I CONNECTED A AUDIO Y-CABLE TO MY COMPUTER TO MY HDTV AUDIO INPUTS ON BACK OF TV. HOW DO I GET THE SOUND TO COME FROM TV SPEAKERS?
    Master:
  • 633 Answers
You will set the default sound device as HDMI audio.
You can found the sound settings in the control panel.
Posted on Nov 10, 2010
Mitsubishi rear projection tv, model WS-48311 - Lost audio after moving tv and re-hooking up cables. How do I get it back?
It sounds like this TV is being used only for the PS3. We'll need to troubleshoot this through a process of elimination.
If you're using Component Input 1 and audio, try using Component Input 2 and audio instead. If this set of inputs provides working audio and video - you can stop. Or, try going back to Input 1 once more. If Input 1 now works - you may have simply made a better connection. If it doesn't - then there's probably an issue with input 1 on the TV.
If moving to Input 2 above still didn't solve the problem, you should try using a different set of audio cables between the HDFury and the TV. If it now works, the original audio cables are faulty.
You can check the HDfury setup on another HDTV with component inputs with it connected to an HDMI cable. if the HDFury wors, you know the device and all the cables work. If you do this test and it works with your PS3, then you know that the PS3 is providing good video and audio signals via HDMI. If the problem follows the PS3 - then it's the PS3 at fault. If everything works perfectly on the second TV, then there is some issue with the audio amplifier / inputs / speakers of the Mitsu TV. You could get a cheapo stereo amp and speakers - or a set of computer speakers for audio - it all depends on how much you want to spend for sound.
Good lcuk!
May 07, 2015 | Mitsubishi Televison & Video
Sound
Your TV has a pair of analog RCA Audio Outputs on the back of the set. They are the red and white, female, round outputs and should be labelled as Audio Out. If you have a surround receiver or stereo that accepts this type of input (most do), then you would purchase a stereo RCA audio cable that has the red and white male ends on both ends of the cable and plug them in to the appropriate stereo RCA left and right channel audio inputs on your receiver and the aforementioned outputs on your TV. The same is true if you have a pair of self-powered computer speakers (or similar). If your external speakers or audio systems don't have the RCA inputs, you may need to get an adapter to convert the RCA output to stereo mini-jack (or similar) to match the appropriate input on your external speakers. Does that make sense?
Apr 14, 2014 | Sceptre X322BV HD 32 inch Class Television...
Can't get TV sound hooked up through sterio?
Hi ,
have you tried using a HDMI cable to hookup to your stereo?
that would be a better option.
george.
May 25, 2011 | Samsung 46 in. Flat-Panel LCD HDTV
I have been trying to add external RCA speakers ( 5 speakers with 1 amplifiler) to my LG PK950 directly through RCA audio put with red and white cable, but so far I couldn't get any sound coming out of my...
It are two things or the plasma not ordering this him the sign it gives audio or not this one connecting the amplifier to the audio exit the cables rca have to go connected in the audio exit of the plasma in the part of behind he says exit
Feb 12, 2011 | LG Infinia Series Plasma HDTV 50PK950
Hello. I just connected my polaroid 32 in LCD HDTV to my computer and there is no sound? I played around with the audio settings on my computer but no luck. How can I fix that? thanks!
You'll need to run an audio cable from your computer's sound card to the TV as well. Depending on your TV's inputs, you will have to get a cable that has a 1/8" stereo plug on one end and either RCA male or 1/8" stereo plug on the other (depends on whether your TV has a 1/8" audio input for the computer connection or RCA inputs.
Feb 04, 2010 | Polaroid TDA-03211C 32 in. LCD HDTV
How do i use it so my tv programming is in surround sound?
if the Comcast cable box has an HDMI output, it should connect directly to one of the TV HDMI inputs. Then connect the LG DVD unit HDMI output to the second HDMI input of the TV. Use two HDMI cables. Do not buy the expensive Monster HDMI cables. If you have already done so, I recommend you take it back for a refund, then buy the low cost HDMI cables which will work just as good and then you can bank the savings toward a new Porsche Boxter!! Now we have the video connected from both the cable box and the LG system.
Now--what do you do if the cable box does not have an HDMI output--just use its component output and your component cable (red, blue and green) to connect to the TV component input. This will still get the video to the TV and good HD pictures. Hum--do you have an HD cable box? You did not say and I just assumed that you did since you got the HDTV. If not, let me know with a follow up question and I will assist in that area further.
Now for the audio connections--The DVD player will not need any connections since it in the LG unit. The sound will come out the speakers when you start playing the DVD. The cable box is where we get the TV audio to feed the LG unit. If the cable box has an optical output, use an optical cable (again the low cost one)and connect to the optical input on the LG.
This will get the TV audio to the surround system. If no optical output, use the red and white (left/right) audio connections and connect to one of the two the LG audio inputs. To hear TV audio on the LG speakers, just switch to that input or the input associated with the optical input.
To watch DVDs, switch the TV to the HDMI input to which you connected the LG unit. For TV, go to the other HDMI input (or component input).
Switch the LG to the audio input to which you connected the cable box to get TV sound.
Hope this gives you food for thought. If so, and you have more questions, just come back in with a follow up.
Sep 11, 2009 | Audio Players & Recorders
I can't hear my tv speakers
If you are connecting your computer to your TV via the PC cable to look at the internet on your screen - you will also need to hook up an alternate audio cable from your computer to either external speakers or an audio receiver in order to hear sound - a PC cable only carries video from the computer to the television, no audio.
Apr 14, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Sc-pt660 + 46pz85u = NO SOUND!
Don't worry about sending the TV audio to the Panasonic. Just send a digital audio signal from the cable box to the Panasonic.
DVD - Panasonic connected via HDMI
TV - Panasonic connected via HDI
cable connected to cable box and TV. But you will not really be using the cable connection to the TV (TV Tuner) since you will want HD feed from cable box through HDMI input on TV.
You aren't concerned about feeding the TV speakers because your audio will always come from the home theatre.
Note that some components don't feed audio through HDMI, in which case you will need to use optical digital audio.
Sep 08, 2008 | Panasonic Home Theater System System
Audio Problems
well dvd player is only 480 i ok not 720 unless its blue ray so dont even do that coupont cables usallly 480 also with comcast outs do u have hd then use one with hdmi outs ok coxal digtal cable works great also better rcas
Jan 05, 2008 | Olevia LT37HVS 37 in. LCD HDTV
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
