Question about Kenmore 57029 Side by Side Refrigerator
Is there a drain in freezer of side by side water keeps freezing on bottom then builds up and up
  • 441 Answers
It is behind the back wall of the freezer, try this..Unplug the unit and pour 1-2 cups of warm water into the bottom of the freezer towards the back, this should unblock the defrost drain
Posted on Nov 09, 2010
Water freezing on bottom of freezer
Clean the drain pan and drain line in the back of the freezer section underneath the evaporator coil. Make sure water drains when you pour it in. If it doesn't - also clean drain tube on the back of the unit behind the cover. When done - put the tube exactly where it was.
Good luck! :)
Vlad
First Choice Appliance
May 14, 2010 | Jenn-Air JSD2789GES Side by Side...
The defrost drain pan is plugged and not allowing the water to drain into the pan under the refrig. Remove the cover on the back wall of the freezer and clear the drain by flushing with hot water.
Mar 25, 2010 | Jenn-Air JSD2789GES Side by Side...
Leaking water and ice build-up in freezer
There's a drain hole in the freezer side behind the bottom drawer in the back wall that must be clogh ; put hot water into it untill melted the ice and keep pouring water to clean the drain (don't worry , the water goes to an evaporative tray) .Keep the drain clean by putting every 3/4 months half a cup of clorox or bleach.
Sep 28, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Build up of ice on bottom of freez
Check for a blocked defrost drain. Take the panel off at the back of the freezer section and find the small hole at the very bottom center below the cooling coils. Use hot (but not boiling) water and a turkey baster to flush it out until water runs through it. (it will go into the defrost drain pan, where it will evaporate)
May 24, 2009 | GE GSF25XGRWW 36" 25.4 Cu. Ft....
Water building up on the bottom inside the freezer side
the drain in the freezer is clog make sure the drain from the freezer is clean all the way to the pan next to the compressor . you need to open the back wall of your freezer for that ( the inside wall) clean with buster (water pump)the drain is in the bottom middle of the freezer.
Apr 19, 2009 | Frigidaire Gallery Series GLRT83TEK 30"...
What causes ice build up on the bottom of a freezer?
your drain is probably plugged so when the fridge goes on defrost the water has nowhere to go.After the defrost cycle when the frige starts to freeze again the water freezes up causing ice build up
Dec 18, 2008 | Admiral 26 cu. ft. Side-By-Side...
Water puddling in bottom of freezer and freezing
the drain in the back of the freezer is probably full of ice. you need to pull out panel and use heat from a blow dryer to unplug the drain. then take a small gauge copper wire long enough to extend into the drain a couple of inches and loop it around the black heating element then when it goes yhrough defrost it should keep this from reaccuring
Dec 01, 2008 | Maytag MSD2434GE Side by Side Refrigerator
Ice buildup at bottom of freezer and small puddle.
Freezer has a drain in the back under the cooling coil. Melt Ice from drain area with a hair dryer, check drain and clear, under bottom in back behind a removable panel you will find the drain exit from the freezer going into the drain pan. This drain line has a loop for air seal, make sure it is cleared.
Aug 08, 2008 | Maytag MSD2732GR Side by Side Refrigerator
Water is building up in the bottom of my side by side freezer and freezing.
sounds like you have a clogged defrost drain tube. removing back panel of freezer will give you acess to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somwhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials works awesome, after you clear it and all water drain down tube wrap a piece of solid copper wirearound the heater( black calrod heater right above the drain trough) and stick it in the whole maybe an inch or so. now everythime the heater comes on to defrost it will prevent the hole from freezing over
May 07, 2008 | Freezers
Freezer, water problem
you have a frozen defrost drain, first of all defrost all of the ice out of the drain pan behind the grate, once the ice is gone you'll see a drain hole that goes thru the floor of the refrig. you need to flush some hot water thru this drain.
I use a big syringe filled with hot water to do this it will force any sludge build up out of the drain tube into the drain pan.
kind of an easy fix even if you aint 10=)
Dec 20, 2007 | Refrigerators
Kenmore 57029 Side by Side Refrigerator Logo
56 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Jude24
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
