Front Load Washing Machine = Error F30
Just received our new Maytag Epic MHWZ600TW01, Front Load Washing Machine. Set up went fine and we then ran it the first time, without a load, to clean out any possible factory film, oil, etc. - as instructed in the Owner's Manual.
At the end of two cycles (each cycle being a water fill, wash, drain, high speed spin), and with about 22 minutes left, an Error F30 popped up, and everything stopped.
Since this happend, we haven't been able to re-start the machine. After going over the trouble shooting items in the manual several times, including unplugging the unit for about 30 minutes and then trying again, nothing works. All that happens is the following:
  1. When the start button is puched, the "locked light" turns on for a few seconds and then turns off.
  2. After some clicking, no water fill happens and the drum turns slowly once or twice and then stops.
  3. The "locked light" lights turns on, and that's all that happens, nothing further.
I did call Maytag service, but even though pleasant, they didn't really have anything to tell me.
After googling the error code, I came up with discussions concerning a possible problem with the Dispenser.
Has anyone run across this, and had any success correcting it?
We do have a service call in, but they won't be at the house for at least 48 hours. Meanwhile, the clothes are piling up!
Thanks,
  • 1 more comment
  • denisonw Jul 12, 2008
    I have the same issue, my machine rattles as if it is trying to get water and nothing happens, then the F30 error code comes up.
  • Anonymous Aug 22, 2008
    I have the same problem. Was the repair man able to fix your problem? If so how much did it cost?
  • kimcarson Jan 07, 2009
    Same problem...any solutions??
  • 3 Answers
Hey there is a temo fix till some body comes to your home if you remove the soap try and reach in to the back of the opening you can rest the spring loaded wheel that controls the soap disspenser and that will stop the clicking and allow the machine to run!!!!! after reading all the post i could find i figured it out now my washer is running fine!!!
Posted on Aug 09, 2008
Testimonial: "This worked temporarily. Fortunately we were covered by warranty and the entire machine was replaced. No problems since."
Just remove the soap tray, reach in all the way to the back (upper right) and move the little lever. It's the only moveable thing in there. Might have to do it again for the rince cycle.
Posted on Oct 26, 2009
My front-loader was giving me the same error code. What corrected the problem for me? Simply remove any items from the top of the washer (my weight? detergents). There is a part that moves in accordance with each cycle, located under the top cover, that is prevented from moving if the weight is in the perfect spot.
Posted on Sep 02, 2010
Front load washer displays f 24
Here is a link to the owner's manual for that device.
http://www.searspartsdirect.com/partsdirect/user-manuals/mhwz600tw01-maytag-residential+washer-manual
Mar 19, 2014 | Washing Machines
Maytag Epic Z won't Drain after rinse cycle.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 13, 2011 | Maytag EPIC MFW9700S Front Load Washer
My Maytag washer has a flashing F 15. What does that mean?
The following list of codes indicates an electronics communication problem with the washer: * Epic® washer - F05, F07, F09, F10, F11, F13, F14, F15, F21, F22, and FdU
* Epic ZTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33
To remove the error display, press Pause/Off or Pause/Cancel twice.
If Pause/Off or Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
Hope this helps.
Jun 24, 2011 | Maytag EPIC MFW9700S Front Load Washer
F30 code on 3000 series washer
I don't know the answer, but you can call Maytag @ call 800-688-9900 toll free for a code definition
Feb 26, 2011 | Maytag EPIC MFW9700S Front Load Washer
When i try and turn it on, a code comes up f 01
Model #MHWZ600TW01, this unit would display an F01 error immediately after the start button was pressed. This error is an EEPROM communication failure of the electronic control board and is an internal failure that basically indicates the washer no longer thinks it's a washer. Since the repair requires the board to be replaced, I installed a new control board and now it has started washing again. A word of caution. Whirlpool has been making a lot of changes to the control boards of their front load washers (yes Maytag too) so make sure you are ordering the correct model using the full model number including the last two digits. If you install the wrong board, you may find yourself trying to fix a self induced problem.
Aug 09, 2010 | Maytag EPIC MFW9700S Front Load Washer
Maytag Epic Z with error codes F20 and F24
my epic will start & wash & then gets F 20 & won't drain until I hit start again
Oct 16, 2009 | Maytag EPIC MFW9700S Front Load Washer
Maytag Epic giving F11 error code!
ths.gardenweb.com/forums/load/.../msg1012004912002.html
Jun 22, 2009 | Maytag EPIC MFW9700S Front Load Washer
F30 code
F30 = DISPENSER SYSTEM ERROR
You might have to replace the damaged one.Or in other words something that cannot be repaired.Well came across this info through other certified websites.good luck.hope this helps out.
Jan 09, 2009 | Maytag Neptune MAH5500B Front Load Washer
Front Load Washer - Error F30
hI I HAVE REMOVE THE TOP COVER. YOU WILL SEE AT LEFT A PLASTIC ACTUATOR WHO MUST BE UNPLUG FROM ANOTHER PLASTIC PIN. JUST PUT IT BACK TOGETHER AND THE PROBLEM WAS GONE!
Jun 16, 2008 | Washing Machines
Maytag Epic Z error code
I need a clear code for maytag epic z front load washer
code f-o1 is coming up
says intall new ccu, I did but still the same
do I need to clear the code if so how.
please tell me.
Jun 16, 2008 | Maytag EPIC MFW9700S Front Load Washer
Washing Machines Logo
800 people viewed this question
Top Washing Machines Experts
