Question about Dell Inspiron 9300 Notebook
9300 display issues
While watching a video the other day my 9300 froze. I did a cold reboot and noticed fuzzy like dots on the opening Dell screen. Then noticed once I booted to windows severe lines and dots that caused the it to freeze again.
I went into safe mode and shut off the video drivers for the 6800go and rebooted. Everything worked fine. Now this is the confusing part. After messing around I realized I could use the drivers some of the time, not much. Eventually it would mess up again. I tried two different versions of the driver. Installed XP (using vista), nothing seems to be helping.
I can't see it being a driver issue being I've used the same driver. I would think if my video card went kablooey then it wouldn't work some of the time.
It could be my screen, but again - why would it work some of the time. It seems like maybe something is loose...or so I thought. I turned it on and noticed it was working correctly, so I went and done other things without touching it. I noticed when I looked up every now and then the dots and lines appeared then disappeared. This lead me to believe that it's getting hot. Though if it's getting hot wouldn't it just die. Would it mess up the card then fix itself when it cooled back down.
Yeah, I'm just confused. Basically as long as I don't install video drivers I'm not plagued by dots and lines. The basic windows video drivers are not even good enough to view video (because it lags) and I can't use my native resolution, so I'm looking for why this is might be happening.
  • 130 Answers
Sounds to me like u r video card has an issue, or it could be the display on it's way out, that problem is really hard to resolve without personally looking at it and toy around with it, I would suggest contacting Dell tech support chat and let them go inside remotely and check it out inside and run a diagnostics on it, if you shut the system off and then restart it and hold the Fn key down you unit should run a diagnostics that should tell you your problem.
hope this helps out and let me know what you find out!
Posted on Jun 16, 2008
Is it possible to fix an LCD for Dell 9300?
you could buy a replacement screen on ebay? apart from that i dont think its fixable
Feb 01, 2014 | Computers & Internet
My Dell Inspiron 1525 laptop has been having trouble with overheating. I used a laptop fan but my 9mo pulled it off the table and broke it. I went through the process of shutting it down after using it...
holding the fn key on boot will start the pre boot diagnostics if theyre clean then the heatsink and fan need cleaned out as they get blocked with dust, there should be a panel that you can remove on the back
Feb 24, 2011 | Dell Inspiron 1525 Notebook
Hello, I have a Dell D600. and the screen froze the other day. I did a hard restart and now the screen is pitch black at startup (but the systems seems to be running). Please help
The first thing to do is determine if the system actually is running or is it in a no POST configuration.
  1. If you are getting any video at all (Dell Splash Screen at boot) then try booting into the Safe Mode (F8 at boot) If you can get into the safe mode, then try a system restore to the day before the issue
  2. If you are not getting any video, then try using an external monitor and toggling it on with FN + F8 If you get video on an external display, then there is an issue with the LCD most likely and I'd try reseating the video cable under the keyboard as a place to start.
If you are not getting any video, then try this:
Jan 12, 2010 | Dell InspironTM 1501 Notebook
Numerous, bright, multi-colored vertical lines on 9300 screen
Try taking out the Ram memory first one stick at a time. Sometimes when Ram goes bad or overheats, it first affects the display. If that is not the issue, here is the link to your service manual.
Oct 09, 2009 | Dell Inspiron 9300 PC Notebook
6 monitors on 1 screen!!!!
try booting to safe mode (F8 at boot) and see if the issue goes away. If it does, then reboot in the normal mode see if the issue still occurs.
If it does, try running systemre store to a restore point before the issue started.
Mar 06, 2009 | Dell Latitude D600 Notebook
Black dotted line on monitor
Hi , Do not panic ,It is to do with the display driver which you need to reinstall.
Jan 11, 2009 | Dell Inspiron E1505 Notebook
Dell D800 screen looks like if it fizzing
you need to reinstall the Graphic Drivers. If you have Installed any antiVirus in recent days, try uninstalling it and reinstalling it back again. it seems as if the problem is with the graphic card and need to be replaced
May 01, 2008 | Dell Latitude D800 Notebook
apparently this works
* Remove the battery for 10 seconds
* Replace the battery
* Open the Nokia 9300 to view the inside display
* When you see the screen with "NOKIA" in blue text,
* Press and hold the following 3 keys until a Format Message is displayed:
CRTL + Shift + F
* Confirm the process by selecting Format
* Formatting will begin
* After formatting is complete the Nokia 9300 will reboot with some basic settings. If prompted, accept the request to reboot
* Follow the instructions on your Nokia 9300 to set the time, date and city and to enter your contact information.
Apr 06, 2008 | Nokia 9300 Smartphone
Bad screen display
If it does the same in safe mode, your LCD or graphic adapter is bad. If not uinstall the current drivers and get the newest ones from COMPAQ.
Jan 02, 2008 | Compaq Presario R3000 Notebook
Dell Inspiron 9300 Notebook Logo
75 people viewed this question
Alun Cox
