Question about Microsoft Office Computers & Internet
When Microsoft update is run, my Microsoft Office fails and says something about security update. How do I correst this?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 93 Answers
Windows update failed
You version is no longer supported, time to upgrade
Apr 04, 2017 | Office Equipment & Supplies
Tip
How to activate office 2007
Office Genuine Advantage (OGA) is another anti-piracy initiative by Microsoft on its popular business productivity product – Microsoft Office XP, Office 2003 and Office 2007. Similar to Windows Genuine Advantage (WGA), OGA requires users of the Microsoft Office software to validate their installed copy of Microsoft Office in order to download files from Microsoft Download Center, access updates or hotfixes from Office Update, and receive special offers for genuine users.
OGA is not to be confused with Office Product Activation that is mandatory required to during the installation process in order to use the Office software whereby users enter a serial product key that is validated online over the Internet or by phone by Microsoft to confirm that the product key has not been used on more personal computers than are permitted by the Microsoft Software License Terms. To crack Office XP/2003/2007 activation, you need a key generator that provides volume license key (Guide: How to change Office 2007 product key).
If you’re using a keygen-generated product key or publicly available leaked Office 2007/2003/XP serial number, especially the volume license key (VLK) that requires no activation when used, most of the keys no longer able to pass the OGA genuine validation test anymore with the following error message (Office 2007 as instance):
office-fail-validation.jpg This computer has failed validation.
Microsoft Office Enterprise 2007: Validation Failed
The product key used to install Office is not valid. It has been identified by Microsoft as a false key used with counterfeit copies of Office.
[0x80180108]
It’s likely that users who failed validation check may continue to use Microsoft Office as per normal and use Microsoft Updates to update critical patches. However, if you want to download add-ins, updates, templates, samples and tutorials, Smart Tags, Language Interface Packs and Software Development Kits (SDK) that require Genuine Office validation, you won’t be able to do so.
To bypass or crack the Microsoft Office 2007 and Microsoft Office 2003 OGA genuine validation, follow these steps:
  1. Install and activate Microsoft Office 2007 or other version of Office. If you intend to use the key-gen, you must install Enterprise edition.
  2. Download the patched ogacheckcontrol.dll.
  3. If you never validate your copy of Office, go to Genuine Microsoft Software web page, and run the Office Validation Assistant by using Internet Explorer (not Firefox as it will use different version of ActiveX component). This is to install the components required for Office validation. If you fail the validation – Office not genuine – simply ignore the message.
  4. Copy the cracked ogacheckcontrol.dll to the following location: Windows XP and Windows Vista (32-bit): \Windows\System32\
    Windows XP and Windows Vista (64-bit): \Windows\SysWOW64\
  5. Attempt to download Office files that require validation again. All downloads should work now.
The OGA Check Control crack works on Office 2007 Enterprise Edition, Office 2007 Blue Edition, Office 2007 Professional Edition, Office 2007 Pro Plus, Office 2007 Standard Edition and all Office 2003 Editions.
If you’re using invalid or blacklisted product key, you may have to change the Office product key (Guide: How to change Office 2007 product key). This is especially so if you’re using Microsoft Office 2007 Blue Edition.
Disclaimer: This patcher is for genuine Office user who having problem to pass genuine validation only. To use Office 2007, you must purchase a licenseir?t=techgadgetrev-20&l=ur2&o=1. Alternatively, you can use for free OpenOffice.org, an equally good productivity suite.
on Aug 02, 2010 | Computers & Internet
Hi!! How are u? My english not good that much but i will try to explain my problem: when iam open my computerwhich work by windows xp sp3 i got massage the ip operator (3.0208.911.01) is not...
OK, sounds like the problem is that the computer cannot get a valid IP address. In fact it sounds like you might have a IP address conflict on your network. Each IP address on a network segment must be unique.
Check if you are using DHCP.
  • Go to
  • Control Panel
  • Network connections
  • Locate the network connection you are using e.g. 'Local area connection' or perhaps 'Wireless connection'
  • Right click on the relevant network connection
  • Select 'Properties'
  • Select Internet Protocol (TCP/IP)
  • Select Properties
Is your machine set to "Obtain an IP address automatically" (DHCP) or "Use the following IP address".
