Question about Amana Dryers
Model NED5100TQ0 WAS WORKING THEN WE PUT ANOTHER LOAD IN IT AND NOW IT WILL NOT START CHECKED THE BREAKERS AND THEY ARE FINE WHAT ELSE CAN IT BE IT IS ONLY 2 YRS OLD THANKS
  • Amana Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Nov 11, 2010
Amana electric dryer NED5100TQ0 SHUTS OFF ATER 5-10 MINTES.
check the vent system,most common cause of motor over heat-shut down.if motor makes a loud noise at start up, motor is likey bad.
Mar 15, 2014 | Dryers
My dryer will only work for like 3 minutes and then it kicks out the breaker. It is an lg tromm dle3777w. It has worked fine for about 4 years. Used it for a load already today and it worked fine. ...
Hi - there is a fault with the heating circuit, most likely either a bad connection on the elements or elsewhere on the wiring. The only other problem would be the actual heater element, although doubtful as it would normally pop the circuit breaker instantly if this was the case.
Although i'm not familiar with this particular model all dryers operate the same way, when on air dry there is usually no heating involved, it will work ok.
If you can handle the repairs yourself otherwise get an electrician or appliance serviceman to help you out.
Jun 15, 2011 | Dryers
Dryer will not start. Circuit breaker fine. Just
Check for a blown thermal fuse. It is located just inside the rear of the dryer and is usually attached to the exhaust duct. It is about one inch long and can be tested for continuity using a multimeter or ohm meter. If it does not have continuity, then it is defective and will have to be replaced. Hope this helped and best wishes.
Aug 03, 2009 | Dryers
Dryer has no power
Have you manually reset your breaker? Sometimes breakers can seem fine but they actually aren't. Physically turn the breaker off and then back on. If this doesn't work, you will need to find out if your particular brand and model has a fuse that needs to be replaced.
Apr 08, 2009 | Kenmore 64602 Electric Dryer
Magtag Electric Dryer
Did you check the breaker closely. Dryers work on 220 volts, usually 30 amps and that means TWO 110 breakers attached together must be good and putting out 110 volts each. One may be burnt or disabeled and the other working. Also check at the  dryer receptacle and make sure you have 220 or more volts.
Mar 11, 2009 | 2001 Yamaha V Star 1100 Classic
Whirlpool dryer model LEQ8800JQ won't start when push start butto
I posted today (Jan 2, 2009) that I had same problem. Handyman tested for blown thermal fuse, etc and everything was fine. He said I have to replace the timer switch .. well guess what - I fidgeted with the start button (on/off) hard a few times while simultaneously pressing & releasing door switch and it did the trick. In my case the problem was most likely with the start button. Dryer is working fine now!
Jan 02, 2009 | Whirlpool LEQ9858P Electric Dryer
Maytag Electric Dryer Stopped Working
Check spring tab behind door switch-if it's bent/out of adjustment, circuit will act like door is always open.
To confirm this, open door, set dryer to active setting, and hold in door switch; if it comes on, then it's either the spring tab, or the switch is malfunctioning
Mar 30, 2008 | Dryers
Total Power Shut-Down - Can't get it to come back on
Hi , recock the breaker ,one the line was disengage..
Jan 27, 2008 | Kenmore 46462 Front Load Washer
Dryers Logo
340 people viewed this question
Top Amana Dryers Experts
Sal De
Marvin
Marvin
Android Man
Android Man
Are you an Amana Dryer Expert? Answer questions, earn points and help others
