Front Load Washer - Error F30
We just purchased a new Maytag Epic z, Model MHWZ600TW, Front Load Clothes Washer, which was delivered yesterday, the 15th. Set up was easy, and started by dong the user manual's suggested first wash without clothes and only 1/2 the normal detergent. After two successfull cycles (each cycle being adding water, wash, drain, high speed spin), and with about 22 minutes left (as indicated on the digital readout), the machine stopped with an error F30. After going through the recommended troubleshooting as well as disconnecting the washer for about 30 minutes, nothing cleared the error.
Whenever we try to start the machine, the following sequence occurs:
1. After pushing start, the machine locks for a few seconds, then unlocks
2. The tub turns once or twice and stops.
3. Although we hear what apparantly seems to be valves clicking, no water inters the tub.
4. The tub stops, the washer locks again and just sits there.
  • 1 more comment
  • Anonymous Jul 19, 2008
    SAME THIG WITH MINE.....
  • Anonymous Nov 19, 2008
    I have the same problem. Service guy did something to it. It washed a few loads. Now have same problem again. Have scheduled service again.
  • kimcarson Jan 07, 2009
    sAME PROBLEM
    Problem Solver:
My maytag mdg5806 aww
just works few second and then goes
can help me?
Posted on Sep 03, 2011
HI I HAVE REMOVE THE TOP COVER. YOU WILL SEE AT LEFT A PLASTIC ACTUATOR WHO MUST BE UNPLUG FROM ANOTHER PLASTIC PIN. JUST PUT IT BACK TOGETHER AND THE PROBLEM WAS GONE!
Posted on Jul 19, 2008
My Maytag washer has a flashing F 15. What does that mean?
The following list of codes indicates an electronics communication problem with the washer: * EpicĀ® washer - F05, F07, F09, F10, F11, F13, F14, F15, F21, F22, and FdU
* Epic ZTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33
To remove the error display, press Pause/Off or Pause/Cancel twice.
If Pause/Off or Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
Hope this helps.
Jun 24, 2011 | Maytag EPIC MFW9700S Front Load Washer
F30 code on 3000 series washer
I don't know the answer, but you can call Maytag @ call 800-688-9900 toll free for a code definition
Feb 26, 2011 | Maytag EPIC MFW9700S Front Load Washer
Maytag Epic giving F11 error code!
ths.gardenweb.com/forums/load/.../msg1012004912002.html
Jun 22, 2009 | Maytag EPIC MFW9700S Front Load Washer
F30 code
F30 = DISPENSER SYSTEM ERROR
You might have to replace the damaged one.Or in other words something that cannot be repaired.Well came across this info through other certified websites.good luck.hope this helps out.
Jan 09, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Epic Error "F"
I dont know how to fix it but if you hit OFF then start it restarts, i get the same message it will appare over and over again untill the load is done.
Oct 18, 2008 | Maytag EPIC MFW9700S Front Load Washer
Maytag Epic Washer high spin shaking, AND high-pitched sound coming out of washer
When someone reports severe vibration during spin on a brand new washer, the first question always has to be whether the transit brackets have been left in.
Washers are designed so that the drum and motor float on a collection of springs and shock absorbers. To prevent damage to these during shipping, a set of brackets is used to bolt the floating assembly to the case. If these aren't removed before first use (the manual will say how to do it) havoc ensues.
The irritating whine is a new one on me.
A.
Jul 04, 2008 | Maytag EPIC MFW9700S Front Load Washer
Maytag Epic Z error code
I need a clear code for maytag epic z front load washer
code f-o1 is coming up
says intall new ccu, I did but still the same
do I need to clear the code if so how.
please tell me.
Jun 16, 2008 | Maytag EPIC MFW9700S Front Load Washer
Maytag Epic
the control board has loose solder connections around the relays.
see this
diff model same issue with new boards as they make them all.
http://www.fixya.com/support/t364216-whirlpool_duet_ht_ghw9400pl0
being it is in warranty its too early for you to fix it yourself.
you will have to wait for them to come out and say the parts are on backorder.
Feb 04, 2008 | Maytag EPIC MFW9700S Front Load Washer
Washing Machines Logo
560 people viewed this question
Top Washing Machines Experts
