Question about NetGear RangeMax NEXT WNR854T Wireless Router
I need a manual for the Netgear RangeMax WNR854 wireless router...had DSL and have bundled with cable now have broadband and don't remember how to hook up router. thnx
    Scholar:
  • 97 Answers
You should be able to download the manual from here:
ftp://downloads.netgear.com/files/WNR854T_RM_20Apr06.pdf
Hope that this helps!
Posted on Nov 09, 2010
HOW DO I CONFIGURE MY ROUTER TO ACCEPT THE HP4100 (WIRED USB) SERIES OF PRINTER?
Connect with network cable and make sure both are set to DHCP for auto config.
Or manually set an IP's on both units. You need enter Subnet Mask and Gateway.
Nov 11, 2012 | NetGear DGND3300 RANGEMAX DUAL BAND...
Does the netgear n150 wireless router work with the westell 6100G single-port modem provided by verizon? they **** btw.
Yes this router will work with any DSL or cable modem that is out in the market right now, it just need to be setup properly to work with your modem.
Feb 09, 2011 | NetGear N150 / RANGEMAX 150 Router
How to connect ruoter to internet
If you are connecting to either broadband cable or dsl you pretty much have the same steps. First hook up the modem (dsl or cable) with its own power cable and its own internet connection coming in (dsl will be a usually green phone cable)(cable will be a coaxial line that the cable guy already hooked up). Next get the netgear router and plug in its power cable somewhere near the modem, then plug in a preferably crossover ethernet cable to the uplink connection on the back of the netgear, should be on the same side as where the power cable went in. (and yes you can probably use a straight ethernet cable as well) Plug the other end of the ethernet cable into the only location it will go on the modem, both boxes should already be setup for use, if for any reason they do not work just pull the power on them both at the same time and wait a minute or two and replug them back in for power resets.
Oct 31, 2009 | NetGear RangeMax WPN824 Wireless Router...
How do you connect a netgear router from dsl to cable
The DSL modem will have a LAN port (RJ45), plug a LAN cable in this port and connect the other end to the Netgear router's WAN port.
Sep 10, 2009 | NetGear RangeMax NEXT WNR834B Wireless...
Need to set up router
Provided you have a broadband internet connection (DSL or Cable), it is easy to install the router. There's a CD that came with the router and you can use that for initial setup. It will guide you through the process of installation.
Jan 11, 2009 | NetGear RangeMax WPN824 Wireless Router...
Netgear rangemax wpn824 incorrecty or won't detect wireless conn.
Check ISP configuration to match Router settings with your supplier requirements.
Your issue seems related with wrong settings on Router WAN configuration.
Check if DHCP is required on your router or if it has tio be configured as a BRIDGE.
Your ISP should be ready to support you. (Or Netgear)
Dec 31, 2008 | NetGear RangeMax WPN824 Wireless Router...
Connect netgear wpn824 to DSL router using usb connection between DSL router and wireless router
call your ISP. Change the DSL modem from USB connect to ethernet connect. There is no possible way two match the two device
Dec 25, 2008 | NetGear RangeMax WPN824 Wireless Router...
Hook up
Hi Cheryl,
From your cable/dsl modem please take the cable that comes out of it that looks slightly larger than a phone cable and plug it into a port on your NetGear Wireless Router that is labeled either Internet or WAN. After that is done, unplug the power to both your cable/dsl modem and your wireless router. Plug the power back into the cable/dsl modem and wait about 30 seconds then do the same with the wireless router.
Next on your computer, there should be a wireless icon by your clock near the bottom right corner of the screen. If you double on it, you will see a list of connections, yours will say Netgear and should have a good signal strength. Double on it and give it about 10 seconds to connect. Voila, you should be on the Internet.
Please let me know if this solves your problem.
Thanks,
Adam
Nov 28, 2008 | NetGear RangeMax NEXT WNR834B Wireless...
Netgear
hello!
-- who is your internet service provider
-- what is the operating system of your computer?
-- is this working fine before or is this a brand new router
you may try this and see if this help solve your problem. make sure your computer is directly connected to the router
Step 1: Shutdown the computer.
Step 2: reset the router while power on then Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and configure the router settings
Step 7: test the Internet connection.
if this still didnot work, upgrade the firmware of your router
note:
configuring the router settings will depends who is your provider. if your isp is dsl you need to configure your ISP username and password on the router. if your router is a cable no need to change any settings on the router. it should automatically work
May 29, 2008 | NetGear RangeMax WPN824 Wireless Router...
Wireless router installation
Please see my response to this question. Your university's connection is most probably a LAN connection, so you'd need to follow the instructions as if you had a cable internet connection (unlike DSL, a LAN connection and cable internet connection don't require authentication with the ISP).
Jan 07, 2008 | Linksys Wireless-G Broadband Router
NetGear RangeMax NEXT WNR854T Wireless Router Logo
61 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
