Question about Samsung PCL545R 54" Rear Projection Television
Picture blury i have a samsung 54inch rear projection tv and its picture is blury. i also tried adjusting the focus bt cldnt locate where the adjuster is located. can u help me with these?
  • Samsung Master
  • 8,617 Answers
Its behind the speaker grille up front , remove the grille and then a small access panel and you will see the focus control with 1 button for each CRT 3 buttons in all.
Posted on Jun 16, 2008
We have a Hitachi LCD rear projection Tv, 42V710,42V715, The picture has alot of green in it, tried ajusting the color, still a hint of green. It was fine until about a month ago. Every thing esle is...
You need to adjust the Green Screen Drive Located on the Focus/Screen Control Block Their will be 3 on Top to adjust Focus to each Tube R/G/B and under it is 3 Controls to adjust Screen Drive to each Tube R/G/B . Cleaning the mirror and Top of Tube Lenses will help improve Picture also if they are Dirty. Control Block is Located behind Front Bottom Panel Pull it off and you should see it.
Oct 05, 2010 | Hitachi 43UWX10B 43" Rear Projection...
Picture is bluring...especially the writing..
If you are comfortable working inside the set, locate the flyback transformer (part with large red wire coming out the top.) This part should have 2 controls on it. One should be labeled screen and the other focus. Try adjusting the focus control a bit. If that fails to resolve the focus, please update this with the make and model and additional details will be supplied.
Thanks,
Dan
Jun 13, 2010 | Zenith IQ5299DT 52 in. Rear Projection...
My tv needs readjusted (color,focus,etc.)Is there an easy way to do so myself? i got a 1986 45'' RCA projection tv.it started of with just a blury spot across the top but after i messed with it the whole...
First pull back Look for screen and focus block you will have 3 controls ontop for focus and 3 controls below for adjusting screen drive to each Tube R/G/B
turn color off on Menu NOW try to Adjust the red,greenand blue screen drives as close asyou can to a Black and White picture then turn Color back on in Menu also adjust Focus for each Tube Be sure to Clean Top of Tube Lenses of dust&dirt Just in case Post me your Model and Chassis Number it will be on back of TV some RCA Focus&screen drive Block maybe in front of TV if so remove front bottom panel their you will see control box.
Nov 10, 2009 | Televison & Video
Half of the screen is clear and left side of the screen is blury
Its a Common Problem with Projection Tv's ~ If your flash focus is not correcting the problem, And It can Not be Adjusted in your service menu: under Manual Convergence, your IC chips and maybe a few resistoirs may have failed and need to be replaced!... onegeo
Jul 07, 2009 | Sony KP-46WT500 46" Rear Projection...
Blue gun out of focus
There is a manual focus adjustment above and between the red and green gun, located in the front of the TV behind the panel; It is a small black box about 3X3" . This has all three adjustments .
Apr 21, 2009 | Samsung HCM5525W 55" Rear Projection...
The picture is blurry. does anyone have a solution to this or has anyone had a similar problem.
I have a blurry screen and the top of it the picture is curved a bit. I was told to adjust the focus knob but I don't know where that is in the back of the TV. I took off the back and couldn't find it. I also tried to adjust the manual convergence and the red would not adjust only the blue would align. Any suggestions.
Nov 05, 2008 | Samsung HCM422W 42" Rear Projection...
TV, RCA MOD # F19424, CTC 203U5, Picture blury
Focus and Screen. The focus control may help, just like focusing a set of binoculars or an old camera. Watch the picture on the TV, using a mirror can help and make an adjustment until the picture is as clear as you can get it. If it still is not clear it may mean that your picture tube is weak.
If you can avoid it, don't touch the Screen control. If you have, let me know and I can advise you on the proper way to adjust it.
Oct 09, 2008 | RCA Televison & Video
Blury picture
Check the connections on the CRT circuit boards. there is a red wire that slides into the white plastic socket make sure that is connected good, If that doesnt help you may need a replacement focus block, But if so they are very cheap and very easy to install, and I can post a link where you can get one if you need it.
Jun 16, 2008 | Samsung PCL545R 54" Rear Projection...
Focus block is at max still blue
the convergance amplifier have failed there are two of them they need to be replaced. there may be some pico fuses and resistors also. convergance failure is the most common rear projection tv it makes the set appear blury.
Feb 21, 2008 | Hitachi 46F500 46" Rear Projection...
My samsung projection tv #pcl5415r don't want to perform perfect focus adjustments
perfect focus functions are based on service mode setup...or factory settings. if the alignment of these setting are loss then the unit wont perfect focus. does the unit have a complete loss of convergence. a complete loss of convergence indicate possible failure of convergence amps.
Jan 03, 2008 | Samsung PCL541R 54" Rear Projection...
Samsung PCL545R 54" Rear Projection Television Logo
80 people viewed this question
Henry  Thomas
Henry Thomas
