Question about Karcher 2500 PSI Pressure Washer
Onan p224 engine
Need a cylinder head for this engine. believe part Number is onan 170-4387
  • 33 Answers
Gonna have to go to an onan dealer or repair place.
Posted on Apr 21, 2009
How to setup the timing on a 1941 john deere tractor and which cylinder is number 1.
The number one cylinder is the one closest to the front of the engine/tractor. When you look from one side across the top of the engine you will see that one of the cylinder heads is slightly forward of the other. The one that is most forward of the two is number one. This simple trick works on ALL multi-cylinder engines. Twin to W-18. The most forward cylinder head and the most forward cylinder on that head. If the engine is mounted backwards or sideways the front of the engine takes precedence.
Mar 24, 2016 | John Deere Garden
Miller Legend welder. Onan engine starts and runs a few minutes then dies. Why won't it restart for 5 minutes?
Some engines have a low oil cutoff switch. If the oil level drops to a certain point it kills the engine. Your oil level may be close enough that after starting and running for a little bit the level drops enough to kill the motor. After sitting for awhile the level rises enough to allow the engine to run again check the level and add oil if necessary.
Hope this helps.
Bob
Oct 22, 2015 | Onan Starter for twin cylinder engine...
Are the wires in a Onan gender numbered in the panel box cause their all white in color and all disconnected help me with a dummies version diagram please!
I believe you are asking about an Onan generator in a motor home? Search for your model number on generator, then go to the Onan website and look for a pdf download of their wiring manual. My dealer would help me with this for free, ask yours. Be prepared for $100/ hr if the dealer works on it.
Feb 23, 2015 | Cars & Trucks
My onan marquis gold generator runs no problem, when I put a load on it, it doesnt ramp up, the fault code is 14, this is a marguis gold 5500 spec d
Does it bog down? if so have engine checked for ability to deliver HP. Cylinder compression, leakdown test. When was it tuned?
Jun 23, 2014 | Onan Marquis Gold Quiet Gas Generator 5500...
1972 5cck onan engine
I would need some more information that you list the complete model & serial numbers of the unit you are asking for information about, so I can help with you the correct answers. Serial number should be on the name plate of the engine for the engine.
Dec 02, 2011 | Watts Onan Portable Generator - 5000 ,...
Where is bank 1 sensor 2 located in a 1996 mitsubishi galant s?
Locate the number 1 spark plug and then locate the O2 sensor in the exhaust. The one you see nearest the cylinder head is number 1. Look underneath the vehicle and locate the catalytic converter and the number 2 sensor is just before the "cat" and the one after is the Bank 2 sensor 2. I believe that the number one cylinder is closest to the radiator and the front of the engine. If this is a 4 cylinder car it is the sensor in the exhaust just prior to the catalytic converter. You will need a 7/8" or 22mm wrench and a good rust penetrant to remove the sensor without incident. Let me know if you need anything else.
Jul 10, 2011 | Mitsubishi Galant Cars & Trucks
Onan MicroQuiet 4000 Generator
Remove the air cleaner and inside near the throat of the carb is two bolts holding the carb to the intake remove these. Unhook the fuel line and twist the carb to allow the linkages to remove.
Sep 14, 2009 | Watts Onan Portable Generator - 4000 ,...
Karcher 2500 PSI Pressure Washer Logo
311 people viewed this question
Top Karcher Garden Experts
John Trevino
Are you a Karcher Garden Expert? Answer questions, earn points and help others
