Question about Lands Phones
Batterie phones don't work( all new batteries) No dial tone on any jack- electric plug in phone do work on any jack.
    Sergeant:
  • 139 Answers
Check for the polarity again . You might inserted the batteries wrong. + to - and - to + ! Pay attention to the simbols on the batt. and on the phone batt place.
Posted on Nov 10, 2010
EL52500 Phone base & 4 handsets have static, message Line in Use. Bought new phone, charged, connected - it says no line. Have dial tone at phone line into house.
Sounds like your phone has a short. If you see the message "line in use" call your number, is it busy, now unplug your phone and call your number again, is it ringing? Indicates a short, possibly in your equipment. As for message " no line" is the electric connected to the phone and did you check for dial tone in tat particular jack with a known, working phone first...just to make sure there's dt @ the jack. Good Luck :)
Nov 19, 2015 | AT&T Lands Phones
How do I reset my phone to reset to get back in range it says out of range anyone have instructions ?
Unfortunately, I do not have a manual for the GH-4102. However, most cordless phones get out of range messages at a few points: low handset battery, no power at the base or no dial tone at the base. Other possibilities are the phone base and handset lost the registration or one or the other isn't transmitting/receiving properly.
Things to try: unlpug the base power (from both the wall outlet and the phone) and phone line cord and remove the battery from each handset. Wait a few minutes and then reconnect the batteries and plug in the power and data connections. (Check when you unplug the base power adapter if it was warm; that indicates the unit was at least getting power at that point.) Recharge the handset batteries and then re-register the handsets, if needed.
Consider replacing the handset batteries if they are more than a year old (this includes the time that the phone may have been on a shelf after manufacturing). Try a new phone data cable (RJ11).
Next test your phone line and make sure that you have a dial tone. I like to use an old corded phone with the new phone cord for testing. If there is no dial tone, test the line at another jack. If there is still no dial tone, find your incoming phone line and open the service box. If you have a relatively new service, you will be able to plug your test phone into the service box and test there. If you can't test the line or there is no dial tone at the service box, contact your telephone company. They will test and fix outside problems for free.
If the problem is inside, look at all accessible wiring and make sure that the lines aren't damaged. If only one jack is bad, open the faceplate and fix any loose wires. There are two types of connections. The first holds the conductors under screws and the wire must be stripped back and secured. The other uses a keystone jack. The conductor wires are not stripped but a special tool punches the wires into place. You can find the punch-down tool at many hardware/home improvement stores in the wiring section. See http://www.lanshack.com/wire_phone_jack.aspx for a picture of the correct wiring for the jack.
If your phone line has a dial tone and the above fixes didn't work, contact the company and get the phone repaired if it is under warranty (usually 1 year). If it is out of warranty, then decide if it is worth repairing or if you should replace the unit.
I hope this helps.
Jan 09, 2012 | Southwestern Bell GH-4102 Twin Cordless...
HELP?Why Does my telephone say connecting?
Most cordless phones will say connecting when the handset is out of range, the base has no power or the base does not have a dial tone.
I start my tests at the base and make sure that another phone (preferably an old corded phone) gets a dial tone at that jack. Try a new phone cord to check if the cable is bad. Check if the power brick for the base is warm and that the outlet has power. For some phones, you can reset them by unplugging the base and removing the battery from the handset. Then reconnect the battery and plug in the base. Check if the handset and base can communicate (try the Find Handset option). If needed re-register the handset.
If the test phone doesn't get a dial tone, then you need to find where you have a wiring problem. Try the test phone at another phone jack. If there is still no dial tone, find the telephone service box (where the phone line comes in). If you have a fairly new service, you will find an RJ-11 jack in the box. Plug in your test phone and check for a dial tone. If you have no dial tone, contact your phone company. They will come and fix the line for free. (If you can't use an RJ-11 cord at the service box, your phone company will test this outside connection.)
If there is a dial tone at the service box or at one jack and not another, it's an inside wiring problem. Look at any open wires (perhaps in the basement) for obvious damage. Open the jack and check for loose wires. (There are two types of jacks - one wraps the wire around a screw, the other requires a punch down tool to secure the conductors in the keystone. The conductors should be connected to the terminals in the correct order. To see a picture of the terminal connections that are used, see http://www.lanshack.com/wire_phone_jack.aspx . The punchdown tool is available at many home improvement stores in the wiring aisle.)
If your test phone had dial tone at the original jack and resetting the phone by disconnecting the power did not help, then the phone needs service. If it is under warranty, contact V-tech. Otherwise, you may be better off replacing the unit. These phones are not meant to be user serviced.
I hope this helps.
(if you add a comment with the model, then I will check if I can provide more details in my solution.)
Sep 28, 2011 | Vtech DECT 6.0 Cordless Phone with Digital...
I have a philips telephone/fax machine with 2 handsets, the handsets have stopped working, there is no dialling tone and they won't let you reset them it tells you not possible. What can i do? thanks...
