Paper Jam HP Color LaserJet 2840
Problem with paper jam. Unfortunately, after removing the bottom tray of the 2840, I could see the paper but was unable to pull it out without ripping. Now the paper is deeper in the machine and I cannot reach it.
Can you help please?
Tim.wulf@firstgroup.com
  • drysahra Jan 17, 2009
    Problem with paper jam. Unfortunately, after removing the bottom tray of the 2840, I could see the paper but was unable to pull it out without ripping. the paper was deeper in the machine and it was torn. I checked all the devices but i dont know where the paper is.
  • Anonymous Apr 11, 2009
    SAME
  • 42 Answers
Pull out the drum cartridge by it's green handle then
look for your paper at the timing roll section-there is a plate you can lift or release to access jams.
other than that the fuser unit on the rear of the mfc can be pulled out by moving two levers.
Posted on Jun 19, 2008
Jam in tray 2 bt there is not paper jams
There may be paper remnants left over from a prior feed jam. Please click the link below and select printers - jams and feed issues to find more info.
HP Color LaserJet 1600 Printer
Aug 21, 2014 | HP Color LaserJet 1600
Hp Color Laserjet 1600 says Jam in tray 2 bt there is not paper jams
Open the paper feed area and the printer, examine the paper feed path and make sure there isn't a page or piece of paper jammed in the path somewhere.
Have a HP Laserjet 2840..error reads "paper jam tray 1" there is no paper jam I can find. Help !!!
There are paper sensing switches above the paper tray. Most likely the actuator has fallen out .
Mar 30, 2010 | Xerox Phaser 6110 Laser Printer
Paper jam inside HP Color Laserjet CM1312 MFP, not related to paper tray and is deep inside where it cannot be pulled out
paper jam inside HP Color Laserjet CM1312 MFP, not related to paper tray and is deep inside where it cannot be pulled out
Mar 01, 2010 | HP Laserjet CM 1312NFI Color Printer
Says Paper Jam but ther is no paper jam
It appear from here that the exit sensor may be dirty and you can use canned air and blow it out.
You may also be missing the paper out sensor that is located at the bottom of the printer oposite of the paper tray when you pull it out. When the flag arm has fallin out, it will give a false paper jam error when the last sheet has printed from the tray, not knowing or detecting that the tray is now empty.
Jul 02, 2009 | HP LaserJet 4 plus Printer
Jam in print paper path HP 2840 printer
does the paper feed at all(1/2 way) no feed,if not pick-up paper most likely will be feed motor if 1/4,1/2 or 3/4 fed will be sensor at falt or 2nd tray conectors dirty or making false contact.
May 20, 2009 | HP LaserJet 2840 All-In-One Printer
Cant figure out how to open Tray 1 to clear paper jam
Leave Tray1 closed. Remove tray 2. Push down on green arrows visible after removing Tray 2. You should see the jammed paper on the plastic tray which becomes accessible after pushing down on the green arrows.
May 05, 2009 | HP laserjet Cp2025dn color Card Printer
Cut off printer during print, paper jam tray 2 won't release
Open the cartridge door and remove cartridge...can you see the paper here...if so slowly apply even pressure to both sides of paper and pull...
keep me posted
Cheers!
Nov 13, 2008 | HP LaserJet 2840 All-In-One Printer
Is it possible that you have the default tray set as "tray 1" (the one on top) and the paper is actually in tray 2 (the one on the bottom?)
If so, you should be able to press the "check" button & the printer will accept the paper in the bottom tray.
Shelley
Nov 06, 2007 | HP LaserJet 2840 All-In-One Printer
826 people viewed this question
jasbo
jasbo
