Question about Orion1934 19" TV
20" orion tv
I can hear the sound, but the only picture it has is a thin strip across the middle of the screen.
    Genius:
  • 1,139 Answers
Hello mel2003,
This problem is caused by the loss of vertical deflection. Either the vertical output section of your TV or the vertical coupling capacitor has completely failed. In any event you will have to have a TV technician fix this set, BTW I hope you have not been playing the TV with the line on the screen this will burn the TV screen.
I hope this helps
Thank you,
Shuttle83
Posted on Jul 16, 2008
I turned my television on then it made the tv frame made a noise!and now the screen is black except for this thin line across the middle of the screen which is display the picture
Most likely the vertical oscillator circuit has failed. As CRT televisions have gone the way of the dinosaur, my advice to you is to give a fond adieu and invest in a new TV.
Nov 05, 2015 | Televison & Video
When I turned on my Durabrand 1907A the sound was clear but the picture was a thin strip across the screen and I can only see the middle of whatever is on television. Can anyone help?
Out of focus picture. Contact any service technician.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Aug 13, 2014 | Televison & Video
LG 32LH30 LCD TV Problem
IMO Seriously for $119 it's not worth it.
However, it does sound like a capacitor problem
If you are "Serious" about fixing I'd find a TV repair Forum.
Else I'd go here and get a new one.
https://www.walmart.com/browse/electronics/32-inch-tvs/3944_1060825_2489948_7156390
Best Wishes.
Apr 29, 2017 | LG 32LH30 32 in. LCD HDTV
Toshiba 26DF56 Problem
Yes,Ur horizontal ic is dead or cold solders.Hit the back tv cabinet see pic come back,tap the main PCB resolders,or replaced IC probally not manufacture's anymore.
Jan 15, 2010 | Toshiba 26DF56 26" TV
SanyoTV-blk screen w/thin line of light across screen great sound
Your Vertical Amp is probably Blown (bad) , but before you change that check all capacitors around the vertical amp IC and / or resolder resistors and diodes around vertical amplifier.
And NO it is NOT the Picture Tube
Good Luck
JG
Apr 18, 2009 | Sanyo DS27820 27" TV
Line across the screen
dry joints on the field output ic is a fairly common problem with these.if a firm slap changes things,a simple resoldering job does the trick.resoldering is usually the cure ir the fault was intermittent.otherwise the ic may need to be replaced.cheap as chips,so to speak.hope this helps,steve.
Nov 05, 2008 | Orion STV2763 27" TV
20" orion tv
The thin strip is possibly a combination of bad parts on your main board. You possibly have a bad horizontal output transistor and or a bad flyback transformer. All of witch should not be repaired by the average homeowner. These sets could have upwards of 30,000 volts inside even when unplugged!! Please dont forget to rate this answer for me ! Good luck!!
Aug 19, 2008 | Televison & Video
Orion TV model TV_798 sl (thin line no picture)
problem is with the vertical output circuit. take it to a repair shop and have them fix it.
Sep 15, 2007 | JVC AV-27D302 27" TV
Tv not working
this symptom, sometimes called the tube light effect, it is characterised by a bright thin horizontal line across the middle of the screen. this symptom is caused by a breakdown in the vertical deflection circuit. hence maybe the trouble maybe in the vertical oscillator, amplifier or output circuits. but if all i have said is not clear to you, better bring it to a qualified tv technician. good luck!
Mar 08, 2007 | Sanyo DS31590 31" TV
Orion1934 19" TV Logo
127 people viewed this question
Top Orion Televison & Video Experts
wayne chamberlain
Jerry Greenberg
Jerry Greenberg
Are you an Orion Televison and Video Expert? Answer questions, earn points and help others
