steps again. If the unit continues to fail to reboot, the unit may need service.
Note: These instructions are only for the Acer Aspire One AOA-110 and the AOA-150 netbook series and should not be performed on any other model Acer Aspire One.
Mar 27, 2010 | Acer Aspire One PC Notebook
Same Problem - Flashing light - no power - after power outage
JD, get yourself a cheap battery backup surge protector, I have one and its saved my **** many times, I live in FL and with lightning and power outages its a real system saver.
Sep 16, 2009 | HP Media Center m7250n (ED842AA) PC...
Green light on front rapidly blinks after power outage. No picture, or can't turn on
This unit, when first plugged in or after power interuption takes 70 to 90 seconds for the digital module to boot up. During the time the LED blinks green and the set will not respond to anything. After the appropriate amount of time the blinking should stop and the set should operate normally. If the blinking never stops then you have to have the Digital Module repaired.
Apr 25, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Simple tech 500gb usb hard drive
Youve damadged the harddrive, is the harddrive spinning or making any noise?
Jun 16, 2008 | SimpleTech SimpleDrive Pininfarina 500GB...
Power Outage - PC will not Boot up
nope...you might have lost any combination of these items:
A. Power supply
B. Motherboard
C. uProcessor
D. Memory
This is a good reason why folks use UPS devices. Hope this turns out for you.
Mar 13, 2008 | HP Pavilion A520n (DW233A#ABA) PC Desktop
Compaq Presario 4400us
Either the new power supply you purchased is not functioning correctly. But, assuming it is now that you are getting some form of power to your PC, it is very likely the motherboard. Whatever fried your old power supply (or it could have just been the power supply itself) most likely fried your motherboard in the process. Probably not the CPU since the MB can't even post.
Jun 21, 2007 | Compaq (388746-001)...
Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive Logo
2,368 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
