Question about Kitchen Ranges
How do I reset the digidoor 24? - Kitchen Ranges
Who do I contact for Digidoor repairs and maintenance in the Lydenburg area?
only link for digidoors repair
one company
use "contact us " their web page
to get the nearest authorized repairer of didgi doors to the lydenburg region
DigiDoor Garage Door Motors Installations Repairs of DigiDoor 1000N...
Oct 14, 2016 | Building Materials
My digidoor 3 doesn't work, just constantly flashes amber
Digidoor ... what is that? Make, model and OS of laptop please.
Jun 23, 2016 | Computers & Internet
Can i fit 12v battery backup for digidoor 11 to open when there is loadshedding. My digidoor2 had the extra consoke for remote receiver
Nope, Digidoor II has no battery backup. You need to invest in a UPS or replace the motor.
Digidoor one, Digidoor III and the Digidoor IQ all have build in battery backup.
__________________
Reference:
http://www.4x4community.co.za/forum/showthread.php?t=142874
Jun 13, 2015 | Computers & Internet
How do I get a free service manual for digidoor 24 garage door opener
Your first problem is you bought a digidoor garage door opener. But check their website, or call the manufacture. You will either be able to download the manual or have to buy a one directly.
Mar 28, 2015 | Building Materials
Where can I get a digidoor 1 garage door motor ?
I found a site that you may check out go google -type in www.hydrodoors.co.za/products
they claim to be the home of digidoors. they have an e-mail , sales@digidoor.co.za and a telephone no. 0114749060
even if they are not close to you maybe you can purchase on line and have it sent to you.
Feb 17, 2015 | Cars & Trucks
I bought a receiver to pair a Centurion D5 motor with thE Digidoor motor.How do i install the Receiver on a Digidoor motor?
Hi there Vusi.
You should have a manual open and close switch on the wall for your Digidoor. You need to find the two wires which control the open and close functions on the Digidoor Trace these back to the Digidoor motor connect these to the Comm and NO terminals. You also need to supply 12V power to the receiver This needs to be connected to the Possitive and Negative terminals on the receiver. These connections originate in the Digidoor motor housing and can be connected right there. Some Digidoor motors have connection terminals for additional remote receivers in the housing. Remember that the minimum connections needed are Positive, Common(Sometimes the common is also the negative supply so you can bridge the common and negative terminals on the receiver) and NO. Then pair the remote with the receiver as per the instructions in the receiver box. If you still cannot come right post pics of the PC boards of your receiver and Digidoor motor and I will identify the connections for you
Jan 05, 2015 | Televison & Video
I bought a second hand Digidoor 1 with garage door. The door opens and closes perfectly when the digidoor is off. When I power up the digidoor the motor will not open the garage door when the door is...
You are receiving interference from the digi door. You will have to return this unit and go with a different one on a different frequency. Chamberlain makes a clicker that would work well with that unit. Thanks BB
Sep 21, 2010 | liftmaster Chamberlain Garage Door Opener...
I have a digidoor 2 automatic garage door and it closes in stages not in one motion. The problem started when I stopped the closing motion half way down by remote control to let someone in. Up until then...
It sounds like your obstacle setting might be set too low and the friction of the door is causing the motor to stop. There are two white alan key adjustments on the side of the motor that can be adjusted to change these settings for the up and down sensitivity. If this does not solve your problem contact the Digidoor technical helpline on 2711 4749060, they will be able to assist you.
Aug 24, 2010 | Kitchen Ranges
Kitchen Ranges Logo
503 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