If its "Use the following IP address" then make sure no other machines are also using this IP address. You can try setting to 'automatic' but if you do, make sure that you note all details first, so you can revert back to the settings you currently have if you need to.
if its "Obtain an IP address automatically" then make sure no other machines have been manually set.
With regards to the microsoft update, then your best bet is to only select a small number of updates at a time, until you determine which update(s) is causing the failure. Once you know which update is the problem then you can troubleshoot the specific update.
Hope this helps
Please take the time to rate this answer. Many Thanks Don.
Sep 05, 2011 | Microsoft Computers & Internet
Why I can not to download microsoft office 2007???
Overview The 2007 Microsoft Office Suite Service Pack 2 (SP2) provides customers with the latest updates to the 2007 Office suite (the products that are affected by this update are listed below). This download includes two types of fixes:
  • Previously unreleased fixes that were made specifically for this service pack.
    • In addition to general product fixes, this includes improvements in stability, performance, and security.
    • You can find out more information in Knowledge Base Article 953195, where product-specific changes are described.
  • All of the Public Updates, Security Updates, Cumulative Updates, and Hotfixes released through February 2009.
Before installing this service pack, you are strongly encouraged to read 953195, which describes some big improvements introduced by SP2, and also calls out some important information that you should be aware of before installing. arrow_anchorlink_up.pngTop of page System requirements Supported Operating Systems: Windows Server 2003 Service Pack 2, Windows Server 2008, Windows Vista Service Pack 1, Windows XP Service Pack 3
Service Pack 2 will update the following:
  • Microsoft® Office Basic 2007
  • Microsoft® Office Enterprise 2007
  • Microsoft® Office Home and Student 2007
  • Microsoft® Office Professional 2007
  • Microsoft® Office Professional Plus 2007
  • Microsoft® Office Small Business 2007
  • Microsoft® Office Small Business Management 2007
  • Microsoft® Office Standard 2007
  • Microsoft® Office Ultimate 2007
  • Microsoft® Office Access® 2007
  • Microsoft® Office Excel® 2007
  • Microsoft® Office InfoPath® 2007
  • Microsoft® Office Outlook® 2007
  • Microsoft® Office PowerPoint® 2007
  • Microsoft® Office Publisher® 2007
  • Microsoft® Office Word 2007
  • Microsoft® Office OneNote® 2007
  • Microsoft® Office Groove® 2007
arrow_anchorlink_up.pngTop of page Instructions To install this update, do one of the following:
  • Use Microsoft Update (recommended).
    • Microsoft Update consolidates all updates into one location and offers you only those that affect your particular system.
  • Install this update manually.
    • Download the file by clicking the Download button on this page.
    • Save the file to your hard disk drive.
    • Locate the .exe file that you saved, double-click it, and follow the instructions on the screen.
Aug 08, 2011 | Microsoft Office Professional 2007 Full...
Word 2000
A buffer overrun error is a somewhat generic error in the sense that buffer overruns can occur in the OS, OS subsystems or any application that you may be running. So what you have posted here does not necessarily tell me where the issue lies. Here's a progressive approach to solving the issue.
Buffer overruns are runtime errors in the program code. They occur when a program attempts to write more information to a particular "array" than is allowed or expected. MS Windows has a number of security patches specifically designed to fix these loopholes in their OS. So to start with, I strongly suggest visiting the Windows Update site and patching your Windows operating system until the website tells you that there a no updates available. Sometimes you will have to go through the process a few times before all the updates are successfully applied.
Next visit the Microsoft Office update site (office.microsoft.com/officeupdate). There is also a link to it on the Windows Update page. Update your Office application in the same manner. Once that's done if you are still experiencing the problem, you'll want to launch the installer for MS Office from your disk and attempt a repair.
If that fails, perform an uninstall of MS Office, then manually delete the Winword.exe file from your PC and reinstall the software from scratch.
This progressive approach should fix whatever the issue is.
Aug 12, 2008 | Microsoft Word 2000 for PC
Computers & Internet Logo
37 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
