Question about Bosch 24 in. SGS45E02 / SGS45E08 Exxcel Free-standing Dishwasher
Cleaning the drain of a bosch dishwasher
We need to clean the bottom drain on our Bosch dishwasher but are unsure of how.
We removed an rinsed out the cylindrical filter, but there is still water in the compartment below, and sadly, there is some food floating in the water.
Do you have diagrams on line. I am not sure which model we have (it came with our house), so I may have to look through more than one.
  • mfetko Aug 18, 2008
    bosch dishwasher does not drain....need diagram of drain system
  • Anonymous Aug 26, 2008
    water will not empty or fill. machine is not working and makes a humming noise.
Had the same problem if you remove t20 screw on the left side of the bottom bowl & remove plastic cover this is the drain pump & can block with food or glass particles clean it out & check it revolves & should be ok
Posted on Jul 01, 2008
Bosch Dishwasher stopped draining
If you hear the pump running, but little water drains, then check hose, and clean out debris trap at bottom of dishwasher. That gets plugged and needs occasional cleaning.
Sep 04, 2014 | Bosch Dishwashers
Bosch dishwasher runs continuously
I would call Bosch with you.re model and serial number, they have had a recall on your model for the control board and that sounds like it may be your problem, if it is under recall Bosch will send someone out at no charge to install a new board (800) 856-9226
Jan 24, 2014 | Bosch Dishwashers
E:25 on bosch dishwasher ?
Bosch E25ErrorThe drainpump is blocked or restricted by debrisPossibly something stuck/jammed in the wash or drainpropeller, remove filter mesh at the bottom of the dishwasher. Carefully remove any excess water and debris jammed near the propeller caution there may be glassor debris near or where the water drains-out.Removeand clean the spray arms, they may have food debris jammed, rinse in hot runningwaterMaintainerWash Runa wash with a tablespoon of powder, without any dishes on the hottest settinge.g. intensive, 65C, if you have a 70C this will be more effective.
Apr 09, 2012 | Bosch Dishwashers
Dirty dishes & not draining properly
The problem is most likely that there is still water residue at the bottom of your machine. If the machine is not fully drained it picks up some of the residue and sprays that onto the dishes during the final rinse, leaving an unhealthy and unsightly film on everything.
Remove the bottom strainers and make sure that there is nothing obstructing the outlet pipe and the pump. If possible back flush through the outlet pipe and try draining the machine again before using it again.
Feb 11, 2011 | Bosch 24 in. SGS47E02 Exxcel Free-standing...
We have a Bosch dishwasher...model #shu4326UC. We have been so happy with it until recently. All of a sudden the dishes are not cleaned properly. We have to run the cycles a couple of times and are...
You likely have food or soap buildup stuck behind the trap in and around the drain workings. The only remedy it to remove the trap cover or lower arm assembly, and start poking around. The food finds its way into the tiniest of places and sits there, but it dirties up the rinse cycle. I have to clean mine out about once per year.
Nov 20, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch 100 series will not drain
You need to check and clean the pump filter if you have not already done so.
This is located at the bottom front right of washer.
Unscrew anti-clockwise to remove and clean.
Mar 15, 2010 | Bosch Nexxt 100 Series WFMC1001UC Front...
My Bosch classic 1200 express washing machine wont drain or spin
Possibly a blocked filter or pump.
Ths filter should be at the bottom right front of washer, sometimes behind a removeable cover at the bottom of washer.
To clean it, unscrew anti-clockwise, remove and clean.
Dec 09, 2009 | Bosch Washing Machines
Bosch dishwasher has standing water doesnt drain out, repair man pushed 2 buttons cancel drain and it drained last month, but happened again today and it wont work for me
Fixed mine very easily... After checking and cleaning the filters by the tub's drain, I checked the air vent atop the sink -- it had a small bit of gunk trapped in the outlet. Cleaned it out, ran a "rinse & hold" cycle and it drained the tub beautifully!
Apr 22, 2009 | Bosch Dishwashers
Bosch shv56c03uc/114 Water is not draining
Check drain hose first.
If you do not find any blockage, then you will need to access the pump, remove pump hose and look for blockage in there.
If there is no blockage at all, then either the water level switch, a faulty pump, a wiring problem, or a faulty timer board can be cause the machine not draining.
Apr 06, 2009 | Bosch 24 in. SHV56C03UC Built-in...
Bosch dishwasher cleans but will not drain.
Remove the drain hose where it attaches to the disposal. This area often clogs and will prevent any d/w from draining.
Feb 13, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch 24 in. SGS45E02 / SGS45E08 Exxcel Free-standing Dishwasher Logo
1,285 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