TRY UNPLUGGING...WAIT A FEW SECONDS, THEN PLUG BACK IN...THIS SHOULD RESET YOUR PHONES. IF THE BATTERIES ARE CHARGED!
IF YOU DON'T HAVE A DIAL TONE, YOU MAY HAVE A FAULTY PHONE BOX, (LOOSE WIRE ETC,.SOMEWHERE)
OR IT IS POSSIBLE YOU MAY NEED TO REPLACE YOUR BATTERIES, I WOULD TAKE THE BATTERIES OUT AND RE-INSTALL THEM IN OPPOSITE PHONES.
IF YOU COULD PROVIDE ME WITH THE MODEL NUMBER, I COULD RESEARCH THIS FURTHER FOR YOU.
ALSO...DO YOU HAVE A DIAL ON YOUR FAX MACHINE? IF SO...THEN TRY HOOKING YOUR PHONE'S UP TO THAT PHONE JACK...TO SEE IF THEY WORK!
LET ME KNOW...WHAT HAPPENS?
KIND REGRADS!
MARTIE
Sep 08, 2011 | Cell Phones
The phone is not ringing and it is plug on charge and my wife got new battery for it too. What can i do to get it working? What size of Batteries cani use for this cordless phone
You need the specific battery pack: 5-2814 for the handset. This is a 850 mAh Nickel Metal hydride battery.
When I see a cordless phone that doesn't ring, the first thing I recommend checking is the phone jack and line itself with a second phone. I prefer to use a corded handset with a new phone cord to check for dial tone. If no dial tone at the jack, check for dial tone at the service entry box. If you have no dial tone at the service box, contact your provider. If it's only a problem at the jack, you will need to check your inside wiring.
To check the base, try a new cable (RJ-11) (double check the power as well).
To check the handset, first make sure the handset is fully charged (16 hours) and that the battery is fully installed. Does the handset beep when the Talk button is pressed? Next check that the handset ringer software is on. With the phone off (not in the talk mode), press the Mute/menu OK button. Use the Caller ID/volume (up/down) buttons to get to the Handset setup menu. Press the Mute/Menu OK button to access the menu. Use these buttons to check the Ringer Volume (should be on) and Ringer Tone. Press Mute/Menu OK to save the settings at each sub-menu. Check that the Do Not Disturb function is not on - this toggles with the Do Not Disturb button and should be noted on the handset screen when on.
If you have multiple extensions on the phone line, try unplugging some of them.
I hope this helps.
Jul 07, 2010 | GE T28821FE2 19 GHz Twin 1Line Cordless...
My phone is practically new, battery fully charged, however, I cannot get a dial tone.
Check all your connections, something must be loose, or not plugged in correctly. If you are on VOip, then you have alot to check...make sure that the cord is plugged into the "phone jack" on the back of the router, and you need to plug the base into the electric wall outlet too.
Sep 14, 2009 | Uniden Cordless Phone
My GE phone 27958 just stopped working. I originally thought the cordless handset needed a new battery, but upon replacement that did not help. I found that the base which is plugged into the land line...
check power ?
Is Ac - DC converter pack plugged into power point ?
Is the DC plug plugged into the phone ?
does power point work ?
Check correct dc voltage being produced from the AC - DC power pack converter ?
Isolate other phones on other extensinos to see if uniden is cause or not of no dial tone.
You may have another phone off hook and phone line has timed out .
Jun 11, 2017 | Uniden Cordless Phone
Just bought phone no dial tone i move the setting to pulse
First thing to try is another phone in the wall jack if it doesn't work either you need to call your phone company. If the other phone works, make sure that the telephone is getting power from the AC electrical outlet. Try swapping the telephone cord with another cord. and lastly, unplug the battery from teh handset and plug it back in untill you feel it click into place. Sometimes the new battery connections are pretty tight and may not really be connected even though it looks like it is plugged all the way in.
Mar 23, 2009 | Uniden 5.8GHz Dual Cordless Phone
Dial Tone Appears and Disappears
Any store offering phones will have replacement cables for low prices; replace this first. Your wall jack could also be damaged although the ones used by installers is generally very long-lived.
Aug 01, 2008 | Sony SPP IM977 Cordless Phone
Dial tone
I disconnected the RadioShack phone/answering machine and plugged in an old phone. At first I didn't get a dial tone, but in a minute or so, I did get one. I doublechecked the connection with the incoming phone jack. (I had checked this before, but didn't see anything wrong.) Again, I didn't see anything wrong, but maybe that did it. Also, when I disconnected the RadioShack from the incoming phone jack, I disconnected from my computer (I used to have dial-up connection).
Don't know which of my actions worked, but now I have dial tone on Radio Shack.
Hoooooooray!!!!
Jun 22, 2008 | Radio Shack 433575 Cordless Phone
Lands Phones Logo
23 people viewed this question
Top Lands Phones Experts
David Burbee
David Burbee
Are you a Lands Phone Expert? Answer questions, earn points and help others
