Question about Biostar K8M800 Micro AM2 Motherboard
How do I disable the onboard video? I am adding my own video card.
  • 4,281 Answers
When you power up the computer press F1 or F2 or del or ALT+F2 key to enter in bios then go to advanced option menu in bios then disable on board vga then save settings and exit. Then on board vga disable then you can use your another video card. Let me know if you need further assistance. Thanks for using FixYa,
Posted on Nov 09, 2010
Install new video card in Gateway GM5072 with Pheonix bios and disable oonboard video
There should be an option to disable the onboard VGA connection within the BIOS of the computer.
Plug your monitor into the onboard video output to do this.
Dec 24, 2011 | Gateway GT5220 PC Desktop
Greetings, I have a Gateway 832Gm Media Center PC, I want to add a Radeon HD 5550 graphics card to get the ability to get dual monitor support. My question is do I disable the chipset via the bios or can...
Most likely what you will want to do is just turn your resolution down to it's lowest settings. and turn off unplug the computer and install the card. Plug the monitor into the card and then boot up the computer. Sometimes depending on the computer you may have to disable the onboard video in the bios but a lot of times you don't. If you do run into an issue you can unplug the card hook the monitor back up the onboard video, then if need be disable the onboard driver, by going to control panel, then system properties, then device manager and then under video adapter disable the drivers for the onboard video but it shouldn't be necessary.
Thank you,
Lee
Dec 07, 2010 | Gateway 832GM PC Desktop
Problem with onboard video of a compaq sr2032x
The onboard video card is actually set to secondary when you plug in a PCI or PCI-E video card. If no video image is showing then there may be further damage inside the mother board.
Apr 29, 2010 | HP Compaq Presario SR2032X PC Desktop
I need to disable the onboard video by finding the jumpers on the motherboard (MSI 7191 Version 1.1). When I installed a new PCI card (because the onboard video is broken) the computer freezes up and...
Go to the device manage and instead of disabling it, uninstall it. Then power down, move the cable to the pci port. reboot, when windows brings up the new hardware found, hit cancel until it disappears. Go back to device manager and if it has re-appeared uninstall it again and go about your business.
Sep 06, 2009 | MSI PM8M-V Motherboard
Media Center has an Intel graphics chip on the mother board. How do I omit using it so I can install a PCI video card?
Have you tried adding the card and see if it defaults to the card rather than the onboard video? Many BIOS are set that way by default.
Go into your BIOS and look at the onboard devices. It is preferable to tell your BIOS to first look for an add-in card and default back to onboard if you don't find one. But you can disable your onboard video, then save and reboot.
Jul 18, 2009 | HP Media Center m7060n PC Desktop
Were are the jumpers to disable the on board videofor aopen mx3w pro-E
Why do you need to disable the onboard video??
If you have added a new graphics card it should automatically select this new card.
If it doesnt, you can go in to the bios and disable the onboard graphics card from there.
For example, Onboard graphics can usually be refered to in the bios as PCI, so if you've added an AGP card or PCI-E card then you would just need to select either one of these from the bios menu.
Not sure what bios your using but it may even have ann option to disable onboard graphics.
Oct 23, 2008 | AOpen MX3W Pro-E (91.88210.241)...
HOW TO DISABLE MY ONBOARD GRAPHIC CARD??
For user BIOS21 & julio1963,
How to enable you're (Add-in AGP video card) & disable the onboard, integrated S3 graphics UniChrome 2D/3D PCI graphics card.
Enter you're bios. Open you're user manual to page 3-13. Integrated Peripherals. Go to, Init display first. Set to AGP.
(Not to PCI). That is all you need to change. The MSI bios will than see you're add in AGP card & automatically disable the PCI S3 graphics, (Onboard) card.
Enjoy!
If I can help you further, feel free to post here.
Please, each user's vote this issue as a fix, if this helped you to get you're bios to see you're new AGP graphics cards.
Mike
May 31, 2008 | MSI KM4M-L Motherboard
Monitor not displaying
observe your keyboard numlock key,,, press it .. if numlock key is on and off your motheboard and ram is working.. check video card.. but if numlock key is not working.. check your memory ram.. and motherboard...
Mar 31, 2008 | Asrock P4I45GV R5 Motherboard
Video controller disabling
That model server comes with onboard video. If you wish to use a PCI video card then all you have to do is place it in the server and the BIOS will automatically disable the onboard. If it currently has a PCI video card in it, just remove the PCI card and you should get the onboard video again. Hope this helps.
Aug 28, 2007 | IBM Netfinity 3500 M20 8657 Server
Hp compaq dc5000 small form factor
Hi, uninstalling the onboard video will only be reinstalled by Windows next time you boot up. Disabling it in the Device Manager might and mght not do the trick if your mb is set on using the onboard. You might want to try and disable the onboard video in the CMOS/BIOS set-up. In some instances, you are asked in the BIOS what video will be used such as onboard, AGP or PCI or a selection of something like that. Also you can try and not allocating any memory to the onboard video. Hope this be of some help. Pls post again how things turn up. Good luck.
Apr 28, 2007 | HP Compaq dc5000 PC Desktop
Biostar K8M800 Micro AM2 Motherboard Logo
211 people viewed this question
Top Biostar Computers & Internet Experts
Jayburt
David
David
Jerry Umali
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
