Question about Kenmore Washing Machines
I have a 9 yr. old Kenmore washer with oil underneath. Is it worth fixing, or should I replace it?
  • 441 Answers
If you have oil under the unit dont fix it! At nine years old this is not worth it, if you have oil its the trans that is shot. Your looking at 300-500 for a repair. I would look at the new ge washers they have no trans, also fisher & paykel makes a great washer that has no trans
Posted on Nov 09, 2010
Testimonial: "fast answer"
Makes noise in spin cycle and now it started smoking. Tub seems to spin more easy but i don't hear anything like a bearing.
LG WM2688H Front Load Washer Smoking power ... - Fixya
www.fixya.com > ... > LG > WM > LG WM2688H Front Load Washer
LG WM2688H Front Load Washer, smoking power related issues. ... is it worth trying to fix drum loud and rattles when on spin cycle, then smoke started pouring out of ...hi working till smoke came out the back and now no power - Unplug it. ... washer makenoise doing spin cycle smell smoke make the power cord warm to ...
LG 4280FR4048L Bearing - AppliancePartsPros.com
www.appliancepartspros.com > ... > Washer > Kenmore Washer Parts
Rating: 5 - ‎189 reviews - ‎$32.19
Burnt rubber smell at end of cycle from 11 yr old lg wm2277hw front load washer i hand spun inner drum it was ... Appliance: LG Washer WM2277HW ... Our LG "Tromm"washer (a.k.a. "Trommy Baby") started making a horrible ... The bearings were worn and made very loud noise in the spin cycle John A. • Punta Gorda, FL.
LG WM2455HW washing machine problem - YouTube
? 10:29
https://www.youtube.com/watch?v=__abhTwmi1I
Sep 15, 2010 - Uploaded by djmcarter
I also have an LG refrigerator, which makes a loud sound (it's the.... I am watching your video while mopping up water underneath the exact same machine right now. ... How to Fix an LG Front load washer machine that wont spin - Duration: 5:32. ...
Jan 19, 2016 | LG WM2277H Front Load Washer
The spin cycle sounds like a jet plane taking off. Any ideas as to what it could be?
Main bearing failure probably. Have a look underneath for an oil or rusty water stain around the cabinet... If it has, it may be an expensive repair and probably not worth fixing.
Dec 21, 2014 | Kenmore Elite Oasis 27052 Top Load Washer
Leaking oil underneath clothes dryer
My mom has a Kenmore dryer that is less than a year old. It leaks oil under front side. What can I do to fix it.
Jun 29, 2012 | Kenmore Dryers
The seals failed on my 6 yr old kenmore front load washer and the bearing is making noise and the machine shakes. Is this an economical fix or should I buy a new one.
The bearing is bad as you already know , call a local repairman and compare the price between having it fixed and replacement , make sure you take into concideration the age of your unit, MIKE
Dec 30, 2009 | Kenmore HE2 Plus Front Load Washer
I have an 11-yr-old Amana washer that is all of a sudden leaking water underneath. Any ideas?
ammanas are famouse for this it is the drum seal dependending on how long it been leaking it maynot be worth replaceing do do leakage on other components
Oct 31, 2009 | Amana Washing Machines
My 80 series kenmore washer will not agitate unless I push down on the center of the part that agitates. it pins fine. is this something I can fix myself? is it worth fixing or should I look at replacing...
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
This problem points to a couple of places:
First, I'd pull the agitators and check for worn or damaged splines inside the agitator or on the agitator shaft.
Following is a description of how to take them out.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
If the agitator and shaft are OK, the problem may be in the transmission.
See the following Whirlpool / Kenmore installation and service manual for top load, direct drive washers.
Starting at page 10, you'll see a description of how the transmission changes from agitate to spin mode.
The key (and likely problem) is the "agitator spring".
The spring holds the agitate gear down so that the two sets of splines on the agitate gear are connected and the agitate rack can turn the agitators.
See the following Whirlpool parts list for a blow-up of the transmission and how the various gears and springs connect.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
See the following for how to remove the transmission and clutch.
Tearing apart the transmission is a bit messy but if the problem is the spring or agitate cams, it's a lot less expensive to fix than a $170 transmission.
Remove the clutch (the spring holding the clutch to the spin pinion is a bear to replace.
Remove the 8 transmission screws carefully, the transmission is full (15 oz.) of 80-90 weight oil.
Remove the transmission cover and drain the oil.
Pull off the spin pinion.
Carefully remove the clip that holds the main Spin Gear on and remove it.
Push down on the agitate spring and remove the spring clip. Note where is attaches to the main shaft.
Check the spring, Agitate Cams and the cams in the Neutral Drain Assembly.
Re-assembly is obviously the reverse of taking it apart.
In answer to your other questions:
If you're reasonably comfortable with tools you can fix it yourself.
When we had a problem with ours, we ended up spending less than $30 replacing the agitate cams, neutral drain assembly and oil instead of $170 for a transmission. It was worth fixing.
As an aside, tearing the washer apart will give you the opportunity to completely clean it.
Oct 24, 2009 | Kenmore Washing Machines
Kenmore Series 80 Washer leaking oil underneath
TRY TO CHECK THE RUNNING CAPACITOR MAY BE THE OIL THAT YOU SAW CAME FROM THE DAMAGE CAPACTIOR.
Aug 21, 2009 | Kenmore 22642 Top Load Washer
4 yr old Kenmore Elite washer will not spin
sure sounds a little suspect ot me,some one not knowing who to remove the top of this( perhaps the easiest of all machines to work on) then condemns the machine? yea id look for a second (more knowedgleable ) opionion
Dec 10, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore dryer king size capacity 90 series
Sorry to say, but the motor needs to be replaced. motor cost around $150... 9yrs old=not worth fixing...
Jan 03, 2008 | Kenmore 63942 Dryer
Washing Machines Logo
125 people viewed this question
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
