Question about Maytag Neptune MDE5500AY Electric Dryer
Control Panel is on but no response to buttons being pushed. Recycled power - no help
  • A.J. Murk Nov 09, 2010
    I just posted this problem and found my own solution. I cleaned out the vent tube, although it didn't seem too clogged, when I put it all back together everything seems to be OK.
Have been having the same problem on and off for about 9 months now. It would unfreeze quickly at first by heating the top of the dryer cabinet at the control panel with a hair dryer (believe it or not). Got tired of doing that every time I need to use the dryer so just ordered a new control assembly with touchpad. Here's the link: http://www.appliancepartspros.com/part_details.aspx?part_id=4043476
Good luck
Posted on Nov 11, 2010
Regency problems
follow this steps and fix it. God bless you
Touchpad and Control Panel
If the buttons don't work on the control panel the entire touchpad and control panel assembly may need to be replaced. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Touchpad
If the buttons don't work on the control panel, the dishwasher touchpad might be at fault. Generally speaking, if the dishwasher display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
Main Control Board
The dishwasher has a main control board which regulates nearly every function in the dishwasher. If the control panel buttons don't work, and other causes have been ruled out, the main control board might need to be replaced.
Jun 14, 2013 | Maytag Dishwashers
Tip
Windows and windshield fogs up in the winter
the real solution is to turn on and up the fans BUT you must use the fresh air from outside instead of recycled air. This is done by selecting or deselecting it using its own button. On my Toyota 2006 RAV 4, there's a button you push which is on the center of the climate control knob. By pushing it, you are using fresh air instead of the air being recycled. Any questions, let me know.
on Sep 12, 2010 | Toyota RAV4 Cars & Trucks
47pfl56030d/27
If the front panel indicator lights, power is getting to your TV. Pushing the power button and getting no results indicates that something is wrong with the internal power supply
Jan 04, 2013 | Philips 47PFL5603D/27 Flat Widescreen TV...
Pentair Minimax NT heater -- panel doesn't respond.
if connected to control make sure heat is enabled
Jun 22, 2017 | Pentair Minimax NT Heater
I PUSH ON THE BUTTONS IN FRONT ( CONTROL PANEL) AND NOTHING HAPPENS.
Sorry to read about your problem.
It seems you have a general failure in the power control or switch failure on the unit. if your unit has power, and things lite. it is more likely you have a control/switch problem,
since you can replace your unit for under $100.00 a service call would not be worth it.
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 21, 2010 | Danby DMW1153 Microwave Oven
Jenn-air electric double control does not work - clock is on
Disconnect the Power Supply for few minutes, say 30 minutes and then Turn the Oven ON.
Do you see any Error Message?
How old the Unit is?
Do you have any Experience to Fix this?
Do you have all the tools?
Let me know, so that we could proceed.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jan 30, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
Tv wont come on at all..push the power button.. nothing, use the remote..nothing, not even a flicker...please assist
hi..this is probably an issue with the power supply
of the tv.check the power supply.
thank u..
kindly rate my response..
May 09, 2009 | Protron PLTV-37 37 in. LCD Television
No response from control panel
Try this
Brew group missing indicator
Open the door on the right. Push on the upper left side of the brew unit until you hear a click. Close the door and see if the message is gone. If it is make sure that the grounds drawer is in place.
Tip: Pull the grounds drawer out, then push it back with only 1 finger and push it on the right side of the drawer. This will make sure that it engages the micro switch.
Apr 17, 2009 | Saeco Magic De Luxe Espresso Machine
Tricky touch pad on Sharp R530 es microwave oven
There are two options here:
1. Order a new control panel frame which has the keypad, trim piece and door button already installed and swap your control boards into it.
The original part number FPNLCB346MRK0 has been replaced by part # FPNLCB346MRK0B and it runs $58.28 plus shipping.
2. Disassemble your control panel frame, peel off the old keypad and stick a new one on.
Even though the keypad alone runs only $35.66, this job takes a lot of time and labor.
If you (or someone you know) might want to replace just the keypad yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
Whichever option you choose, we have the service manual for this model and have uploaded it to our site here to help you.
You will need the
free Acrobat Reader to view or print it in case you don't have it already.
Jan 18, 2009 | Sharp R-530ES Microwave Oven
Maytag Neptune MDE5500AY Electric Dryer Logo
107 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
