Question about NetGear DG834PN Router (DG834PNAU)
Hi! my problem with DG834PN is about disconnection. The wireless, and so the router connection, randomly disappears, and the only way to get it back is to switch off the power supply and on again. If i try to get back the connection from 192.168.0.1 control panel, there is no way to Inizialize LCP again... it's like dead! I tried different security encryption, MUD level, SIP firewall, etc... the firmware is updated, and so on, but the problem of random disconnections still persists. What do i have to do?! Thanks, Daniele
sandrew
  • 2961 Answers
SOURCE: Wireless connection fails: won't assign address
As ever starting with the simplest of solutions normally works, well spotted.
Posted on Nov 28, 2006
Metawatch
  • 96 Answers
SOURCE: Wireless connection keeps dropping out
Somtimes thats enough....
Try moving the router and changing the angles of the antenna to see if you can get stronger signal strength...
Posted on Feb 10, 2008
SOURCE: Netgear Firewall
I have NetGear RangeMax WPN824. I work from home and need access to my desktop at work . I go thru Kaseya to access my desktop at work. I continue to get the same error: "Unable to connecto the KServer@216.186.253.12 on Port 5721. Check firewall, router or proxy server is allowing outbount TCP connection to 216.186.253.12 on port 5721."
Is port 5721 associated with the rangemax WPN824? If so how can I enable this.
Posted on Jun 07, 2008
SOURCE: The Wireless Signal keeps dropping out.
make sure that there are no cordless or wireless devices near the router such as a cordless phone since that will interfere with the wireless signal and a cause for frequent disconnection.
otherwise, the device should be replaced already.
Posted on Aug 24, 2008
redhaze89
  • 854 Answers
SOURCE: I keep losing my wireless connection.
Here are some troubleshooting steps that I suggest you try:
1. Check physical connections.
a. Connect the modem to the Internet port of the router. The Internet “i” LED on the front of the router should light up.
b. Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up.
2. Access the router's web-based utility.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. By default, the user name is "admin" and the password is "password".
Note: If you were unable to access the router's web-based utility, you may reset the router to restore the settings to factory default.
To reset the router:
a. Please push the reset button at the back of the router and release after 30 seconds.
b. Unplug the power adapter for 10 seconds and then plug it back in.
3. Configure the router.
If your Internet Service Provider is using a cable connection, please follow the steps below:
a. Click on Basic Settings under Setup tab.
b. Select No for Does Your Internet Connection Require A Login?.
c. Scroll down on the center page and look for the Router MAC Address section. Set it to Use computer MAC address and click on the Apply button.
If your Internet Service Provider is using a DSL connection, please follow the steps below:
a. Click on Basic Settings.
b. Select Yes for Does Your Internet Connection Require A Login?.
c. Select Other on the Internet Service Provider drop down box.
d. Enter your ISP's username (username@ISPdomain) and password. Then, click on Apply.
4. Configure the wireless settings.
a. Click on the Wireless Settings under Setup.
b. Change the SSID to any unique name.
c. Scroll down, look for the Security Options settings and select WEP (Wired Equivalent Privacy).
d. Set the Authentication type to "Automatic" and the Encryption Strength to "64bit".
e. Leave the Passphrase field blank, select Key 1 and enter a 10-digit number.
Note: The 10-digit number you typed in the key 1 will be the password or network key for the wireless connection.
f. Click Apply button to save the changes.
g. Go to Router Status under Maintenance tab and check if there is an IP address under Internet port. If it's 0.0.0.0, do a power cycle.
5. Power cycle.
a. Power off the modem, router and computers.
b. Turn on the power of the modem first and wait for it to initialize, the lights to stop blinking.
c. Power back the router and the computers. Check if it will be able to get online.
If you have wireless computers, you can connect them wireless to the router. Kindly follow the instructions below:
6. Connect wireless computer to the router.
If you are using Windows XP with Service Pack 1, please follow the steps below:
a. Please right click on the Wireless icon on the right lower end portion of your computer.
b. Then click on View Available Wireless Networks.
c. Click on the Advanced tab.
d. Please delete all the preferred networks then click on OK.
e. Right click on the Wireless icon again and click on View Available Wireless Network. Please select your network and click on Connect. It will ask you for the network key.
f. Please type in the network key and then confirm it. Network key is the password you type on the key 1 of the wireless settings of the router.
g. Make sure not to enable IEEE and then click on Connect.
If you are using Windows XP with Service Pack 2, please follow the steps below:
c. Click on the Change Advanced Settings.
d. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
e. Right click on the Wireless icon then click on View Available Wireless Networks.
f. Select your network and click on Connect.
g. It will ask you for the network key. Type in the network key and confirm it. Then click on Connect. Network key is the password you type on the key 1 of the wireless settings of the router.
If you are using Windows Vista, please follow the steps below:
a. Click Start then select Connect To.
b. Connect to a network window will show up.
c. Select your wireless network and click Connect.
d. It will ask you for a network key. Type in the network key and confirm it. Then click on Connect.
From the above configuration, please check if you can now access the Internet.
Posted on Apr 12, 2009
My new Laptop uses Windows 7. Will it connect to my DG834PN router?
yes it should work !
You will need to check the wireless settings of the router
is there any computer connected to the router ?
If yes then you can open the router set up page on that computer.
Router set up page is the page where you can check all the wireless settings of the router.
Click here for step by step instructions
Jan 26, 2010 | NetGear DG834G Router
No wireless connection with Vista or Linux
Please change the wireless channel on the router and check if it helps.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Jun 30, 2009 | NetGear Computers & Internet
Need my USB sprint card to connect with my wireless G router
Well - you are mixing up two different kind of wireless networks.
Your sprint card connects to the same network a cell phone connects to (EV-DO technology), while your local network at home uses a different technology (802.11).
What you need in order to connect to your Linksys router is a USB adapter like this.
If you have any more questions, just come back here and leave a comment - I'm happy to help.
Jun 11, 2009 | Linksys Wireless-G Broadband Router
Router randomly stops sending out wireless signal
You may be getting interference from other routers in your area.
Check to see what channels the other routers are broadcasting in your area, change it to a channel that is not being used.
The location of the router could affect the signal strength, move the router away from concrete reinforced walls etc, and or move the router to a higher position in a clear space.
May 22, 2009 | D-Link DI 514 Wireless Router (DI-514)
Setting up a wireless lan
The DG834PN is an easy to set-up, single box solution, it plugs straight into your ADSL line – there is no need for a separate modem. Once the DG834PN modem router is connected, configuration is also easy, via NETGEAR’s Smart Wizard™. The Smart Wizard™ automatically detects your ISP’s network settings, and then walks you through each step of the installation process. Or then Call ur ISP.
Thank You,
Your Tech Support,
Fixya.com
Manish Shirsikar
May 18, 2009 | Gigabyte GA-K8NS Motherboard
Wirless going down randomly
Hello ajestrella,
If your connection is a DSL, I think you need a "Micro Filter" to be connected to your phone lines. This will eliminate the disconnection or unwanted signals that causes you network to go off or disconnected. You can request this device from your telephone company.
Mar 11, 2009 | NetGear WGR614 Wireless Router
Netgear DG834PN ADSL ROUTER AND HUB - PC dial-up connection
so your trying to use a dsl router as just a router -dsl with dialup?
Aug 06, 2008 | NetGear Computers & Internet
NetGear DG834PN Router (DG834PNAU) Logo
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
