Question about Hotpoint Washing Machines
Hotpoint Ultima WMA 61 has started being very noisy when spinning. Can turn drum manually but has metallic sound. Is it a bearing problem and can I fix it ?
  • Hotpoint Master
  • 3,463 Answers
It will be the main drum bearings that have failed.
It can be repaired, but it is an involved job as it involves a complete strip down, not a job to undertake lightly, if it is more than 5 years old, I would recommend you replace the washer.
Posted on Nov 09, 2010
Is it possible to change the bearings on this model?
sealed units are separate to the tub and drum
I would first remove everything down to the outside drum as the noise could be from an obstruction ( coin/s bra wire, metal objects etc)
At 3 years I would not expect bearing trouble in a sealed unit so explore all other avenues of the noise first
bearings will be noisy at all cycles and not specifically at high speed spin
before you touch it -check the warranty period and if inside that period call the technician
Feb 10, 2016 | Hotpoint Washing Machines
Hotpoint ultima washing machine wma74 drum not turning
If the machine wasn't excessively noisy before and when you select spin only you can't hear the motor running its likely to be the carbon brushes in the motor worn down till they no longer contact stick a new set in if the carbon length sticking out the brass holder is less than around half an inch long
Dec 08, 2013 | Hotpoint Ultima WF860 Front Load Washer
Very noisy spin wf860
hi if you turn the drum by hand can you feel a slite rumble if you can it will be your drum bearings common problem on a machine that has had alot of use
Oct 30, 2011 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint WMA 32 washing m/c noisy drum
is poss bearings or something stuck between the inner and outer drum
Jan 03, 2010 | Washing Machines
Hotpoint wt960 ultima, very noisey when on spin
Remove lower rear panel of washer, remove belt and spin drum by hand, if it is noisy or feels rough, then main drum bearings have failed.
If no noise, then look elsewhere for prob..Could be noisy motor, or loose concrete balance wieght.
Please rate my solution.
Thanks.
Aug 27, 2009 | Washing Machines
Noise when spinning
Remove drive belt and spin drum by hand, if it is noisy, or feels rough, then the main bearings have failed, if no noise, then check for noisy motor bearings.
Thanks.
Jul 18, 2009 | Hotpoint Ultima WF860 Front Load Washer
Started having a noisy rinse & spin cycle, then stopped.
Open the washer door and spin the drum by hand, if it feels rough or noisy and rumbling, then the main drum bearings have failed. There should be little or no noise when you spin drum
This is a major repair, and I would not recommend a D.I.Y solution.
Other possibility is there is something in the pump, but you would only hear this when the pump is working.
Plz rate my comments.
Thanks.
Jan 07, 2009 | Hotpoint Aquarius WF210 Front Load Washer
Door locking & drum noisy
It sounds as though the main drum bearings are failing, if you spin the drum by hand and it feels rough or sounds niosy, then it is definately the main bearings. there should be little or no noise when you spin the drum by hand.. Re the door lock,I do not think the two problems are related, could be a faulty door lock that is taking too long to release.
If the m/c is under 5 years old, then you should be able to get it put right under Hotpoint 5 year guarantee
You pay for labour, all parts are free, and in your case the cost of parts, would in excess of £100.00
So it would be worth a phone call to Hotpoint to confirm if you are covered.
Plz rate my solution,
Thanks.
Jan 05, 2009 | Hotpoint WMA64 Front Load Washer
Hotpoint Aquarius WF 430
Best way to check if the main drum bearings have gone is to;
  1. Remove back panel of washer
  2. Remove drive belt.
  3. Spin drum by hand from the inside of the drum, if it feels rough, or is noisy and rumbling, then the main bearings have gone.
If there is no apparent noise, then you will have to investigate further.
If I can help further, pleas let me know.
Plz rate my solution.
Thanks.
Oct 31, 2008 | Hotpoint Ultima WF865 Front Load Washer
Noisy spin loose drum
drum bearing need need bearing kit and drum support £60 plus labour at similar price. Appliance Doctor
Feb 02, 2007 | Hotpoint Ultima WF860 Front Load Washer
Washing Machines Logo
150 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
