Question about Bose 601 Main / Stereo Speaker
Where can I buy replacement speaker grills for a set of bose 601 series III speakers
SOURCE: Repairing BOSE 901 IV series speakers
The grille will come off if you try to pry it off. Then, unscrew the bad driver. Sort of new ones are sold on E-Bay for not a lot of money. Install the new driver, secure it with screws, and snap the grille back into place.
Posted on Mar 08, 2007
SOURCE: Bose 901 VI speakers used with sub woofer and Bose mo. 141 rear speakers
just connect 2 speakers to each output.
Posted on May 18, 2008
SOURCE: bose 901 series II speskers
To remove the stapled grilles, have a look at:
http://www.audio-circuit.dk/Schematics/Bose_901_I&II_SM.pdf
To go further and remove one or several drivers, remember that these speakers are air-tight (acoustic suspension); Don't break gaskets.
Posted on Jul 09, 2008
ward_knutson
  • 64 Answers
SOURCE: Can I hook my TV directly up to Bose 201 speakers?
It depends on the TV audio output connections. Most TVs have low level audio outputs (RCA Jacks) that require a amp but some do have external speaker connections. You will have to refer to your manual or check the back of the set.
Posted on Nov 25, 2008
SOURCE: compatable receiver list for Bose 901 series VI
I contacted the Customer support folks at Bose. Here is what they said: With a stereo receiver, the equalizer is run through the tape monitor section in the back of the receiver. The receiver's tape monitor output, left and right, runs to the amp input section of the equalizer, left and right. Then the amp output section of the equalizer, left and right, runs to the receiver's tape monitor input section. With a surround sound, home theater, type of receiver, the theory is the same, but the connection is through the preamp-out/ main amp-in section of the receiver. Not all receivers have this feature. Most, in fact, do not. Check the back of the receiver. There would be a connection made by two U-shaped clips. The plugs would be pulled out. Then connect from the preamp-out to the equalizer's amp input section; and from the equalizer's amp output section to the main amp-in. This effectively isolates the equalizer so that it is not affecting the other speakers in the system or the receiver's surround processing. Attached is a current list of known 901-home theater compatible receivers:
Note: Specifications subject to change without notice. Bose Corporation is not responsible for any inaccuracies due to manufacturer changes. Inclusion in this list does not indicate an endorsement by Bose Corporation. When in doubt contact the manufacturer of the equipment.
I have the list in a pdf document but do not see a way to attach it.
Contact me at danmc@uwyo.edu and I'll forward the pdf.
1-30-2009
Posted on Jan 30, 2009
Need to know how to setup
Search Results
    Bose Support - Owner Manuals
    worldwide.bose.com/axa/en_au/...manuals/page.html
    Bose CorporationFind Bose product informations for headphones, multimedia speakers, stereo speakers, whole home products, home theatre systems and speakers and music ...‎Music systems - ‎Home theatre systems and ... - ‎Headphones - ‎Multimedia speakers
    Bose Support - Owner manuals for Multimedia speakers
    worldwide.bose.com/.../multimedia_speaker_manuals/p...
    Bose CorporationProduct Name. Downloads. SoundDock® Series III digital music system. Owner's guide. SoundDock® 10 digital music system - Sold from 2009 to present.
    Bose Support - Owner Manuals for Music systems
    Bose CorporationFind product information and owner manuals for Bose Music systems, Wave, Wave system ... Home theatre systems and speakers ... Multimedia speakers.
Jan 25, 2016 | Audio Players & Recorders
Where can I get a set of crossovers for the Bose 601 series III
Bose don't sell a lot and indoubt you can order them at bose, i think they say: let it be repaired at a bose certified shop
Sep 18, 2014 | Audio Players & Recorders
Replacing cones on my bose ps28 series II
Use a small flat screwdriver to lift the front grill from the sides.After detaching the grill,unscrew the plastic guard to have access to the speakers and then unscrew the speakers.
Mar 04, 2018 | Bose Lifestyle 28 System
To Mr. Hyde: you appear experienced with Bose 501 Series III speakers. I need to replace a burned out glass bulb fuse inside the right speaker, the fuse for the woofer I believe. I think that you said that...
