Question about Sony Televison & Video
Re my SONY videoscope kpr46ex35: I get a picture sometimes for a few minutes then I hear a pop and then only sound comes out. Do you have any idea what this might be causing this?
  • 1 more comment
  • info16939 Nov 09, 2010
    We have not gotten any picture the last 2 times we turn it on. It is on, open and has sound. No picture at all now. I think the last pop was that, the last...
    We also found a noisy transformer but could not find any bad transformers or fuses.
  • info16939 Nov 11, 2010
    Do you know where i might find a detailed schematic so we can find these components?
  • Sony Master
  • 5,138 Answers
You need to remove the back on TV and Watch to see what is making the popping sound and where is it coming from? It sounds like one of the Tubes has a high voltage leak or Trippler block could be leaking high voltage or FBT flyback Transfomer could have a pin hole in it leaking out high voltage
Posted on Nov 09, 2010
  • 1 more comment
  • ladywinn
    ladywinn Nov 09, 2010
    CK the hori output Transistor if it is shorted then problem will be the FBT flyback Transfomer
    ACME 1-800-575-9833 Also CK the high voltage capaciotr (small blue cap) one that feeds to the hori output Transistor 2Kolts
  • ladywinn
    2k volt cap
  • ladywinn
    ladywinn Nov 11, 2010
    retrevo.com might have it, Do you know what the FBT flyback Transfomer is ?It will be on your deflection board and has 2 leads coming up and out.it should be gray FBT,over on the right hand side is the Hori output Transistor and next to it is the small blue capacitor,Look and see if this cap is burt hole on it.
HI I have a 1998 Sony Videoscope XBR 53 in. Projection TV. When you turn it on the sound is fine but sometimes the picture comes right on and sometimes it can take hours. Can anyone give me some advice....
hello well it's and old tv, my guess it could be capacitors in the power supply or even dry joints on the power supply board, it would be best to have someone with electronic experience to have a look at it
regards
shaun
Oct 06, 2010 | Sony KP-53S65 53" Rear Projection...
TV picture goes out after 10 minutes of viewing with popping sound
It can be a couple things. Something bad on the power board. Or the vertical output circuit. How long ago did you purchase the television. Your best course of action is to have it serviced.
If you need any information or other assistance let me know.
Thanks,
Lee
Jun 24, 2008 | Pioneer SD-582HD5 58" Rear Projection...
MY TV IS ON STANDBY WHAT DOES IT MEAN AND HOW DO I GET IT TO WORK I CAN HEAR SOUND AND CHANGE CHANNELS BUT NO PICTURE STANDBY LIGHT IS ON
my sony videoscope xbr was in storage for a while. I brought it home and let it warm up before I plugged it in. now the standby light blinks all the time. I have sound but no picture. any idea what to do?
Sep 13, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony videoscope XBR - Side by Side screens can't change it back.
Sounds like your TV has a PIP (picture in picture) that allows your AVI (audio visual input) to be viewed simultaneously with your cable input. Check the manual for the correct buttons, but the one you're looking for says either PIP or AVI or something along those lines. Hope this helps
Jun 11, 2009 | Mag Innovision InnoVision XJ 717 Monitor
Tv is on, after a few minutes it goes black and there is no sound. The indicator lamp is still green and stays solid the entire time. Without turning the TV off, in about a minute, you hear a small buzzing...
Someone else gave me the tip as I had the EXACT problem, but no buzzing. Unscrew the panel on the front bottom of the tv. Once that is off, there is another screw that opens a little panel. Unscrew the single screw with an allen wrench and pop out the bulb and casing. Mine was full of dust etc. Used an LCD cloth, but compressed air would do the same thing, put it back together and it works great!
Jun 11, 2009 | Sony KDF-E55A20 55 in. LCD Television
Temporary losing picture
CHCK THE OPTIONS MENU SEE IF IT HAS A COLOR CONVERSION OPTION ,,TRY THAT,,ALLIGN THE COLORS
May 14, 2009 | Pioneer SD-582HD5 58" Rear Projection...
Bigscreen won't turn on at all- no LED's, no sound/vid, get a relay click though
It might be the relay itself, you sound tech savy have you tried testing the transformer and various other main board componets?
Apr 25, 2009 | Televison & Video
TV has sound no picture, Sony Videoscope xbr
Please post both the exact model number (on the back) and the blink count. The standby light should be blinking a repeated pattern. That info will indicate the problem circuit and allow us to provide you with the proper parts/steps to resolve this.
Thanks,
Dan
Feb 10, 2009 | Sony KP-53XBR45 53" Rear Projection...
Picture not working on Sony Videoscope
YOU PROBABLY NEED NEW CRTS. UNIT IS GOING INTO IK BIAS SHUT DOWN WHICH MUTES THE VIDEO SIGNAL. YOUR SET IS OLD ENOUGH THAT IT WOULD BETTER TO GET A NEW SET. EST $1300.00 IF CRTS ARE AVAILABLE
30 YR SERVICER
APGONZO
Jan 01, 2009 | Sony KP-57WS500 57" Rear Projection...
2000 27" Sony Wega
Sony has a code for those blinks indicating the problem area. Count the blonks till the pause then google Sony blink codes for the area to fix.
Jul 03, 2007 | Sony FD Trinitron WEGA KV-29LS35 29" TV
Televison & Video Logo
64 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
