Question about Whirlpool Duet GHW9150P Front Load Washer
The below mentioned product is in dead condition. That is it never turns on due to some fault.
  • 190 Answers
Please press and hold the end of cycle signal button for 10 seconds and try it again. If that didn't work then unplug the unit for a minute and try it again. Then if that doesn't work, then you have to replace the front interface control board which controls input from the front panel. Regards.
Posted on Nov 09, 2010
My toshiba satelite pro processor is performing an internal heating and the fan will nt roll? Whats the problem
Hello. The fan it self could be tangeled up with hair or the the fan can be dead and needs to be replaced. Good Luck.
May 20, 2014 | Computers & Internet
Runs rough
The problem of rough running of vehicle may also arise due to following reason other than you mentioned and they are listed below:
1. Bad gasoline condition
2. Clogged Air Filter
3. Poor fuel filter
4. Discharged battery
5. Low oil in reservoir
Check for the components and solve the issues. Cleaning or replacing the air filter and fuel filter can solve the issue. Charge the battery if it is discharged or replace it with new one if in bad condition. Refill the oil reservoir.
Jun 23, 2013 | 1999 Ford Ranger SuperCab
Refrigerator freezing even when you turn it down
Your refrigerator is freezing due to the unit most likely haveing a defrost issue. This is usually caused by the defrost thermostat, the defrost heater, or the defrost timer or adaptive control having a fault condition. If you remove the rear panel in the rear of the freezer it will give you access to the evaporator coil. Located to one of the side usually clipped onto one of the copper lines you will see a small circular round sensor with two wires coming from it. Unplug the machine and defrost with a hair dryer any ice build up on the evaporator coil. If you have a multimeter you can perform a ohms test to assure that the thermostat is working properly. A defrost thermostat usually has an ohms reading of at least .50 ohms or higher. Located under the evaporator coil is the defrost heater. If you unplug both sides of the heater you can also perform a ohms test with a multimeter which would usually read around 21 ohms or higher. Most often this issue is caused due to the defrost thermostat due to this part being manufactured poorly on most all machines. If you find that you have a positive ohms reading on both these mentioned parts. You would then look at the defrost timer or adaptive control as the part causing the fault condition. I will await your reply and to you testing these first two parts before further posting how to test the defrost timer.
I await your reply,
Thank you,
Rick
Dec 31, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
1996 year model
Please mention details of the fault so that we are able to answer or give any solution.
You need to mention make/model of the set with the observed fault condition.
Jul 25, 2011 | Samsung Televison & Video
0xf0af8004
These error codes indicate that the product has an internal condition.
follow the instruction mentioned in the below link
http://fixmypcandmac.com/questions/how-to-remove-error-0xf0af8004-on-printers/
completed all the steps listed in the link and if still experiencing a problem, service the product. or contact HP technical support for assistance.
Jun 17, 2011 | Office Equipment & Supplies
When I turn on tv,it shows a white screen and don't anything do
Hello
You haven't specified anything about your TVs sound condition. If the sound is there and only the picture is out, leaving a white screen behind, it is due to the R-G-B output section of your TV. The section mentioned above comes on the picture tube base card, a circuit board connected on the neck of the picture tube, directly pluged onto it, with the help of a socket called picture tube base socket. You just measure the voltage to it first. The main voltage comes to it from the secondary voltage winding from the line output transformer, [LOT], generally, or from the SMPS power supply itself. It will come upto 260VDC, and must be there. If this voltage is missing, the fault you mentioned will occur. If this voltage is there, the fault may be due to a decective video output section. It may be built in with transistors, or an integrated circuit [IC].
Usually, Samsung uses Philips IC, number [TDA 6007B], or its equivalent in this stage. Check for any loose, or bad soldering on the terminals of this IC. I advice you to resolder all the pins of this Ic, by applying a little more soder, without making any short circuit bridges in between them. zin most cases, this will solve the problem. If it doesn't help, replace the IC with an identical in type and number.
If you wants anymore asistance, feel free to get me through Fixya. OK.
Dec 20, 2010 | Samsung CSN2077 20 in. TV/DVD Combo
Cant turn off the alarm and it keeps going off while I am playing music every 5 minutes
Not mentioned the Make model or the fault in detail. Please share the fault so that we are able to help you find a solution.
mention the product and symtoms.
Sep 14, 2010 | Audio Players & Recorders
Error: 0xb9000001 has appeared on the screen and the printer is not working... what do i do??
please follow the instrution mention from the below URL
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00112149&cc=us&lc=en&dlc=en&product=422000
If still this should not resolve your problem then try this URL mention from the below
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00712074&cc=us&lc=en&dlc=en&product=422000
now still it not work then follow this URL mention from the below
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00587637&cc=us&lc=en&dlc=en&product=422000
now to follow all this you not resolve your issue then contact HP toll free number 1800-474-6836 they will replace your printe if its under warrantry priode
thanks
regards
Hamid
Mar 01, 2010 | HP PSC 2355 All-In-One InkJet Printer
No turn on
Check that you have power to the set and does the set click?
Common fault for this model include - blown power supply transistors due to bad solder contact at horizontal drive transformer.
Read below and decide if you want to tackle the problem yourself if so I’ll help along the way with what info I have. If not contact the nearest repair shop armed with the info below.
A dead set (no picture no sound) can indicate any number of problems – Usually the set is in shutdown or protection mode – this means that the internal circuits have detected a problem with a supply voltage missing, drawing too much current, going over voltage or a short condition.
The first thing to do is power off the set unplug it for 5min. than replug and try again. This in effect resets the main micro and will sometime unlatch a fault and resume working. There are certain common problems based on the make model – for instance convergence output IC’s(CRT projection TV’s) can cause a dead set symptom in many models. Vertical output IC failure can also cause the same symptom (CRT standard and Projection).
The only way to determine the real cause is :
By an educated guess based on experience or by directly troubleshooting the set – checking fuses, measuring voltages and checking for shorts. Many of the intermittent problems such as, int.(Intermittent) no sound or picture, int. picture shrunken or misshaped. These problems are generally due to cold (bad) solder joints (all TV’s and electronics) that break down under slight temperature changes or vibration and are usually verified by physically tapping the suspected area on the circuit board, or by quickly heating or cooling a suspected component or area ( cold spray and hot air gun). The other main culprit is leaky or dried out capacitors or capacitors that change value depending on temperature. These can sometimes be seen as bulged or leaky and have an acrid odour. Be sure to vote/rate me if this helped Thanks!
Oct 05, 2009 | Sony FD Trinitron WEGA KV-27FS320 27" TV
Hitachi rear projection tv will not turn on. what do i need to replace?
Here are a couple of common faults for this model from the hitachi Sevice Website
Symptom: INTM GOES DEAD
Cause: SOLDER K088,89,90,91 (JUMPERS)
Symptom: POWERS UP; SHUTS DOWN
Cause: CHECK C922, C921, L708, CONNECTION AT PIN 1 OF I907
Sep 26, 2009 | Hitachi 61SWX10B 61" Rear Projection...
Whirlpool Duet GHW9150P Front Load Washer Logo
21 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