Hello whit_hughes,
Just received your request for some information regarding Bose 501's......... Series III. Your looking for te manufacturers part # for the fuse which is in line with the woofer? The fuses used ON the Series III Crossovers (hard wired/soldered directly to crossover board/componants) have been Identified as BUSS #2494, 2amp, Quick-Blow Glass Tube Type Fuses. The fuse which is in-series with the woofer & the fuse which is in-series with the pair of tweeters are the same! In theory this means that the woofer is capable of twice the wattage of the tweeters due to the tweeters being wired in series with each other..... which in turn divides the power beween the two equaly. On the woofer circuit there is only the one speaker or voice coil obsorbing the power. The woofer circuit being wired in parallel with the tweeter circuit again splits the power between the two cuircuits..... so in an ideal situation the woofer sees 50% total input power while the tweeters each see 25% total input power;;;; totaling 100% total. The way Bose has fused them in the Series III's is such that each branch can obsorb a total of 2 amps before shutting down each indivigual branch. This can be adventageous..... should peak power be exceeded causing loss of full load abruptly, Amplifier Power Output Transistors usually blow..... however when only half of the full cuircuit shuts down due to peak power exeeding limits causing one fuse to open (blow) ... the actual impedance (resistance) of the speaker increases protecting the Amplifiers Output Transistors! Thats the reason for the 2 fuses. Each of them are identical. They are soldered into place.... via the wire which is attached to each end of the fuse. (Note; the fuse "kit" Bose is trying to sell you is an external in line fuse holder for each speaker {costing 1.29 each} & 2 fuses for each holder, One for now & One for Later aftr it blows {costing 1.00 each}..... costing Bose 6.58, neting Bose $13.42 Profit!!!! Keep in mind that this fuse WILL NOT FIX YOUR PROBLEM EITHER! DUE TO THE FUSE WHICH IS PRESENTLY BLOWN HAS NOT BEEN REPLACED!!!!! ) The one that has to be replaced is on the crossover... not between the Amplifier & the Speaker Enclosure. Tools required = 1 Long Big Straight Blade Screwdriver to pry off speaker grill, 1 Phyllips Screwdriver to remove screws seccuring woofer to encloser... be carefull not to damage/tear gasket, 1 pair side cutters to cut blown fuse out of crossover curcuit, 1 pair needle nose pliers to attach NEW fuse to crossover curcuit, 1 soldering Iron & a small piece of solder to re-solder fuses leads securly to crossover curcuit. ( replace gasket, woofer, screws, & speaker grill. ENJOY! Should additionaL informaton be required please let me know.... you'll have to leave me your e-mail address for pictures or drawings.... as I don't think they can be sent through this site. Hope this helps ya..... Its an EASY JOB...... you CAN DO IT! & will be glad you did when your done, they'll sound GREAT! ) GOOD LUCK!
Jun 22, 2011 | Audio Players & Recorders
Not sure of how to wire these speakers ( internal ) Bose 901 series iv
Found on Google Search: "bose 901 internal wiring" You must first identify which series you have. The first two series were acoustic suspension, and used nine 8 ohm drivers in a series/paralel configuration. Series III through VI used nine .9 ohm drivers all wired in series. Series III and IV had an additional terminal for use only with the Bose Spacial Control Receiver. Series III through VI are easy to identify, as there are three ports sticking out the back of each enclose. The 1st two series have no ports.
Jan 17, 2011 | Bose 901 VI Main / Stereo Speaker
How do i remove grill from acoustimass cube speaker ?
This is really easy - although Bose don't tell you how in their user manual.
The grilles are snap on and the fixing lugs are located in the centre of each side.
All you have to do is insert a very thin flat blade screwdriver or knife blade between the grille and the speaker body at the centre of one side and gently lever it up about 1-2 mm.
Then, whilst leaving the first screwdriver (or knife) in place do the same on one of the adjacent sides - the corner of the grille should then "pop" up and you can then remove it gently by hand.
I did this so as to be able to clean a grubby set of white grilles by washing them in soapy water - came out looking like new...
Jan 16, 2011 | Bose Acoustimass 5 III System
Bose audio input receiver cable 15 pin
You can buy it on ebay but it's cheaper just to make one. If you can solder, all you need is a female 15-pin d-type connector and a bunch of speaker wire. Here is a diagram of the connections.
Jun 24, 2009 | Bose Acoustimass 10 III System
Apr 24, 2006 | Bose 901 VI Main / Stereo Speaker
Bose 601 Main / Stereo Speaker Logo
600 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Steve Allison
Steve Allison
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
