Question about Motorola Walkie Talkie 2-Way Radio
The battery is fully charged on the walkie talkies and all are on the same channel, however out of 12 walkie talkies only 2 will work. When ever you push the push to talk button the walkie talkie shuts off and this is happpening with 10 out of 12 of our walkie talkies.
  • Yegg Mann Nov 11, 2012
    The same thing happened to me, all you have to do is put it on charge for 20 mins, then take it out, keep on pressing the on button, leave again for 5 mins and then click the on button and it should turn on. It just needs a boot or a jumpstart if you have not used it for a long time like me :) Hope this helps
  • Motorola Master
  • 1,654 Answers
Your batteries are either no good, or not charged. When you press the PTT button it takes more energy than being in standby mode. If you have a battery problem it will fail quickly when the PTT is pressed.
Rechargeable batteries last approx. 18-24 months. Check your battery for a 3-digit date code. It is usually a 3 digit number followed by a couple of letters. The numbers tell the date of manufacture. The first number is the year, followed by the week of the year. 025 would be 2010 the 25th week. (or if very old it could be 2000 the 25th week.)
If you feel age is not a problem, you might check your charger(s) to see they are fully powered, and clear of debris on the contacts (and the radio contacts as well). Clean with a pencil eraser if needed.
A few tips: Be certain when placing your radios on the charge they are turned off. Check your wall outlet to be certain it doesn't get shut off with a light switch. Expect to replace your batteries every 2-3 years.
Best regards.
Posted on Nov 10, 2010
Do you leav the cobra micro talk walkie talkies on when charging
Also, never transmit with them in the charging cradle. I know, lots do but you risk ruining the radio beyond repair.
Dec 26, 2014 | Cobra LI6050-2WXEVP microTALK 22 Channel...
Transister rsdio won't turn on or off
Very likely bad batteries in the handhelds. Make certain they have been charged fully and try again. If not, get new batteries. Batteries go bad even not used, sitting in a box or on a shelf. 1999 are likely nicad chemistry and without a professional battery conditioner, I doubt they will take a charge. You could try to charge and dis charge them your self 10-12 times. Sometimes this will work. Fully charge the battery, put in the radio and turn it on until the radio beeps. Do not let it go dead overnight or you make the problem worse.
Sep 30, 2014 | Radio Shack 1999 Radioshack 6 Transistor...
I have k7gfv700 Motorola walkie talkies w/ charger. The charge seems to work, but the lighs one the charge are red and the talkie do not charge. Do I need new batteries and where can I purchase the
You might try http://wirelesspro.com, we have found them to carry most TalkAbout accessories and batteries. Before ordering battery packs, you might try switching your existing good battery to the other radio and see if it solves the problem. This would assure you that it is indeed a battery problem.
Sep 28, 2014 | Motorola Walkie Talkies 2-Way Radio
Walkie talkies were working yesterday (gift from Christmas) and today the red power light is on indicating both working, but we can only get sound out of one of them.....any suggestions? brand new...
These walkie talkies are pretty simple to use. Turn on and turn the volume up and talk. So if you turn it on it is possible for there to be enough juice in the batteries to make the LED function but not enough to modulate (or talk) to the other walkie talkie. Have you tried to replacing the batteries with new ones yet? Sometimes recharge ables go bad and they are no good when you install them into your item. So make sure the batteries you installed are "new." And replace in both units. Should this not work, given the nature of the item and the age of those who will more than likely be using them, they break and soldier joints come loose. The back has a screw that is a specialty tool to remove. Outside of removing that and taking a look there is not much that can be done. Make sure to put at least 5 feet between the two radios to allow for good reception.
Regards, Tony
Apr 17, 2011 | Digital Blue LEGO Walkie Talkies
I have the cobra micro talk with rechargeable batteries my workers plug them up every night and get them in the morning but some arestill saying low battery, does the walkie talkie need to be turned off...
they charge better if they are turned off. since they do not have a paid dedicated channel, signals can
still be received by any walkie talkie using the same channel, and can deplete the charging process
to the radio. good luck!
Dec 07, 2010 | Cobra Microtalk 100 FRS Walkie Talkie...
Walkie talkie batteries don't last
The Batteries that Motorola uses will die after a while mainly because people leave them on the charger all of the time. But there is a way to refresh them. You let the battery die completely, then you charge it up for about 12 hours. Then you let the battery die completely. Do this a couple of times and the batteries will last long.
Also, Motorola use to make a battery refresher (or did when I worked there.) It will charge and drain the battery automatically. It will even give you a fault if the battery is completely dead. For the HT1000 (for example) it would be the WPPN4065BR.
For future reference, don't constantly charge a battery. Only have it on the charger when the battery is actually dead or very low. This will increase battery life.
Mar 25, 2010 | ICOM Informatique Icom IC-F11 5W 16ch VHF...
Problems charging Cobra Walkie-talkie MT800 battery
Downloading the manual will now make the batteries charge?
apimom
Sep 21, 2008 | Cobra PR-245/2 (7 Channels) 2-Way Radio
How do I make it work
It depends on the channels on the walkie talkies.
Can you supply the frz range of the TRC, and walkie talkies make and model and I will try and get the frez on the channels for you.
I can then tell if it will work or not.
Apr 27, 2008 | Computers & Internet
Radio Communications Logo
2,517 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Greg Cann
Greg Cann
bill tarkulich
Level 1 Expert
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
